Act on a discrepancy
Once you find the discrepancies you need to locate, you can act on them to change the state, send to InForm or another system, modify the description, or export the details.
See this video for details:
This section describes how to complete the following tasks:
- Change the state of multiple discrepancies
- Add a comment
- Edit a Discrepancy
- Edit the text of multiple discrepancies
You can edit the text of up to 50 discrepancies at one time, provided that they did not originate from InForm or an external source. - Export discrepancies on lab data
You can export discrepancies to Excel( (.xls) or .csv format using the Export button located in the discrepancies interface.
Parent topic: Review and act on discrepancies
