Edit a Discrepancy
  1. Do one of the following:
  2. After you select a study, do one of the following:
    • If you selected a study from Study Manager, click Data Management. Data Management in the navigation bar and select Discrepancies from the drop-down menu.
    • If you selected a study from Home, you can navigation to the discrepancies interface by clicking any of the data sets in the graphs on the Discrepancy Dashboard. For more information, see Use the Discrepancy Dashboard.
  3. Find the discrepancies you need to locate using the filters on the left panel or the top of the page. (See Find discrepancies for details on using the filters.)
  4. Select a discrepancy.
  5. In the right panel, click Edit.Edit.
    Tip:
    You can skip the remaining steps and use keyboard shortcuts to edit one discrepancy at a time by pressing Ctrl+Alt+E. Edit the Discrepancy field (if available). Press Tab to navigate to the Category field (if necessary), use the down arrow key to open the drop-down menu and select an option. Press Tab to navigate to Submit and press Enter.
  6. On the Discrepancy Details panel, you can perform the following:
    1. Edit the Discrepancy field.
    2. Edit the risk score values for Impact, Probability, and Non-detectability.
    3. Select a value from the Category drop-down.
    4. Select a value from the Action drop-down. When you select an Action, you can also select an associated Reason for the action and add a Comment.
    5. Select or clear the Allow Auto Close option.
  7. Click Submit.
