Filter predefined signal management reports
Filter the data using Shared Analysis Criteria to run the reports you need.
Before you generate the predefined reports, you must first filter the data in the Shared Analysis Criteria section that corresponds to each report.
If you select a filter that doesn't apply to the report, it will be ignored. You can view each required field for every report on the user interface Shared Analysis Criteria page on the left pane and on the Predefined Oracle Analytics signal management reports.
Parent topic: View signal management reports
