Configuring the InForm Publisher application using the Publisher configuration tool
The Publisher configuration tool is a user interface that allows you to modify the InForm Publisher configuration file.
The Publisher configuration tool appears when you click the Launch Config tool checkbox in the installer wizard. In addition, the tool, which is named PublisherConfigUI, is also located in the \Bin folder of the location where you installed the InForm Publisher software.
