Stopping and starting the InForm Publisher application
Click the Start or Stop button in the upper-right corner of the InForm Publisher Configuration dialog box.
Note: You can enable or disable event publishing by selecting the Event Publishing Enabled checkbox. If you disable event publishing and have subscribers defined, events will not be transmitted to subscribers.
