Configuring the Oracle Life Sciences InForm Publisher application using PublisherAdmin
The PublisherAdmin command allows you to configure the Oracle InForm Publisher application from the command line. The PublisherAdmin command line syntax contains the following commands, each with its own set of parameters.
The command line executable file, PublisherAdmin.exe, is available in the \Bin folder of the location where you installed the Oracle InForm Publisher software.
- EventPublishing
The EventPublishing command allows you to start or stop publishing events.
- service
The service command allows you to view the status of the Oracle Life Sciences InForm Publisher service, and to start, stop, or restart it. - subscriber
The subscriber command allows you to view and modify subscriber settings. You can define a subscriber for each instance of the target application to which the Oracle Life Sciences InForm Publisher application publishes data. - trial
The trial command allows you to view and modify study attributes. Use the trial command to define the list of studies that publish to the target application. - grantor
The grantor command defines the Oracle Life Sciences InForm Publisher Database User that is created by the installer. This database user can grant privileges to the study database user. The database, the privilege-granting user account, and the password for that user account are encrypted using internal encryption specifications. - Example—PublisherAdmin command
