Detail by criteria reporting
- Select the Detail By Criteria Reporting tab.
Figure 2-7 Detail By Criteria Reporting
- In the Request Level Parameters section, optionally
provide a Bookmark and/or a Result Set
Size for the request.Result Set Size indicates the maximum number of discrepancies to return in the response. If the maximum is reached and there are more discrepancies to return, the response will contain a bookmark. You can input this bookmark on a subsequent request that uses the same request parameters to get the remaining discrepancies.
- Click Add Parameters.The parameters are added to the Current Detail by Criteria Request field.
- In the Detail Filter Parameters section, provide the
following information:
- Trial (Required) - The study name for which you want detail by criteria reports of discrepancies.
- Filter Name (Optional) - Name for the current request filter. The filter name can be used to decipher the response.
- Include History -
- Selected—All the revisions of the discrepancies are returned for this filter.
- Unselected—Only the latest revisions of the discrepancies are returned.
- Trial Criteria - If selected, you can provide avSite ID on which to filter the results.
- Item Criteria - If selected, you can provide an Item Dbuid on which to filter the results.
- Current State - Select one or more checkboxes to
filter by the state of the discrepancy. If no boxes are checked, all
states are returned:
- Candidate.
- Opened.
- Answered.
- Closed.
- Deleted.
- Click Add Detail Filter.The Detail Filter is added to the Current Detail By Request field, which displays the DetailByCriteriaRequest XML as you are building it.
You can add multiple filters to the request.
- When the request is complete, click Get
Discrepancies.The sampler calls the Discrepancy interface GetDiscrepanciesByCriteria operation, and displays the response XML in the results pane.
Parent topic: Discrepancy reporting
