PreviousNext
JavaScript must be enabled to correctly display this content
Detail by GUID reporting
Select the Detail By Guid Reporting tab.
Figure 2-8 Detail By Guid Reporting
In the Request Level Parameters section, optionally
provide a Bookmark and/or a Result Set
Size for the request.
Result Set Size indicates the maximum number of discrepancies to return in the
response. If the maximum is reached and there are more discrepancies to return,
the response will contain a bookmark. You can input this bookmark on a
subsequent request that uses the same request parameters to get the remaining
discrepancies.
Click Add Parameters.
The parameters are added to the Current Detail By Guid Request
field.
In the Detail Filter Parameters section, provide the
following information:
Trial (Required) - The study name for which you
want detail by criteria reports of discrepancies.
Filter Name (Optional) - Name for the current
request filter. The filter name can be used to decipher the
response.
Discrepancy GUID - Specifies the discrepancy
GUIDs to add to the Discrepancy GUIDs in this filter list. Each detail
filter can have one or more discrepancy GUIDs.
Click Add Detail Filter.
The GetByDiscrepancyGuid request XML appears in the Current Detail By
Guid Request field.
To add more filters, repeat steps 3 through 6.
When the request is complete, click Get
Discrepancies.
The response XML appears in a tab in the results pane.
The request XML
remains in the Current Detail By Guid Request field. To remove the XML,
click Clear Request.
