Integrating SAS with the Oracle Life Sciences Data Hub
Oracle LSH is designed for close integration with SAS at several levels. You can load SAS data set files into Oracle LSH, use SAS as an integrated development environment to create Oracle LSH Programs with SAS source code, and use the SAS engine to run these Programs on Oracle LSH data.
Oracle LSH supports integration with SAS 9.4.
Oracle Life Sciences Data Hub does not support a SAS Windows server.
This section includes the following topics:
