6 Integrating Other Systems
The Oracle Life Sciences Data Hub (Oracle LSH) supports integration with other systems as sources of data, as means of visualizing and reporting on Oracle LSH data, and as processing engines for transforming Oracle LSH data. Oracle LSH handles integration with such systems with adapters custom made for each external system. Adapters for the systems included in this chapter are included with Oracle LSH.
You must install the adapters and grant them security privileges. These tasks are covered in Load the Adapter Files and Grant Security Rights to Seeded Adapters.
Each external system you choose to integrate with Oracle LSH requires installation and some additional setup, described here. The exception is Oracle Reports, which is installed as part of Oracle Applications and requires no further setup.
For information on supported versions of these products, see Integrated External Systems or for the most current information, see Oracle Life Sciences Applications Supported Technology Stacks (Document ID 180430.1) on My Oracle Support.
- Integrating Oracle Clinical with the Oracle Life Sciences Data Hub
- Integrating SAS with the Oracle Life Sciences Data Hub
- Integrating Oracle SQL Developer or Oracle SQL*Plus with the Oracle Life Sciences Data Hub
- Integrating Oracle Business Intelligence Enterprise Editions (OBIEE) for Visualizations
