Reverse PI replacement
When appropriate you can reinstate a Principal Investigator and save time by using data already saved for that investigator instead of manually recreating the data.
  1. On the site details page, click the Staff tab.
  2. Next to the replaced PI's name, click Actions and select Reinstate PI.
  3. In the confirmation dialog, click Confirm.
When confirmed, the following reinstatement behaviors apply:
  • Documents for the reinstated PI that were marked as "For replaced PI" will be marked as “Active.”
  • The PI being replaced (by the reinstated PI) will go through the normal PI replacement process, and documents associated with the replaced PI will be marked as “For replaced PI.”
  • On the Staff tab, the reinstated PI is marked as “Active” with the original Added date, and the replaced PI will be marked as replaced.
