View plan outcome in tabular format
Tabular view shows study summary milestones enabled for the account in the milestones set up area. The summary milestone columns automatically order by date, from the left (earliest) to the right (latest).
To complete this task, you must have a business role permission that allows you to access Study Planning. If you want to change the data shown in the tabular view and another user created the plan you are viewing, you must have a business role permission that allows you to modify the other user’s study plan.
- On the Studies Planned page, click the name of the study plan you want to see in the tabular view.
- Optionally adjust the Select Countries filter to view preferred plan countries.
- Optionally adjust the Probability Range filter to select a different range, as preferred.
- Optionally adjust milestone dates where edit (
) displays on hover over. By design, summary milestone dates are not editable; the Study Planning tool automatically calculates dates for summary milestones.
Parent topic: Plans and visualizations
