11 Control and Tactical Center
Using the Control and Tactical Center, a user can access Strategy & Policy Management. This is the central place for managing the configurations of different applications and for setting up and configuring the demand forecasting runs.
In addition, a user can access the modules for managing product attributes (Attribute Extraction and Attribute Binning) as well as the link for managing web service-related credentials under the Control & Tactical Center.
Depending on the role, a user will see one or multiple of the following links, as shown below.The administrator user will have access to all of the links.
Strategy and Policy Management
Manage Credential Stores
Attribute Binning
In Strategy & Policy Management, a user can edit the configurations of different applications via the Manage System Configurations functionality. In this screen, the tables can be filtered by applications.
To edit a row in any table, click the row and click the Edit icon. You can override the values for the columns that are editable.
Use the Manage Forecast Configurations to set up, manage, and configure the demand forecasting runs for different applications such as Lifecycle Pricing Optimization (LPO), Inventory Planning Optimization-Demand Forecasting (IPO-DF), Inventory Planning Optimization-Inventory Optimization (IPO-IO), Inventory Planning Optimization-Lifecycle Allocation & Replenishment (IPO-LAR), Merchandise Financial Planning (MFP), and Assortment Planning (AP).
Figure 11-2 Strategy & Policy Management Dashboard
Description of "Figure 11-2 Strategy & Policy Management Dashboard"
Manage Business Rules
Business rules are policy inputs that inform the optimizations about business intent, boundaries, and so on. Each type of rule is created for specific purposes (for example, promotion rules, inventory rules) and are grouped into categories of related concepts.
However, the expected business outcomes can’t easily be understood by looking at the pieces (individual rules). Rather, the set of rules that function together must be viewed together to build a complete understanding of the business drivers. This is achieved by grouping rules into Strategies. Strategies are the mechanism to organize rules around business intent.
To help reduce maintenance, rules are re-usable across strategies. Rules are individually maintained in the Rules Library so that all strategies making use of the rule automatically uptake modification.
Alert rules are also defined for specific business purposes. Alert rules are not assigned to strategies as they do not frequently change due to business events.
Alert Management
Alerts are user workflow indicators. They are used to indicate situations where the optimization results fall outside of the business defined thresholds. Alert Management is where you will define which alerts are relevant to your business and the associated thresholds for each alert type.
Open the Task menu.
Figure 11-4 Task Menu
Click Alert Management.
Inventory Alert Rules
Create or edit rule thresholds in any of the Rule Categories.
Overstock | Alerts the inventory planner when a review day’s beginning of day inventory meets or exceeds the OUTL for that review day and/or Inventory units exceeds the specified threshold. This means that the inventory in the preceding period is more than enough to meet the demand of the prior, and the next review period. The inventory planner will review preceding stock levels, receipts, and forecast or actual sales. |
Out of Stock |
Out of stock alerts are based on lost sales. This alert requires a demand forecast in order to calculate lost sales. Lost sales occur any day inventory plus receipts exceeds the forecasted demand. Note that retail value is always calculated as full retail value. |
Low Stock |
Alerts the inventory planner to the days where inventory falls below acceptable thresholds of Days of Supply (DOS) and/or units. The DOS thresholds requires a demand forecast. The demand forecast is used to calculate average demand of the week. Then each day’s beginning inventory is divided by the average demand to determine if it falls below DOS threshold. A day that meets out of stock rules will not be alerted for Low Stock. Tip: to ignore DOS threshold set it to 0 and choose ‘OR’ Inventory is Less Than… |
Rules Management
In the Promotion Effects module used by the Sales & Promo forecast method, promotion data flows from RI into AIF. This enables the modeling of promotions based on the promotions the retailer has defined at the lowest level.
The following three levels in the hierarchy are used to define a promotion.
Campaign: The highest level in the promotion hierarchy. A campaign can be used to group one or more promotions specific to an event or a holiday (for example, Fall campaign, Christmas campaign, and Back to School campaign).
Promotion: A campaign can be further divided into smaller time frames. For example, a Christmas campaign can be divided into a Week 1 promotion, a Week 2 promotion, and a Week 3 promotion. During a promotion, multiple offers can be active.
Offer: An offer defines the mechanism used during a promotion (for example, BOGO, 20% Off, 50% Off, TV Ad, and Gift with purchase).
The user can manage promotion data in the Promotion Management module to clean up the campaign and offer data.
The raw data provided by the retailer may not be suitable for the modeling of promotions. Consider, for example, information about two fall campaigns, one in 2022 and one in 2023. If the year information is present in the campaign description, it must be removed for modeling purposes as well as to estimate the lifts associated with fall campaign and to apply the observed lift values for future fall campaigns in following years. Similarly, an offer description may contain unwanted information such as month or product descriptions. After the data is cleaned up, the campaign and offer names are referred to as Campaign alias and Offer alias. These values are passed to the Promotion Effects module so that the lift values can be estimated.
The following section describes the management of promotion data for forecasting. The process for estimating the promotion lifts is described under Promotion Effects.
Access the Promotion Management module from the AI Foundation Cloud Services page as follows:
Control and Tactical Center -> Strategy & Policy Management -> Tasks -> Rules Management -> Promotion Management
The Strategy & Policy Management window opens.
Figure 11-5 Strategy and Policy Management with the Tasks Pane
Select Rules Management. You see the Rules Category screen. Under Rules Category, select Promotion Management to view the screen for managing the campaign and offer data in AIF.
Figure 11-6 Promotion Management
Both Campaign data and Offer data are managed in a similar way; the following process describes managing the Offer data.
Select Manage Offer Rules
- Offers: This tab contains the offer data received from the retailer. Review the data to understand the various offers used and pay attention to prefixes or suffixes to the offers that do not add value or that may have an impact on the lift estimation. Similar offers can be grouped together if necessary. For example, BOGO 50% and BOGO 100% can be combined to generate BOGO.
- Rules: Rules can be created to remove unwanted descriptions from the offer data.
- Results: Review the results after the rule is applied and make changes to the rule if necessary.
- Number of offers: Offers received from the retailer through the data file.
- Number of offers with rules: After each rule is created, this metric is updated by the total number of offers for which an alias value is generated by a rule.
- Number of offers with conflicts: Occasionally, multiple rules can impact an offer with conflicting results. This alerts the user of the need to review the rules and make changes.
- TV Ad with Month and Year. The month and year can be removed using rules to generate an offer alias of TV AD corresponding to these offers.
- Price Discount with Year and Season: The year and season can be removed using rules to generate an offer alias of Price Discount corresponding to these offers.
- Web Promo: Multiple offers associated with the web promotion can be grouped by creating an appropriate rule to generate an offer alias Web Promo.
- % Off: All the offers with % Off can be grouped to generate an alias % Off.
Figure 11-7 Offers
Select the Rules tab to see the following screen. This is used to create the new rules and review the existing rules. In this example, rules have already been created for Price Discount, Web Promo, TV Ad, and % Off. Select the + symbol to view the Create Rule screen. To edit a rule, select an already defined rule and click Edit.
Figure 11-8 Rules
Create or Edit Offer Rules
- Description: Add a description to help manage the rules. This is used only in the Promotion Management screens.
- Rule criteria: Define the rule using the Query Builder. Use the Offer Name, Offer ID, and Offer Description columns to define the rules. Select one or more columns to define the rule. For each selected column, select the criteria from the drop-down menu.
- Rule value: Enter the alias value to associate with offers satisfying the rule criteria.
In the following example, all offer name that contain %-Off and Fall are identified and assigned a value of % Off-Fall. Click OK and save the rule. The Summary metrics are updated. You then see the Rule tab where you can review all the rules that have been created.
Figure 11-9 Query Builder
From the Rules tab, review the data for any conflicts in the Summary tab. You can select the Results tab to review the results and any conflicts.
Figure 11-10 Example Rules Tab
In the following Results tab, the Offer alias assigned to each Offer ID is shown. If there are conflicts for an Offer ID, a drop-down menu with multiple offer alias values associated with the Offer ID is displayed. To override the conflict, select one of the alias values in the UI or update the associated rules to remove the conflicts.
Figure 11-11 Example Results Tab
This section describes the workflow and screens in Manage Forecast Configurations. With this functionality, you can set up and manage the forecast run types and forecast runs for different applications.
You can access Manage Forecast Configurations from the Strategy & Policy Management dashboard under the Control & Tactical Center.
Forecast Run Type
The Forecast Run Type is the high-level template for forecast runs. Each run type has certain attributes that must be specified when the run type is being created. All configuration parameters default to the system default value when the run type is created. Use the Manage screen to modify the value of the configuration parameters for the run types.
Forecast Run
Forecast runs are created for a specific run type and are considered instances of the run type. The forecast run shares all the attributes of the run type and by default will have system default values for all configuration parameters. These parameters can be modified when a new run is being created in the Test screen.
Overview
The typical workflow for setting up run types, runs, and configuring the parameters is outlined in this section. Each step is described in detail in the sections that follow.
Create a run type in the Setup screen (train stop 1).
If the aggregation status of the run type is Not Started, start the aggregation.
Create a run in the Test screen (train stop 2) and override the configuration parameters as desired. Then submit the run.
Once the run is successfully completed, review the summary of outputs from the estimation process by clicking the Summary link next to the run. This feature is available only if the run uses the Life Cycle forecast method.
You can create as many runs as desired. These are considered what-if runs and allow you to experiment with different values for configuration parameters and examine the impact on the estimated demand parameters.
Set the configuration parameters for the run type in the Manage screen (train stop 3). This will determine the values that should be used in all subsequent batch runs for the given run type.
At the end of the implementation process, activate the run type to indicate that the run type should be part of the weekly batch process. During the weekly batch, a new run is created for each active run type.
Create a mapping between the run type and the application using the Map screen (train stop 4).
Setup
In the Setup screen in train stop 1, shown below, you can see the overview table of the existing run types and create new run types. In addition to Run Type Name, Run Type Description, Created On, and Created By, the table shows the following information about the run type.
Run Type Status
The Status column in the run type overview table shows whether the run type is Active or Inactive. Active run types become part of the weekly batch process, and a new batch run is created and executed for each active run type. Run types can be activated in the Manage screen in train stop 3.
Aggregation Status
The Aggregation Status column in the run type overview table shows whether the data aggregation for the run type is Not Started, In Progress, or Complete. Instances of runs can be generated for a run type (in the Test screen in train stop 2) only if the aggregation is complete.
Cumulative Aggregation Status
The Cumulative Aggregation Status column in the run type overview table shows whether the cumulative data aggregation for the run type is Not Started, In Progress, or Complete. Cumulative data aggregation is only applicable for run types with forecast method Life Cycle.
Forecast Intersection
The Forecast Intersection column in the run type overview table shows the merchandise-location-calendar intersection for which the forecast is generated. The intersection includes price zone and/or customer segment if the run type has those dimensions.
Applications
The Applications column in the run type overview table shows the application(s) that the run type is mapped to. You can map run types and applications in the Map screen in train stop 4.
External Application Key
The External Application Key column in the Run Type Overview table shows whether the external application key is not yet assigned to the run type. You can assign the external application key for a run type (in the Map screen in train stop 4) only if the run type is being mapped to the application IPO-DF.
Create a Run Type
To create a new run type, click the + (plus) icon above the run type overview table. In the Create Run Type pop-up, as shown below, you must specify the value for the following fields.
Run Type Name
This is a unique name and must be less than 30 characters. The run type name is used as an identifier when the forecast output is exported to other applications.
Forecast Method
A forecast method must be specified for each run type. All the runs created for the run type will use the selected forecast method. The methods that are currently supported are Sales & Promo, Life Cycle, Hierarchical Bayesian, and Automatic Exponential Smoothing. The forecast method must be chosen based on the specific use case and application.
Forecast Measure
This determines the measure that will be used as input by the forecasting algorithm. The final forecast will be generated for this measure. For the Sales & Promo and Life Cycle methods, the supported measures are total gross sales units, total net sales units, and regular & promotion gross sales units. For the Automatic Exponential Smoothing method, the forecast can be generated for other measures such as clearance sales, other sales, and returns.
Data Source
This determines which data will be used as input to the selected forecast method. The sources that are currently supported are store sales, warehouse transfers, warehouse shipments, and fact measures.
Customer Segment
Select Forecast by Customer Segments to generate the forecast by the merchandise/location/segment. If you turn on the switch, you must also click the button next to it in order to select one or multiple customer segments. It is recommended that you only select the segments that you want the forecast to be generated for (that is, un-select inactive segments) as this will make the data aggregation and forecast generation processes more efficient. Forecast by Customer Segment is applicable only for the Life Cycle method.
Price Zone Group
Select the Forecast by Price Zone to generate the forecast by merchandise/price zone. If you turn on the switch you must also click the button next to it in order to select one or multiple price zone groups. It is recommended that you only select the price zone groups that you want the forecast to be generated for (that is, un-select inactive price zone groups) as this will make the data aggregation and forecast generation processes more efficient. Forecast by price zone is applicable for the Life Cycle and Hierarchical Bayesian methods.
Forecast Level- Merchandise/Location/Calendar
Select the intersection that you want the forecast to be generated at. This will also determine the level at which sales data will be aggregated and flow through the various stages of forecasting. If you turn on the Forecast by Price Zone, the location level defaults to a level at the top of the location hierarchy. (This level is configurable and is determined by PMO_MIN_LOC_HIER_PROCESSING_LVL in the RSE_CONFIG table in the Manage System Configuration screen.)
Spread Profile Level — Merchandise/Location/Calendar
You can turn on the switch for the Spread Forecast to Day level only if the Forecast Level – Calendar is Week. Select the Spread Forecast Level for Merchandise/Location/Calendar only after turning on the switch for the Spread Forecast to Day level.
Data Aggregation
After you create a run type, you can see the aggregation status in the run type overview table. If the new run type has the same merchandise-location-calendar intersection as an existing run type, the aggregation status will be shown as complete as soon as you create the new run type because the data aggregation at that intersection has already been completed. This is applicable only for the run types that do not have a price zone dimension. For the run types that do have a price zone dimension, data aggregation must be done for each run type separately.
If any run type has an aggregation status of Not Started, click the Start Data Aggregation button above the run type overview table. This opens a pop-up where you can see a list of run types for which the aggregation process has not yet started, as shown in the next section..
You can select one or multiple run types from the top and/or bottom section in the pop-up and click Submit to start data aggregation. The Cumulative Aggregation process will be started once the aggregation process is submitted. It is only applicable for run types with forecast method Life Cycle.
Add Multiple Run Types
Click on the Add Multiple Run Types button. It will open a tab with a table consisting of available templates to create multiple run types at a time, as shown below. If the Enable column button is turned on and Process Flag column is null, then the corresponding row will be considered for creating run type. Click on the Create Run Types button to create multiple run types.
Click on + icon to add new process IDs to the table, as shown below. Select rows from the table and click on X icon to delete process IDs. User can also edit parameters within each row if Process Flag is null. Click the Save button to save the changes.
Figure 11-14 Add Multiple Run Types
Figure 11-15 Specify Run Type Configurations
Delete Run Type
Select one or multiple rows in the run type overview table, as shown below, and click the X icon above the table to delete the run types. If a run type is activated or if a run type has a run that is in progress, it cannot be deleted.
Figure 11-16 Select Aggregation Levels and Run Types
Description of "Figure 11-16 Select Aggregation Levels and Run Types"
Test
In the Test screen, the top table shows all the run types that have complete aggregation. This table shows the same information as the run type table in the Setup screen. The bottom table shows all the what-if runs and batch runs associated with the selected run type in the top table. In addition to Forecast Run Name, Created On, Created By, and Completed On, the table shows the following information about the run.
Status
The Status column in the run overview table shows the progress of the run by showing the status of the different stages of estimation and forecasting.
Setup
Preprocessing in Progress, Preprocessing Failed
Preprocessing Complete - Estimation in Progress, Preprocessing Complete - Estimation Failed
Estimation Complete - Base Demand in Progress, Estimation Complete - Base Demand Failed, Estimation Complete - Base Demand Complete, Estimation Complete - Base Demand Complete with Zero Rows
Estimation Complete - Forecast Generation in Progress, Estimation Complete - Forecast Generation Failed, Estimation Complete - Forecast Generation Complete, Estimation Complete - Forecast Generation Complete with Zero Rows
Estimation Run
In all forecast methods, the estimation process runs initially to generate the demand parameters such as seasonality and elasticity. Subsequently, the forecast process runs to generate the base demand and the forecast using the outputs from the estimation process. The Estimation Run column shows the name of the estimation run that is behind the forecast run:
Run Type Name
Each run is associated with a run type. This column shows the name of the run type.
Results
This column shows the link to different output screens. The Summary link opens a tab that provides information about the different stages of demand parameter estimation. This link is enabled for all Life Cycle runs for which the estimation process has completed successfully.
Create What-If Run
The menu on the left shows the different stages of estimation and forecasting. These stages can be different, depending on the forecast method that was selected for the run type.
You can set the scope of the run, the run name, and the description in the first tab. In the left side of the Scope tab, select Run Estimation Only to execute the end-to-end process for estimating demand parameters. Select Run Estimation and Base Demand to execute the end-to-end process for estimating demand parameters and generating base demand. Alternatively, you can select Run Base Demand Only and then select an estimation run from the list of previously completed estimation runs. If no such estimation run exists, this option will be disabled. If a completed estimation run is selected, then the historical data period section will be populated based on the estimation run and will be disabled. To also generate the forecast, turn on Run Forecast. Forecast generation for a price zone run type will always be disabled.
In the right side of the Scope screen, you can select the period of historical data that should be included in the estimation process. This part will not be enabled if the Run Base Demand Only option is selected. You can either select a period by specifying the start and end date or by specifying the number of weeks to be used from the latest historical data. In the Scope tab, you can also specify the time period for the forecast generation by selecting a start date for forecast period and a forecast horizon. You can also set the threshold used for auto-approving base demand. The base demand values that are less than this threshold times the average rate of historical sales are approved.
In the other tabs on the left menu, you can review and override the configuration parameters for each stage of the estimation and the base demand/forecast. To override a parameter, select the row in the table and click the Edit icon above the table. For the Elasticity, Seasonality, and Base Demand tabs, you can override the parameters at different levels of merchandise and location. This feature is applicable only for the Sales & Promo and the Life Cycle run types. The levels that are valid for the override depends on the stage (particular tab), that is, for elasticity and seasonality this is closely tied to escalation levels.
You can click the Add a parameter override button to override parameters at different levels of merchandise and location. The Active flag allows the user to not use an override temporarily without having to delete it, as shown below. Once the parameter is overridden at the selected intersection, you can add the override at multiple intersections by clicking Save and Add Another button. This override parameters table is shown below.
Figure 11-19 Override Parameters at the Intersection for Elasticity/Seasonality
Figure 11-20 Override Parameters Table
Figure 11-21 Override Parameters at the Intersection for Base Demand
In the Seasonality tab, in addition to the configuration parameters, you can also modify the escalation path by selecting or unselecting the merchandise-location intersections that will be used during escalation process.
Figure 11-22 Add a Parameter Override Button
Figure 11-23 Modify Escalation Path for Seasonality/Elasticity
Description of "Figure 11-23 Modify Escalation Path for Seasonality/Elasticity"
Duplicate Run
Select a row and click the Duplicate icon above the table to create a copy of an existing run. The run will be created in Setup status.
Delete Run
Select one or multiple rows and click the X icon above the table to delete a run or runs. If a run is in progress, it cannot be deleted. For each run selected to be deleted, you see three options: Cancel, Delete Forecast Run and Delete Forecast and Estimation Run. The Delete Forecast Run button deletes the forecast run. The Delete Forecast and Estimation Run button deletes the forecast run and in addition deletes the estimation run that is behind the forecast run. You can perform the Delete Forecast and Estimation Run only when there is no other forecast run tied with same estimation run. For the Automatic Exponential Smoothing run type, only the Delete Forecast and Estimation Run can be performed, as each forecast run is mapped with a different estimation run.
Approve Demand Parameters
Select a row and click the Approve Demand Parameters button above the table to approve the estimation runs. You can approve demand parameters only for the runs where the estimation is complete. You can approve another run to replace the previously approved run. Once a run is approved, the Estimation Run column in the below table displays Approved next to the estimation run name. Only one estimation run per run type can remain approved at any point in time. The demand parameters generated by the approved run will be used in weekly forecast batch runs.
Approve Base Demand and Forecast
Select a row and click the Approve Demand and Forecast button above the table to approve base demand and forecast runs. Approve Base Demand and Forecast operation can be performed for the runs that has an approved estimation run and are in base demand complete or forecast generation complete status. Once a run is approved, the Forecast Run Name column in the below table displays Approved besides the forecast run name. Multiple forecast runs per run type can remain approved.
Manage
In the Manage screen in train stop 3 you can set the value of configuration parameters for the run type. These values will be used when creating and executing batch runs for each run type. In this screen, you can also activate or inactivate run types by selecting a row and clicking the Activate button above the table. Active run types become part of the weekly batch process, and a new batch run is created and executed for each active run type. For each active run type, once the batch run is approved, the output of the batch run will be exported to and consumed by the applications that are mapped to that run type. In order to auto-approve the batch runs, select a row and click on Manage Auto-approve. For the Life Cycle run type, the start date calculation can be disabled or enabled by clicking the Disable Life Cycle Start Date Calculation or Enable Life Cycle Start Date Calculation button, respectively.
Set the values of all configuration parameters in that stage, based on the system default for the run type. To do this, select System Default from the drop-down menu and click Apply.
Set the values of all configuration parameters in that stage based on the values that were previously set in one of the what-if runs. To do this, select the desired run from the drop-down menu and click Apply.
Override the value of a certain configuration parameter. To do this, select a row and click the Edit icon above the table.
Promotion Effects
This section describes the process for estimating the promotion lifts and is a continuation from Promotion Management. As part of the Promotion Effects module within the Sales & Promo forecast method (this module is activated when the PROMOTIONAL_SALES_AVAIL parameter is set to Y in the RSE_CONFIG table in the Manage System Configurations screen), select the following.
- Select features for the promotion lift estimation model.
- Model settings.
Forecast Configuration — Promotion Features
The Promotion Feature Selection screen within the Promotion Effects tab shows the various features that are available to the user. These various features can be classified according to the following categories.
- Promotion related: Campaign Name, Offer Name, Campaign Description,
Offer Type, and Offer Description.
Campaign Name and Offer Name contain the campaign alias and offer alias values that are assigned through the Promotion Management module; these are always selected.
In addition to the alias values, one or more of the following features can be enabled if they are useful: Campaign Description, Offer Description, and Offer Type. Review the data to decide which of these features will be useful.
- Product Hierarchy: Promotion feature product hierarchy
Multiple levels of the product hierarchy can be selected as features to the model (for example, Class and Department). This allows the model to search for variations at each of the selected levels.
- Location Hierarchy: Promotion feature location hierarchy
Multiple levels of location hierarchy can be selected as features to the model (for example, Area and Region). This allows the model to search for variations at each of the selected levels.
- Product Attributes
Two attributes are supported. Select the relevant attributes that impact the promotion lift.
- Location Attributes
- Performance Metrics: % sales on promotion, % weeks on promotion
In addition to the hierarchy and attributes, products can behave differently. Some products might be highly promotional compared to others. These features can be used to capture the variation lifts observed for different types of products, as determined by each performance metric.
Figure 11-25 Feature Selection for Promotion Effects
For a given retailer, start with a small selection of features that you expect to have an impact on promotion lifts and add new features to see if the addition of the feature improves the model performance. The details for reviewing the model output are provided after the model settings.
Forecast Configuration — Promotion Model Settings
Algorithm: Available options are Decision Tree and Generalized Linear Models (GLM).
Minimum samples: Minimum number of data points for each leaf node of the decision tree. This is used to ensure there are enough data points for each node.
Maximum depth: Number of levels between the leaf node and the top of the decision tree. Start with a value between 4 and 6, depending on the number of features being used and increase the number gradually to see if the model performance improves.
Partition: The model can be partitioned, based on one or more of the features used for building the model. Selecting a partition builds a separate model for each value corresponding to the chosen partition. Multiple features can be selected to determine a partition. Partitioning by higher levels in the product hierarchy and the location hierarchy or based on relevant product/location attributes can help to determine the promotions lifts more accurately. Lower levels of product/location hierarchy may not have sufficient data to create reliable parameters.
Reliability metrics:
High percentile: A value of 0.9 removes the top 10 percent of the observed lift values for building the model. Adjust the setting to remove outlier values with very high lift.
Low percentile: A value of 0.1 remove the bottom 10 percent of the observed lift values for building the model. Adjust the setting to remove outlier values with very low lift.
Figure 11-26 Model Settings for Promotion Effects
- PMO_LLC_PL_MODEL table: Contains the details about the promotion model.
- RUN_HDR_ID: Estimation run id.
- CASE_TABLE, CASE_COLUMNS: Contains all the features available for the user to select.
- VIEW_NAME, VIEW_COLUMN_NAMES: Based on the user selection in the UI.
- Using IW, MODEL_NAME can be used to apply the model for a chosen time frame on the CASE_TABLE.
- Root Mean Squared Error (RMSE) and Mean Absolute Error (MAE): Error metrics for the promotion lift values.
- Average Error (AVG_ERROR), Median Error (MEDIAN_ERROR), and Weighted Error (ERROR_WGT): % Error metrics for the promotion lift values.
- ERROR_WGT: % Error weighted by sales units.
Figure 11-27 Promotion Effects Output Review in IW
Map
In the Map screen in train stop 4, you can map run types to applications. There can be many-to-many mappings between the run types and applications. For example, if IPO-DF requires a forecast for two different measures (for example, total gross sales units and total net sales units), which may or may not be at the same forecast intersection, there will be two run types and both must be mapped to IPO-DF. Also, if two different applications (for example, IPO-DF and IPO-IO) require a forecast for the same measure and at the same forecast intersection, then both the applications will be mapped to the same run type.
You can select more than one run type at a time to be mapped to an application except when the applications are IPO-DF and RI/RMS, as shown below.
You can assign an external application key to the run types in this screen. An external application run type key value can only be assigned to a run type when the selected application is IPO-DF. Two run types that have the exact same forecast intersection, forecast measure, and data source, but different forecast methods (Sales & Promo vs. Life Cycle) can have the same external application run type key.
Basically, for each external application run type key, there can be at most one Sales & Promo run type and at most one Life Cycle run type, and those two run types must have the same forecast intersection, forecast measure, and data source.
To create a new mapping, click on the + (plus) icon above the table in Map screen. Select an application and one or more run types (based on what the application allows) and click Save. To delete a mapping, select a row and click the X icon above the table.
Figure 11-28 Map Run Types to IPO-DF as a Single-Select Option
Figure 11-29 Map Run Types to IPO-IO as a Multi-Select Option
Manage Master Data
Figure 11-30 Manage Master Data
Figure 11-31 Sales Plans Tab
Figure 11-32 Flexible Groups Tab
Figure 11-33 Create Flexible Group Set
Figure 11-34 Partitions (Groups) under a Group Set
Figure 11-35 Escalation Levels Based on Group Set are Available
When a new What-If run is created from the Test screen under the corresponding run type, the run will also contain the additional escalation levels corresponding to the flex group set and will be displayed under the Available Values column in the Estimation Levels and Escalation Path section of the Seasonality tab.
Oracle Customer Engagement web service-related credentials are managed in the credential stores using the interface shown below. The administrator can use this screen to configure the name and password. This information is used to generate the authentication key that is sent as part of the message to Oracle Customer Engagement.
The Credential Stores dialog box requires the following information:
Label - describes the credential store map and key
Username - user name provided by Oracle Customer Engagement
Password - password provided by Oracle Customer Engagement
Confirm Password - prompt to confirm user password
Description - used by the administrator to describe the credential store used for Customer Segment integration with Oracle Customer Engagement.
For details about the screens of Attribute Extraction, refer to Attribute Extraction.
