Segment Criteria Stage
Use the Segment Criteria stage to view summary data about existing segments and define the characteristics of new segments.
Process
Here is the high-level process for defining a segment.
  1. Provide a unique name for the segment.
  2. Define the type of data used to characterize the segment.
  3. Select the merchandise and location nodes.
  4. Define the time period for the segment.
  5. Define the historical time period for the data.
