Run Batch Measure Export Group
This task exports a predefined set of measure data into flat files. The predefined set of measures to be exported are defined in the batch control file batch_exportmeas_list.txt. This set of exported data can be used for integration with other applications. Typically, the data exported can be interfaced to an external database that can be used to create reports or queries by users who need Planning data. The Administrator needs to schedule the Set Export Flags under the Run Batch Calc Group task to set the required export flags before scheduling this task. Exported files for this task are put into the Object Storage location; the Administrator can download the files from this location.
The standard exports from MFP are available to the retailer to use by any downstream applications which need MFP plan data. Default approved plan standard exports are included as part of the daily and weekly batch.
The predefined options for these tasks are listed below:
  • Merch Plan - Current Plan (mpcp)
  • Merch Plan - Original Plan (mpop)
  • Merch Plan - Submitted Plan (mpwa)
  • Merch Plan - Working Plan (mpwp)
  • Merch Target - Target Plan (mttg)
  • Merch Target - Working Plan (mtwp)
  • Location Plan - Current Plan (lpcp)
  • Location Plan - Original Plan (lpop)
  • Location Plan - Working Plan (lpwp)
  • Location Target - Target Plan (lttg)
  • Location Target - Working Plan (ltwp)
For details about the different versions for export, the list of measures exported in each file, and the file name and format details, see the Oracle Retail Merchandise Financial Planning Cloud Service Implementation Guide.
