Run Batch Measure Load Group
This task is used to load a predefined set of measures grouped as a measure set in the batch control file batch_loadmeas_list.txt. These set of measures can be loaded together. Actuals Data is a named set of load measures in the batch control file. If the Administrator decides to load the measure set for Actuals Data, the Administrator needs to load data for measures which includes measures such as Ty Sales Clr R and TY Sales Clr U. All required data files must be uploaded to Object Storage. If there is no file present to load a particular measure in that measure set, it will be logged as not found and skipped.
This process will only load the data into those measures and will not run any subsequent calculations. The Administrator may need to schedule the necessary Run Batch Calc Group task after scheduling this task in order to process the loaded data.
The Predefined Measure Load Options in MFP are listed below:
  • Actuals Data (load_act) - To load all the measures containing actual data as needed such as Sales, Inventory, Receipt, Shrink, and so on.
  • On Order Data (load_oo) - To load only On Order data files.
  • Admin Data (load_adm) - To load planning administration level data such as VAT %, Currency Conversion Rates, Week Mapping, and so on.
  • Forecast Data (load_fcst) - To load Forecast Data, if the customer is planning to load forecast data from external systems other than from AI Foundation in RAP integration.
  • Portfolio Opt Data (load_mpo) - To load Portfolio Optimization Data, if the customer is planning to load Portfolio Optimization data from external systems in file format.
For details about the list of measure files that are loaded for different measure sets and information on the data file formats, see the Oracle Retail Merchandise Financial Planning Cloud Service Implementation Guide.
