Foundation and Transactional Data from RMFCS using Retail Insights
RMFCS can send Foundation and Transactional data to RAP integration using Retail Insights (RI) and other systems within RAP. The systems can share the data, even if RMFCS is not implemented for the customer. The customer can upload the foundation and data files in the file format needed by RI in RAP integration. That way, the same data can be published to all applications within RAP. It can be done by scheduling required job flows in Retail Insights to get the foundation data from RMFCS and loading it into the staging tables present in Retail Data Exchange (RDX) from where the configured interfaces in MFP can pull the required data into Facts in Planning Data Schema (PDS) where MFP is deployed.
The customer can also load foundation data directly into RAP using the file format specified for RAP integration and using the same staging process in RI to write the data into RDX staging tables from where Planning can pull the data using standard configured interfaces. Only mapped columns specific to GA interfaces are detailed in this guide. For more details about interface file formats and the jobs flow details, see the Oracle Retail Analytics and Planning Implementation Guide. Also refer to those guides to find more information about the available columns in each interface staging tables in RDX sourced from RI so that customers using extensibility on template or using custom configuration (non-template) can pull the required data from RDX.
For information about the mappings between the columns in RDX interface table and RAP Inbound Data File columns, see the Data Mappings in the Transformations from RI to Planning section of the Oracle Retail Analytics and Planning Implementation Guide. The following sections shows the mappings between the RDX Interface table columns and the measures and dimensions in Planning.
The following table shows the list of interfaces in RAP to get the foundation and transactional data:
Interface Interface and Table Name Interface Type
Product Hierarchy
W_PDS_PRODUCT_D
Hierarchy Importer
Location Hierarchy
W_PDS_ORGANIZATION_D
Hierarchy Importer
Calendar Hierarchy
W_PDS_CALENDAR_D (VW_CLND_HIER)
Hierarchy Importer
Currency Hierarchy
VW_CURR_HIER (W_PDS_EXCH_RATE_D)
Hierarchy Importer
Sales Interface
W_PDS_SLS_IT_LC_WK_A
Data Importer
Inventory Interface
W_PDS_INV_IT_LC_WK_A
Data Importer
Markdown Interface
W_PDS_MKDN_IT_LC_WK_A
Data Importer
On Order Interface
W_PDS_PO_ONORD_IT_LC_WK_A
Data Importer
Receipts Interface
W_PDS_INVRC_IT_LC_WK_A
Data Importer
Inventory Adjustments
W_PDS_INVADJ_IT_LC_WK_A
Data Importer
Inventory Transfers
W_PDS_INVTSF_IT_LC_WK_A
Data Importer
Deal Incomes
W_PDS_DEALINC_IT_LC_WK_A
Data Importer
Wholesale/Franchise
W_PDS_SLSWF_IT_LC_WK_A
Data Importer
Currency Conversion Rates
W_PDS_EXCH_RATE_D (VW_CURR_RATE)
Data Importer
Location Data
VW_LOC_DATA
Data Importer
The following table shows the mapping of dimensions to columns for Hierarchy Importer interfaces from external interface tables:
Hierarchy Dimension External Interface Table External Mapped Column
prod
sku
W_PDS_PRODUCT_D
ITEM
prod
sku_label
W_PDS_PRODUCT_D
ITEM_DESC
prod skup
W_PDS_PRODUCT_D
ITEM_PARENT_DIFF
prod skup_label
W_PDS_PRODUCT_D
ITEM_PARENT_DIFF_DESC
prod skug
W_PDS_PRODUCT_D
ITEM_PARENT
prod skug_label
W_PDS_PRODUCT_D
ITEM_PARENT_DESC
prod
scls
W_PDS_PRODUCT_D
CLASS_ID
prod
scls_label
W_PDS_PRODUCT_D
DEPT
prod
clss
W_PDS_PRODUCT_D
GROUP_NO
prod
class_label
W_PDS_PRODUCT_D
DIVISION
prod
dept
W_PDS_PRODUCT_D
COMPANY
prod
dept_label
W_PDS_PRODUCT_D
CO_NAME
prod
pgrp
W_PDS_PRODUCT_D
GROUP_NO
prod
pgrp_label
W_PDS_PRODUCT_D
GROUP_NAME
prod
dvsn
W_PDS_PRODUCT_D
DIVISION
prod
dvsn_label
W_PDS_PRODUCT_D
DIV_NAME
prod
cmpp
W_PDS_PRODUCT_D
COMPANY
prod
cmpp_label
W_PDS_PRODUCT_D
CO_NAME
loc
stor
LOCATION
loc
stor_label
LOC_NAME
loc
dstr
DISTRICT
loc
dstr_label
DISTRICT_NAME
loc
regn
REGION
loc
regn_label
REGION_NAME
loc
chnl
AREA
loc
chnl_label
AREA_NAME
loc
chan
CHAIN
loc
chan_label
CHAIN_NAME
loc
comp
COMPANY
loc
comp_label
CO_NAME
loc
phwh
PHYSICAL_WH
loc
phwh_label
PHYSICAL_WH_NAME
loc
loct
LOC_TYPE
loc
loct_label
LOC_TYPE_NAME
loc
strc
LOCATION
loc
strc_label
LOC_NAME
loc
chnc
PLANNING_CHANNEL_ID
loc
chnc_label
PLANNING_CHANNEL_NAME
loc
ccty
PLANNING_COUNTRY_ID
loc
ccty_label
PLANNING_COUNTRY_NAME
clnd
day
W_PDS_CALENDAR_D
DAY
clnd
day_label
W_PDS_CALENDAR_D
DAY_LABEL
clnd
week
W_PDS_CALENDAR_D
WEEK
clnd
week_label
W_PDS_CALENDAR_D
WEEK_LABEL
clnd
mnth
W_PDS_CALENDAR_D
MNTH
clnd
mnth_label
W_PDS_CALENDAR_D
MNTH_LABEL
clnd
qrtr
W_PDS_CALENDAR_D
QRTR
clnd
qrtr_label
W_PDS_CALENDAR_D
QRTR_LABEL
clnd
half
W_PDS_CALENDAR_D
HALF
clnd
half_label
W_PDS_CALENDAR_D
HALF_LABEL
clnd
year
W_PDS_CALENDAR_D
YEAR
clnd
year_label
W_PDS_CALENDAR_D
YEAR_LABEL
clnd
woyr
W_PDS_CALENDAR_D
WOYR
clnd
woyr_label
W_PDS_CALENDAR_D
WOYR_LABEL
clnd
stdb
W_PDS_CALENDAR_D
STDB
curh
curc
VW_CURR_HIER
TO_CURRENCY_CODE
curh
curc_label
VW_CURR_HIER
TO_CURRENCY_CODE
satr satt VW_SATR_HIER ATTR_ID
satr satt_label VW_SATR_HIER ATTR_DESC
satr satv VW_SATR_HIER ATTR_VALUE
satr satv_label VW_SATR_HIER ATTR_VALUE_DESC
Note: For Calendar Hierarchy (clnd), RMFCS is not sending the labels. Internally, VW_CLND_HIER is defined in PDS against the interface W_PDS_CALENDAR_D table to derive the labels and also default the calendar import to PDS to have two past years, one current year, and two future years based on the current business date. The Administrator can update the same using the Online Administration Tool Tasks under System Admin Tasks -> List/Set/Unset PDS Integration variables and can update the CLND_PAST_YEARS and CLND_FUTURE_YEARS variables. By default, both are set to 2. The customer can also update the start fiscal month by setting the CLND_START_MONTH variable. By default, it is set to 2 to have the fiscal start month label be generated as February.
Note: For Currency Hierarchy (curh), there is no direct interface table. Internally, VW_CURR_HIER is defined in PDS against the interface W_PDS_EXCH_RATE_G table to get the unique currency codes. The base currency code is set by default as USD to get the conversion rates for other currencies. The Administrator can update the same using the Online Administration Tool Tasks under System Admin Tasks -> List/Set/Unset PDS Integration variables and can update the BASE_CURRENCY_CODE.
Note: For the Location Attribute Hierarchy (SATR), there is no direct interface table. Internally, VW_SATR_HIER is defined in PDS against the interface W_PDS_ORG_ATTR_STR_D table to get the distinct location attributes.
Note: The VAT Hierarchy (vath) in the MFP GA is not integrated using RAP integration. The customer needs to explicitly provide those files for the MFP GA.
The following table shows the mapping of fact names/measures names to columns for the Data Importer interfaces from the external interface tables in RDX:
Fact Name External Interface Table External Mapped Column External Mapping Condition
drtyeop1c
REGULAR_INVENTORY_COST
CLEAR_IND = 'N'
drtyeop1r
REGULAR_INVENTORY_RETAIL
CLEAR_IND = 'N'
drtyeop1u
REGULAR_INVENTORY_UNITS
CLEAR_IND = 'N'
drtyeop2c
CLEAR_IND = 'Y'
drtyeop2r
CLEAR_IND = 'Y'
drtyeop2u
CLEAR_IND = 'Y'
drtyrinva1c
SHRINK_COST
drtyrinva1r
SHRINK_RETAIL
drtyrinva1u
SHRINK_UNITS
drtyrinva2c
NON_SHRINK_ADJ_COST
drtyrinva2r
NON_SHRINK_ADJ_RETAIL
drtyrinva2u
NON_SHRINK_ADJ_UNITS
drtymkdcanr
MARKDOWN_CANCEL
drtymkdclrr
CLEAR_MARKDOWN_RETAIL
drtymkdpclr
PROMO_MARKDOWN_RETAIL_CLEAR
drtymkdpror
PROMO_MARKDOWN_RETAIL_REG
drtymkdregr
REG_MARKDOWN_RETAIL
drtymkupr
MARKUP
drtyicmkur
INTERCOMPANY_MARKUP
drtyicmkdr
INTERCOMPANY_MARKDOWN
drtywfmkdr
WF_MARKDOWN_RETAIL
drtywfmkur
WF_MARKUP_RETAIL
drtywfslsu
FRANCHISE_SALES_UNITS
drtywfslsc
FRANCHISE_SALES_COST
drtywfslsr
FRANCHISE_SALES_RETAIL
drtywfrtnu
FRANCHISE_RETURNS_UNITS
drtywfrtnc
FRANCHISE_RETURNS_COST
drtywfrtnr
FRANCHISE_RETURNS_RETAIL
drtynslsclrc
NET_SALES_CLR_COST
drtynslsclrr
NET_SALES_CLR_RETAIL
drtynslsclru
NET_SALES_CLR_UNITS
drtynslsproc
NET_SALES_PRO_COST
drtynslspror
NET_SALES_PRO_RETAIL
drtynslsprou
NET_SALES_PRO_UNITS
drtynslsregc
NET_SALES_REG_COST
drtynslsregr
NET_SALES_REG_RETAIL
drtynslsregu
NET_SALES_REG_UNITS
drtyrtnclrc
RETURNS_CLR_COST
drtyrtnclrr
RETURNS_CLR_RETAIL
drtyrtnclru
RETURNS_CLR_UNITS
drtyrtnproc
RETURNS_PRO_COST
drtyrtnpror
RETURNS_PRO_RETAIL
drtyrtnprou
RETURNS_PRO_UNITS
drtyrtnregc
RETURNS_REG_COST
drtyrtnregr
RETURNS_REG_RETAIL
drtyrtnregu
RETURNS_REG_UNITS
drtyooc
ON_ORDER_COST
drtyoor
ON_ORDER_RETAIL
drtyoou
ON_ORDER_UNITS
drtyporcptc
PO_RECEIPT_COST
drtyporcptr
PO_RECEIPT_RETAIL
drtyporcptu
PO_RECEIPT_UNITS
drtytraninbc
TSF_IN_COST
TSF_TYPE = 'B'
drtytraninbr
TSF_IN_RETAIL
TSF_TYPE = 'B'
drtytraninbu
TSF_IN_UNITS
TSF_TYPE = 'B'
drtytraninic
TSF_IN_COST
TSF_TYPE = 'I'
drtytraninir
TSF_IN_RETAIL
TSF_TYPE = 'I'
drtytraniniu
TSF_IN_UNITS
TSF_TYPE = 'I'
drtytraninr
TSF_IN_RETAIL
TSF_TYPE = 'N'
drtytraninc
TSF_IN_COST
TSF_TYPE = 'N'
drtytraninu
TSF_IN_UNITS
TSF_TYPE = 'N'
drtytranoutbc
TSF_OUT_COST
TSF_TYPE = 'B'
drtytranoutbr
TSF_OUT_RETAIL
TSF_TYPE = 'B'
drtytranoutbu
TSF_OUT_UNITS
TSF_TYPE = 'B'
drtytranoutic
TSF_OUT_COST
TSF_TYPE = 'I'
drtytranoutir
TSF_OUT_RETAIL
TSF_TYPE = 'I'
drtytranoutiu
TSF_OUT_UNITS
TSF_TYPE = 'I'
drtytranoutr
TSF_OUT_RETAIL
TSF_TYPE = 'N'
drtytranoutu
TSF_OUT_UNITS
TSF_TYPE = 'N'
drtytranoutc
TSF_OUT_COST
TSF_TYPE = 'N'
drtyvndfndr
DEAL_INCOME_SALES
addvlocopnd
VW_LOC_DATA
STORE_OPEN_DATE
addvlocendd
VW_LOC_DATA
STORE_CLOSE_DATE
addvlocrefd
VW_LOC_DATA
REMODEL_DATE
addvwfpoct
VW_LOC_DATA
STORE_TYPE
drtylcratex
W_PDS_EXCH_RATE_G
EXCHANGE_RATE
addvlocatt W_PDS_ORG_ATTR_STR_D ATTR_VALUE
Note: For Location specific data, the same W_PDS_ORGANIZATION_D hierarchy table used for the location hierarchy is used. The view VW_LOC_DATA is defined in PDS to point to the same set of data and used as data importer interface.
Note: Pack Items are filtered by default for MFP during the product hierarchy import from RAP using the Pack Item Filter Value measure set to N. This shared filter measure, PCKFLGVAL, can be managed in the Planning Admin workbook. In a multi-app scenario, if other applications need to bring in pack items, this can be changed to % to bring in both pack items and non-pack items.
