Plan Exports to Retail Insights
Approved plans from MFPCS can be exported to Retail Insights within RAP integration. Retail Insights allows getting four levels of plans for different versions. The MFP template version allows creating four levels of plans, Merch Plan (OP, CP), Merch Target (TG), Location Plan (OP, CP), and Location Target Plan (TG). All those plans and their different versions can be exported to Retail Insights on a weekly basis. Since MFP non-template versions can create a different level of plans and also can configure various metrics, the interface staging table in Retail Sights contains the same set of columns and various flex columns.
For more details about the list of columns available in the Retail Insights Interface Staging table if the customer plans to use extensibility or use the non-template version to send additional data, see the Oracle Retail Insights Implementation Guide. This guide contains only the mapped columns for the MFP template version for each level of plans.
The following table shows the list of interfaces in RAP to export the plan data from MFP to RI:
| Interface | Interface and Table Name | Interface Type |
Merch Plan Export |
MFP_PLAN1_EXP |
Data Explorer |
Merch Target Plan Export |
MFP_PLAN2_EXP |
Data Explorer |
Location Plan Export |
MFP_PLAN3_EXP |
Data Explorer |
Location Target Plan Export |
MFP_PLAN4_EXP |
Data Explorer |
Note: If Retail/Cost is denoted, that metric will have value only if that version of MFP is implemented from the template, otherwise that value will be always exported as zero.
