Forecast Imports from AI Foundation
Forecasts can be generated from AI Foundation (AIF) and imported to MFPCS using RAP integration. AI Foundation can generate different levels of forecasts as needed by different levels of plans. It generates both Pre-Season forecasts (using the Auto-ES Forecast method) and In-Season Forecasts (using the Bayesian Forecast Method). AI Foundation directly gets the actuals and plan data from MFP through RI using RAP integration. Job flows in AI Foundation need to be scheduled to generate the forecast and import the same to MFP. For more details, see the Oracle Retail Analytics and Planning Implementation Guide.
In order to get forecasts from AI Foundation (AIF), during implementation, some initial setups need to be done in the AI Foundation (AIF) platform.
The AIF default location hierarchy does not include MFP Channel and MFP Country, so the alternate Location Hierarchy needs to be set up in AIF and also needs to be mapped and imported with data in order to create the forecast at the required levels. For more details, see the Oracle Retail Analytics and Planning Implementation Guide.
Mapping
The following table shows the interface table column details from AI Foundation in RDX used for the interface.
Interface Name: RSE_FCST_DEMAND_EXP
Table Column Data Type Comments
RUN_ID
Number(10)
The export Run ID as obtained from the RAP_INTF_UTIL.
CAL_HIER_LEVEL
Varchar2(30)
The calendar level data is for Fiscal Year, Fiscal Quarter, Fiscal Period, Fiscal Week, and Fiscal Day.
LOC_HIER_LEVEL
Varchar2(30)
The location hierarchy level data is for COMPANY, CHAIN, AREA, REGION, DISTRICT, LOCATION, and CHANNEL_COUNTRY.
PROD_HIER_LEVEL
Varchar2(30)
The product hierarchy level the data is for CMP, DIV, GRP, DEPT, CLS, SBC, STYLE, STYLE_COLOR, and SKU.
FCST_DATE_FROM
Date
The start date which the forecast is for.
LOC_EXT_KEY
Varchar2(80)
The external id of the location. It will use the integration ids as provided to RI (preferably the RMS id, and not an integration id such as AREA~123).
PROD_EXT_KEY
Varchar2(80)
The external id of the product hierarchy. It will use the integration ids as provided to RI (preferably the RMS id, and not an integration id such as CLS~123~456~789).
CUSTSEG_EXT_KEY
Varchar2(80)
The external id of the customer segment. It will be NULL if not applicable.
FCST_TYPE
Varchar2(20)
The type of forecast. PI, NPI (PI=Plan Influenced, PI = Non Plan Influenced)
REG_SLS_QTY
Number(38,20)
Regular Sales Units
REG_SLS_AMT
Number(38,20)
Regular Sales Amount
PR_SLS_QTY
Number(38,20)
Promo Sales Units
PR_SLS_AMT
Number(38,20)
Promo Sales Amount
CLR_SLS_QTY
Number(38,20)
Clearance Sales Units
CLR_SLS_AMT
Number(38,20)
Clearance Sales Amount
REG_PR_SLS_QTY
Number(38,20)
Regular and Promo Sales Units
REG_PR_SLS_AMT
Number(38,20)
Regular and Promo Sales Amount
SLS_QTY
Number(38,20)
Total Sales Units
SLS_AMT
Number(38,20)
Total Sales Amount
RET_QTY
Number(38,20)
Return Units
RET_AMT
Number(38,20)
Return Amount
The same Interface table contains the forecast data for different levels of plans differentiated by _LEVEL columns within the interface. The single interface run pulls data for different levels of forecasts which are pre-configured. Customers using non-template versions, if using different levels of plans, can use the supported levels in AI Foundation to generate forecasts. The following sections provide the default levels of forecasts exported for the MFPCS template version and their mappings.
Merch Plan Forecasts Mapping
The following table shows the mapping for pre-season and in-season Merch Plan Forecasts.
Table Column Mapping for Pre-Season (MPP) Mapping for In-Season (MPI)
CAL_HIER_LEVEL
Fiscal Week
Fiscal Week
LOC_HIER_LEVEL
CHANNEL_COUNTRY
CHANNEL_COUNTRY
PROD_HIER_LEVEL
SBC
SBC
FCST_DATE_FROM
WEEK
WEEK
LOC_EXT_KEY
CHNL
CHNL
PROD_EXT_KEY
SCLS
SCLS
CUSTSEG_EXT_KEY
NULL
NULL
FCST_TYPE
NPI
PI
CLR_SLS_QTY
MPWPDmdP2U
MPWPDmdI2U
CLR_SLS_AMT
MPWPDmdP2R
MPWPDmdI2R
REG_PR_SLS_QTY
MPWPDmdP1U
MPWPDmdI1U
REG_PR_SLS_AMT
MPWPDmdP1R
MPWPDmdI1R
RET_QTY
MPWPRtnPU
MPWPRtnIU
RET_AMT
MPWPRtnPR
MPWPRtnIR
Merch Target Plan Forecasts Mapping
The following table shows the mapping for pre-season and in-season Merch Target Plan Forecasts.
Table Column Mapping for Pre-Season (MTP) Mapping for In-Season (MTI)
CAL_HIER_LEVEL
Fiscal Week
Fiscal Week
LOC_HIER_LEVEL
CHANNEL_COUNTRY
CHANNEL_COUNTRY
PROD_HIER_LEVEL
DEPT
DEPT
FCST_DATE_FROM
WEEK
WEEK
LOC_EXT_KEY
CHNL
CHNL
PROD_EXT_KEY
DEPT
DEPT
CUSTSEG_EXT_KEY
NULL
NULL
FCST_TYPE
NPI
PI
CLR_SLS_QTY
MTWPDmdP2U
MTWPDmdI2U
CLR_SLS_AMT
MTWPDmdP2R
MTWPDmdI2R
REG_PR_SLS_QTY
MTWPDmdP1U
MTWPDmdI1U
REG_PR_SLS_AMT
MTWPDmdP1R
MTWPDmdI1R
RET_QTY
MTWPRtnPU
MTWPRtnIU
RET_AMT
MTWPRtnPR
MTWPRtnIR
Location Plan Forecasts Mapping
The following table shows the mapping for pre-season and in-season Location Plan Forecasts.
Table Column Mapping for Pre-Season (LPP) Mapping for In-Season (LPI)
CAL_HIER_LEVEL
Fiscal Week
Fiscal Week
LOC_HIER_LEVEL
LOCATION
LOCATION
PROD_HIER_LEVEL
DEPT
DEPT
FCST_DATE_FROM
WEEK
WEEK
LOC_EXT_KEY
STOR
STOR
PROD_EXT_KEY
DEPT
DEPT
CUSTSEG_EXT_KEY
NULL
NULL
FCST_TYPE
NPI
PI
SLS_QTY
LPWPDmdP1U
LPWPDmdI1U
SLS_AMT
LPWPDmdP1R
LPWPDmdI1R
RET_QTY
LPWPRtnPU
LPWPRtnIU
RET_AMT
LPWPRtnPR
LPWPRtnIR
Location Target Plan Forecasts Mapping
The following table shows the mapping for pre-season and in-season Location Target Plan Forecasts.
Table Column Mapping for Pre-Season (LTP) Mapping for In-Season (LTI)
CAL_HIER_LEVEL
Fiscal Week
Fiscal Week
LOC_HIER_LEVEL
LOCATION
LOCATION
PROD_HIER_LEVEL
CMP
CMP
FCST_DATE_FROM
WEEK
WEEK
LOC_EXT_KEY
STOR
STOR
PROD_EXT_KEY
CMPP
CMPP
CUSTSEG_EXT_KEY
NULL
NULL
FCST_TYPE
NPI
PI
SLS_QTY
LTWPDmdP1U
LTWPDmdI1U
SLS_AMT
LTWPDmdP1R
LTWPDmdI1R
RET_QTY
LTWPRtnPU
LTWPRtnIU
RET_AMT
LTWPRtnPR
LTWPRtnIR
