Plan Level 6 MFP_PLAN6_EXP - LPO Export
This plan export is for LPO Integration of Markdown Budgets. This is an optional export only available if LPO Integration is enabled. This process exports the Permanent Markdown data for the current week after aggregating it for the number of weeks set up in the LPO Aggregate Weeks at the Sub-Class/Store level.
| Staging Table Column | Description | MFP Dimension/Measure Mapping | Retail/Cost |
PROD_KEY |
Product Dimension |
SLCS |
LOC_KEY |
Location Dimension |
STOR |
CLND_KEY |
Calendar Dimension |
WEEK |
PROD_DH_ATTR |
Attribute Dimension for RI |
-1 |
SUPPLIER_NUM |
Supplier Dimension for RI |
-1 |
CAL_DATE |
Last Day of Week |
MLCPLDOWD |
VERSION_NUM |
Version Number |
1 |
| PROD_LEVEL | Product Level | SBC | |
LOC_LEVEL |
Location Level |
LOCATION |
MKDNPM_RTL_AMT |
Cp Markdown Perm R |
MLCPInvDVR |
| FLEX1_NUM_VALUE | LPO Aggregate Weeks | ADHDLPOSprl |
