4 Set User Preferences
The Preferences pages are where you specify the default regional, language, and accessibility settings that you want to use throughout the system.
To set your preferred preferences, click User list > Preferences at the top of the application home page. The Preferences page appears. The standard preference options available are as follows:
Regional
Language
Accessibility
To return to the application home page, click Back to Home at the top of the page. The Preferences pages are where you specify the default regional, language, and accessibility settings that you want to use throughout the system.
Regional Options
Use the following options to specify the default formats for territory, date, time, number, and time zone you want to use throughout the system.
Table 4-1 Regional Options
Value | Description |
Territory |
Specify the country details. |
Date Format |
Select the date format that you want to use. |
Time Format |
Select the time format that you want to use. |
Number Format |
Select the number format that you want to use. |
Time Zone |
Select the time zone you want to use. |
Language Options
Use the following options to specify the default language you want to use throughout the system.
Table 4-2 Language Options
Default |
Specify the default language you want to use. |
Current Session |
Specify the language you want to use for the current session. |
Accessibility Options
Use the following options to specify the default accessibility preferences you want to use throughout the system.
Table 4-3 Accessibility Options
Accessibility |
Select the accessibility option you want to apply. |
Color Contrast |
Specify the color contrast that you want to use. |
Font Size |
Specify the font size that you want to use. |
