Architecture Overview
In prior releases, the integration between RMFCS and RI/AIF used a tool named the Retail Data Extractor (RDE) to generate data files for RI/AIF to consume. These programs have been fully integrated to the RAP batch flow and directly insert the data from RMFCS to RAP. The integration uses an instance of Oracle Golden Gate to copy RMFCS tables to the local database, where the Data Extractor jobs can source all required data and transform it for use in RAP. If you are familiar with the prior RDE architecture, then you need to be aware of the following major changes:
RDE_DM01database objects are now located in theRADM01schema.RDE_RMS01database objects are now in theRABE01USERschema. TheRABE01USERnow has access to extract records from RMFCS through the Golden Gate replicated schema. -
The
C_ODI_PARAMconfiguration tables have been merged and all RDE configurations are accessed from the Control & Tactical Center. -
File-based integration has been removed. All data is moved directly between database source and target tables with no option to produce flat files.
RDE’s batch schedule has been merged with RI’s schedule in POM. Jobs have been renamed and assigned modules such that it is easy to identify and disable/enable RDE jobs as needed.
Customer Engagement (CE) integration jobs have been included in RDE for when CE is set up to replicate data to RAP. File-based integration is no longer required.
All jobs relating to file extraction, ZIP file creation, or data cleanup in RMS have been removed.
Because RDE jobs are now a part of the RAP nightly batch cycle, they have been assigned modules in the Customer Modules framework (accessed using Retail Home) and can be enabled or disabled in bulk depending on your use-cases.
RDE_RMS– These are the RDE components in relation to RMS -
RDE_CE– These are the RDE components in relation to CE
If you are not integrating data from RMFCS or CE then you will need to disable these modules to prevent them from running in your nightly batch cycles. RI and AIF jobs are programmed to start automatically after the RDE jobs complete, but if the RDE jobs are disabled then the dependencies will be ignored.
