Merchandising Foundation Cloud Service Data Mapping
After Golden Gate makes the copy of all data residing in the source Merchandising Foundation Cloud Service (MFCS) environment, there is a mapping layer that connects the replicated database schema to Retail Data Extractor (RDE) programs. This mapping layer consists of two parts:
The replicated schema contains wrapper view (WV) objects on top of the cloned tables to provide a layer of abstraction between the source and destination. If the underlying table changes in the source it does not necessarily have to impact the target systems, since the view could remain unchanged. For example, the source table
ITEM_MASTERhas a wrapper viewRDS_WV_ITEM_MASTERon top of it. -
Within the target RAP database, synonyms are created to map each wrapper view back to its source system name. The synonyms are what are granted to RDE and Innovation Workbench. For example, there is a synonym named
ITEM_MASTERwhich is used by RDE to extract data from theRDS_WV_ITEM_MASTERview. TheITEM_MASTERsynonym can also be directly queried from Innovation Workbench instead of trying to query the original wrapper view object. The synonyms reside in theRABE01USERuser in the database.
This architecture is used for almost all objects from MFCS, with the following exceptions:
The synonym for
ITEM_LOC_SOHpoints to the MFCS tableITEM_LOC_SOH_EOD, which is the end-of-day inventory snapshot. This is required for RAP to ensure it receives the same end-of-day inventory positions that MFCS and other applications will show. TheITEM_LOC_SOHtable itself is not used in RAP integrations at this time due to the constantly changing data from 24/7 inventory program activity. -
The synonym for
MV_CURRENCY_CONVERSION_RATESrefers toV_CURRENCY_CONVERSION_RATES. This is becauseMV_CURRENCY_CONVERSION_RATEScannot be replicated to a Golden Gate schema, so MFCS created theV_CURRENCY_CONVERSION_RATESview as a replacement. -
RAP uses the
RMS_CALENDARsynonym to refer to theCALENDARtable. This is because RI also has aCALENDARtable in its schema and the object names would have conflicted within RDE.
