Batch Control Samples
The following sections show samples of the batch control processes.
batch_exec_list.txt
# Load a custom hierarchy, measure before weekly
batch hook_batch_weekly_pre |hierload |suph~0~N
hook_batch_weekly_pre |measload |c_load_vndr
# Run Batch calc and new custom exports after end of weekly batch
hook_batch_weekly_post |calc |c_calc_vndr
hook_batch_weekly_post |exportmeasure |c_exp_vndrbatch_calc_list.txt
# Run newly added custom calc rule group in
batch c_calc_vndr | G | GROUP | c_batch_agg_vndrbatch_loadmeas.txt
# Load custom measure
c_load_vndr | M |c_drtyvndrfndrbatch_exportmeas.txt
# Export custom measure
c_exp_vndr|O|vendo_plan.csv.dat
c_exp_vndr|X|storsclsweek
c_exp_vndr|F|c_exportmask
c_exp_vndr|M|c_mpcpvndrplanBelow sections describes Batch Control details that are specific to AP:
The following table describes the Custom Hooks available in the batch process.
Table 9-8 Custom Hooks in the Batch Process
| Hook | Description |
                                  hook_postbuild_pre  |
                                  This hook is added at the beginning of the postbuild batch which runs after the initial domain build.  |
                                  hook_postbuild_post  |
                                  This hook is added at the end of the postbuild batch which runs after the initial domain build.  |
                                  hook_postpatch  |
                                  This hook is added at the end of the service patch process which runs after the service patch.  |
                                  hook_batch_daily_pre  |
                                  This hook is added before the daily batch process.  |
                                  hook_batch_daily_post  |
                                  This hook is added at the end of daily batch process before the dashboard build.  |
                                  This hook is added before the weekly batch process.  |
                                  This hook is added at the end of the weekly batch process before the workbook refresh and segment build.  |
If the customer is using the JOS/POM flow schedule to schedule jobs in AP, then the following hooks can be used.
The AP JOS/POM job flow is connected to use the same set names similar to the hooks shown in the following table without hook_* in it and in turn calls each of the corresponding hooks. So the customer can easily customize their AP batch
flow based on their needs by simply changing the hooks or adding additional steps to the existing pre-configured hooks.
The naming convention followed is:
_RDXthat is used for any integration step using RDX. -
_OBSis used for any steps using Object Storage. -
_Dis for jobs that runs daily. -
_Wis for jobs that runs weekly.
Table 9-9 Custom Hooks in the Batch Process
                                  hook_AP_PRE_EXP_RDX_D  |
                                  This hook is for the calling steps using the Daily Export Interfaces to RDX as soon as the batch starts.  |
                                  hook_AP_PRE_EXP_OBS_D  |
                                  This hook is for the calling steps using the Daily Export Interfaces to Object Storage as soon as the batch starts.  |
                                  hook_AP_PRE_EXP_RDX_W  |
                                  This hook is for calling steps using the Weekly Export Interfaces to RDX as soon as the batch starts.  |
                                  hook_AP_PRE_EXP_OBS_W  |
                                  This hook is for the calling steps using the Weekly Export Interfaces to Object Storage as soon as the batch starts.  |
                                  hook_AP_COM_HIER_IMP_RDX_D  |
                                  This hook is for the calling steps using any Daily Import of common hierarchies from RDX.  |
                                  hook_AP_COM_HIER_IMP_OBS_D  |
                                  This hook is for the calling steps using any Daily Import of common hierarchies from Object Storage.  |
                                  hook_AP_COM_HIER_IMP_RDX_W  |
                                  This hook is for the calling steps using any Weekly Import of common hierarchies from RDX.  |
                                  hook_AP_COM_HIER_IMP_OBS_W  |
                                  This hook is for the calling steps using any Weekly Import of common hierarchies from Object Storage.  |
                                  hook_AP_COM_DATA_IMP_RDX_D  |
                                  This hook is for the calling steps using any Daily Import of common data interfaces from RDX.  |
                                  hook_AP_COM_DATA_IMP_OBS_D  |
                                  This hook is for the calling steps using any Daily Import of common data interfaces from Object Storage.  |
                                  hook_AP_COM_DATA_IMP_RDX_W  |
                                  This hook is for the calling steps using any Weekly Import of common data interfaces from RDX.  |
                                  hook_AP_COM_DATA_IMP_OBS_W  |
                                  This hook is for the calling steps using any Weekly Import of common data interfaces from Object Storage.  |
                                  hook_AP_HIER_IMP_RDX_D  |
                                  This hook is for the calling steps using any Daily Import of application-specific hierarchies from RDX.  |
                                  hook_AP_HIER_IMP_OBS_D  |
                                  This hook is for the calling steps using any Daily Import of application-specific hierarchies from Object Storage.  |
                                  hook_AP_HIER_IMP_RDX_W  |
                                  This hook is for the calling steps using any Weekly Import of application-specific hierarchies from RDX.  |
                                  hook_AP_HIER_IMP_OBS_W  |
                                  This hook is for the calling steps using any Weekly Import of application-specific hierarchies from Object Storage.  |
                                  hook_AP_PRE_DATA_IMP_RDX_D  |
                                  This hook is for the calling steps using any Daily Import of application-specific data interfaces from RDX.  |
                                  hook_AP_PRE_DATA_IMP_OBS_D  |
                                  This hook is for the calling steps using any Daily Import of application-specific data interfaces from Object Storage.  |
                                  hook_AP_PRE_DATA_IMP_RDX_W  |
                                  This hook is for the calling steps using any Weekly Import of application-specific data interfaces from RDX.  |
                                  hook_AP_PRE_DATA_IMP_OBS_W  |
                                  This hook is for the calling steps using any Weekly Import of application-specific data interfaces from Object Storage.  |
                                  hook_AP_BATCH_AGG_D  |
                                  This hook is for the calling steps doing any regular daily batch aggregation after hierarchy and data loads.  |
                                  hook_AP_BATCH_AGG_W  |
                                  This hook is for the calling steps doing any regular weekly batch aggregation after hierarchy and data loads.  |
                                  hook_AP_POST_DATA_IMP_RDX_D  |
                                  This hook is for the calling steps using any Daily Import of application-specific data interfaces from RDX after the calc steps.  |
                                  hook_AP_POST_DATA_IMP_OBS_D  |
                                  This hook is for the calling steps using any Daily Import of application-specific data interfaces from Object Storage after the calc steps.  |
                                  hook_AP_POST_DATA_IMP_RDX_W  |
                                  This hook is for the calling steps using any Weekly Import of application-specific data interfaces from RDX after the calc steps.  |
                                  hook_AP_POST_DATA_IMP_OBS_W  |
                                  This hook is for the calling steps using any Weekly Import of application-specific data interfaces from Object Storage after the calc steps.  |
                                  hook_AP_POST_EXP_RDX_D  |
                                  This hook is for the calling steps using any Daily Exports to RDX after the batch aggs.  |
                                  hook_AP_POST_EXP_OBS_D  |
                                  This hook is for the calling steps using any Daily Exports to Object Storage after the batch aggs.  |
                                  hook_AP_POST_EXP_RDX_W  |
                                  This hook is for the calling steps using any Weekly Exports to RDX after the batch aggs.  |
                                  hook_AP_POST_EXP_OBS_W  |
                                  This hook is for the calling steps using any Weekly Exports to Object Storage after the batch aggs.  |
                                  hook_AP_WB_BUILD_D  |
                                  This hook is for the calling steps specific to workbook refresh or build in the daily cycle.  |
                                  hook_AP_WB_BUILD_W  |
                                  This hook is for the calling steps specific to workbook refresh or build in the weekly cycle.  |
