Boolean Scalar Measures for Flow Control
The following table describes the Boolean Scalar measures.
Table 9-10 Boolean Scalar Measures
| Boolean Scalar Measure | Description |
drdvrmsb |
This measure is defaulted to true. Set it to true if AP is integrated with RMF CS. |
drdvexpdb |
This measure is defaulted to true. If set to false, it will skip exporting the standard exports in the daily batch. |
drdvexpwb |
This measure is defaulted to true. If set to false, it will skip exporting the standard exports in the weekly batch. |
