Customer Segment Mapping
The customer segment data is loaded from the W_RTL_CUSTSEG_DS.dat file or from AI Foundation exports of
the segment data back into the data warehouse table W_RTL_CUSTSEG_D. The data is exported to PDS for use
in Assortment Planning, which has the ability to select a customer segment to use for AIF integrations like Demand Transference
results.
| Measure | Target Table | Target Column | Data Source |
Segment ID |
W_PDS_CUSTSEG_D |
CUSTSEG_ID |
W_RTL_CUSTSEG_D.CUSTSEG_ID |
Segment Name |
W_PDS_CUSTSEG_D |
CUSTSEG_NAME |
NVL(W_RTL_CUSTSEG_D.CUSTSEG_NAME,'UNKNOWN SEGMENT') |
Segment Desc |
W_PDS_CUSTSEG_D |
CUSTSEG_DESC |
W_RTL_CUSTSEG_D.CUSTSEG_DESC |
Segment Type |
W_PDS_CUSTSEG_D |
CUSTSEG_TYPE |
W_RTL_CUSTSEG_D.CUSTSEG_TYPE |
Segment Source Type |
W_PDS_CUSTSEG_D |
CUSTSEG_SRC_TYPE |
W_RTL_CUSTSEG_D.CUSTSEG_SRC_TYPE |
Segment Organization Hierarchy Key |
W_PDS_CUSTSEG_D |
ORG_HIER_KEY |
W_RTL_CUSTSEG_D.ORG_HIER_KEY |
