Supplier Mapping
The supplier data is loaded from the PRODUCT.csv file or from RMFCS. The product data load programs will
insert the supplier information into the additional tables used below (as long as these tables are enabled during foundation
loads).
| Measure | Target Table | Target Column | Data Source |
Supplier ID |
W_PDS_SUPPLIER_D |
SUPPLIER |
W_PARTY_ORG_D .SUPPLIER_NUM |
Supplier Desc |
W_PDS_SUPPLIER_D |
SUP_NAME |
W_PARTY_ORG_D .ORG_NAME |
