Delivering Scheduled Reports through Object Storage
If the report is not using a bursting definition then, while adding the destination for the reports delivery when you schedule a report job, you will need the following set of inputs that are required to push the file to object storage.
- Server – The server is preconfigured as OS for any tenant. OS must always be selected.
- Prefix – The prefix under the object storage bucket where the file will be uploaded.
- File Name – The file name with which the scheduled report output will be delivered to the object storage.
The way you set up these inputs is the same as when using the bursting option. For additional details on how to set up reports delivery through object storage, refer to Set Output Options in Oracle Cloud Visualizing Data and Building Reports in Oracle Analytics Cloud.
