Limitations
Boolean arguments must be recast as character types, the PL/SQL function or procedure should declare them as a CHAR type. RPASCE will set the char to T for true and F for false. On the expression
side it is handled similarly to how boolean types are handled by an RPASCE expression. Pass a scalar boolean measure or boolean
constant (true or false) to the execplsql special expression.
