AI Foundation Setup
To see the additional hierarchy level in AI Foundation applications, you must create an alternate product hierarchy that includes both the new level and all other levels from your product hierarchy that you wish to use.
The first step in defining the alternate product hierarchy in AIF is setting up the configuration tables RSE_ALT_HIER_TYPE_STG and RSE_ALT_HIER_LEVEL_STG. These tables are updated from the Manage System Configurations screen in the
Control & Tactical Center. For this example, the data you create may look like the following:
Table 9-11 RSE_ALT_HIER_LEVEL_STG Sample
| HIER_TYPE_NAME | HIER_LEVEL_ID | DESCR | ID_SRC_COLUMN_NAME | ID_SRC_OBJ_NAME | NAME_SRC_COLUMN_NAME | NAME_SRC_OBJ_NAME | UI_DESCR |
                               PROD_SUBCAT  |
                               1  |
                               CMP  |
                               TOP_PRODCAT_ID  |
                               W_PRODUCT_DTS  |
                               TOP_PRODCAT_DESC  |
                               W_PRODUCT_DTS  |
                               Company  |
                               PROD_SUBCAT  |
                               2  |
                               DIV  |
                               LVL8_PRODCAT_ID  |
                               W_PRODUCT_DTS  |
                               LVL8_PRODCAT_DESC  |
                               W_PRODUCT_DTS  |
                               Division  |
                               PROD_SUBCAT  |
                               3  |
                               GRP  |
                               LVL7_PRODCAT_ID  |
                               W_PRODUCT_DTS  |
                               LVL7_PRODCAT_DESC  |
                               W_PRODUCT_DTS  |
                               Group  |
                               PROD_SUBCAT  |
                               4  |
                               DEPT  |
                               LVL6_PRODCAT_ID  |
                               W_PRODUCT_DTS  |
                               LVL6_PRODCAT_DESC  |
                               W_PRODUCT_DTS  |
                               Department  |
                               PROD_SUBCAT  |
                               5  |
                               SUBCAT  |
                               FLEX1_CHAR_VALUE  |
                               W_PRODUCT_ALT_DTS  |
                               FLEX2_CHAR_VALUE  |
                               W_PRODUCT_ALT_DTS  |
                               Sub Category  |
                               PROD_SUBCAT  |
                               6  |
                               CLS  |
                               LVL5_PRODCAT_ID  |
                               W_PRODUCT_DTS  |
                               LVL5_PRODCAT_DESC  |
                               W_PRODUCT_DTS  |
                               Class  |
                               PROD_SUBCAT  |
                               7  |
                               SBC  |
                               LVL4_PRODCAT_ID  |
                               W_PRODUCT_DTS  |
                               LVL4_PRODCAT_DESC  |
                               W_PRODUCT_DTS  |
                               Sub Class  |
                               PROD_SUBCAT  |
                               8  |
                               SKU  |
                               ITEM  |
                               W_PRODUCT_DTS  |
                               ITEM_DESC  |
                               W_PRODUCT_DTS  |
                               Stock Keeping Unit  |
Table 9-12 RSE_ALT_HIER_TYPE_STG Sample
| DELETE_FLG | DESCR | NAME | OBJ_TYPE_NAME |
                               N  |
                               Product Hierarchy with Sub-Category  |
                               PROD_SUBCAT  |
                               PRODUCT  |
The configurations specified in this example show how to refer to the default hierarchies (which are loaded through the
staging table W_PRODUCT_DTS) and the alternate hierarchies (loaded through the table W_PRODUCT_ALT_DTS). When referring to a default hierarchy level, you should use the parameters shown here for all the SRC fields. You can modify the HIER_LEVEL_ID to change the placement of the levels within the structure; however
the standard hierarchy rules must still pass after reorganizing them (for example, you cannot place DEPT below CLS because then the same child node may have multiple parent nodes).
After your configuration is finalized, you may generate the alternate hierarchy in AIF using RSE_MASTER_ADHOC_JOB with the -X flag. This will only load the alternate hierarchy; it assumes you have also loaded the main
hierarchy using the -p flag, or you are loading both of them together using -pX. For nightly
batch job details, refer to the AI Foundation Implementation Guide, section “Building Alternate Hierarchy in AIF”.
It is also necessary to update RSE_CONFIG options to use the new hierarchy. For example, to use the hierarchy
in LPO, change the PMO_PROD_HIER_TYPE parameter to the ID for the new hierarchy. You can find the ID for
the hierarchy in table RSE_ HIER_TYPE column ID, which is viewable in Manage System Configurations.
Custom hierarchies will have ALT_FLG=Y in their rows of the table.
If you will use the alternate hierarchy in forecast generation for Planning, then the rest of the data aggregation and forecasting processes are the same, whether you are using the standard product hierarchy or the alternate one. You will follow all steps outlined in the AI Foundation Implementation Guide sections for “Forecast Configuration for MFP and AP” and “Forecast Configuration for IPO-DF and AIF” as needed. A summary of those steps are:
Set up the configuration to use your alternate hierarchy
Create your run types and select your desired intersections, which can include the new alternate hierarchy levels as the forecast level
Perform aggregation, estimation, and forecasting processes following the usual steps in the AIF guides
Run the ad hoc jobs from POM to export the forecast results to Planning, such as
RSE_MFP_FCST_EXPORT_ADHOC_JOB
If you generate a forecast using the custom level, then the export to PDS will appear for that level description as defined
in RSE_ALT_HIER_LEVEL_STG.DESCR. In this example, you may generate a forecast at the SUBCAT / AREA / Fiscal
Week levels for use in MFP. These are the level names that will appear in the forecast export and must be configured for use
in MFP.
