RI Modules
The following table lists modules within the Retail Insights offer codes which may be used if you are implementing any part of Retail Insights. Disable the RI module entirely if you are not implementing Retai lInsights at this time, because all your batch configurations should be covered by the RAP common modules.
Table 5-3 RI Batch Modules
| Application | Module | Usage Notes |
RI |
RMI > BATCH |
Enable some or all of the modules in this section to use Merchandising data in Retail Insights. |
RI |
RCI > BATCH |
Enable some or all of the modules in this section to use Customer and Consumer data in Retail Insights. |
