Rules for Adding Custom Real-time Alerts into Existing Workbooks
Perform the following steps when adding custom real-time alerts into existing workbooks.
These steps must be performed using RPASCE Configuration Tools. Copying, pasting or direct editing of XML files is unsupported.-
To add custom real-time alert into existing workbooks, all measures related to the custom real-time alert need to be added to the workbook.
Create a style for the custom real-time alert in the configuration.
Create a custom real-time alert in a workbook using the measures and style created from the previous steps.
If a real-time alert defined in custom solution will be used in a GA workbook, the real-time alert measure should be imported as an external measure in the corresponding GA solution.
We must ensure that the rule group consistency is maintained while adding any custom rules that might be needed to calculate an alert measure.
The application plug-in will preserve a custom real-time alert during regeneration
