Elapsed Lock Override
Elapsed Lock Override on RPASCE is supported in the following scenarios:
Custom measures in a workbook can have the Elapsed Lock Override set to
true. -
Custom workbooks can have this field set to
truefor GA measures that are in the Writable list of the published measures.Note:
If a GA measure has not been enabled as Elapsed Lock Override, the following steps can achieve the same behavior:
Make sure the GA measure is writable.
Register a custom measure and load it from the GA measure.
Set the custom measure as Elapsed Lock Override.
Edit the custom measure in the workbook.
Commit the custom measure back into the GA measure.
