Workbook Measure Override Extensibility
Certain GA measures can be overridden in the GA workbook. These measures are listed in the WorkbookMeasureOverride section of the published<app>Measures.properties file.
For example:
WorkbookMeasureOverride|<measure name>|<measure label>|<workbook template>
This indicates that the measure can be overridden in the workbook.
The following rules apply to override measure properties:
Base State and Agg State can be overridden.
Range property of static picklists can be overridden.
Options can only be removed; new options cannot be added.
