7 Implementation Tools
Review the sections below to learn about the tools and common components used within the Retail Analytics and Planning. Many of these tools are used both for initial implementation and for ongoing maintenance activities, so implementers should be prepared to transfer knowledge of these tools to the customer before completing the project.
Retail Home
One of the first places you will go in a new RAP environment is Retail Home. It serves both as the customer portal for Oracle Retail cloud applications and as a centralized place for certain common configurations, such as Customer Module Management. Module management allows implementers to quickly configure the complex batch schedules and interdependencies of RAP applications using a simplified module-based layout. Optional batch programs, such as those used for Retail Insights or AI Foundation applications, can be turned off from this tool and it synchronizes with the batch scheduler to ensure all related programs are disabled automatically.
For more general information about Retail Home and the other features it provides, review the Retail Home Administration Guide.
Because Customer Modules are a necessary part of configuring and using a RAP environment, see the steps below for how to access this feature.
  1. To access Retail Home, access the URL sent to your cloud administrator on first provisioning a new environment. It should look similar to the URL format below.
    https://{service}.retail.{region}.ocs.oraclecloud.com/{solution-customer-env}/retailhome
  2. Navigate to Settings → Application Administration → Customer Modules Management. Confirm the table on this page loads without error and displays multiple rows of results. If an error occurs, contact Oracle Support.
    Customer Modules Management Tab
  3. You may enable or disable various modules, depending on your implementation plans. For example, if you are not implementing any Retail Insights modules, then the sections for “RCI” and “RMI” can be deactivated.
    Other components within the RI parent module may still be necessary. Detailed module requirements are described in Batch Orchestration
In addition to Customer Modules, you may also use Retail Home’s Resource Bundle Customization (RBC) feature to change translatable strings in the applications to custom values. Use the steps below to verify this feature is available:
  1. Navigate to Settings → Application Administration → Application Navigator Setup.
  2. Confirm that a row already exists for each application in the platform, including Retail Insights, Retail AI Foundation Cloud Services, and Merchandise Financial Planning.
  3. On Retail Insights, select the row and click Edit.
    1. If not enabled, change the Platform Service toggle to an enabled state.
    2. Check all of the boxes that appear.
    3. Enter a valid platform service URL.
      If your platform services URL is blank and you do not know the URL, log a Service Request to receive it from Oracle.
  4. Repeat the steps above for the AI Foundation and MFP modules, if necessary.
    Edit Application Info: Retail Insights Window
  5. Navigate to Settings → Resource Bundles → Resource Text Strings once the navigator and platform service setup is validated.
  6. Set the following values in the dropdown menus:
    1. Application: Retail Insights
    2. Bundle: Retail Insights
    3. Language: AMERICAN (en)
    Dropdown Menus
  7. Click the Search button and wait for results to return.
    • If multiple rows of results are returned, then you have successfully verified the feature is enabled and functioning properly.
    • If you receive an error, contact Oracle Support.
If you need additional details on how the RBC feature is used within each application module, refer to the product-specific documentation sets, such as the Retail Insights Administration Guide.
Process Orchestration and Monitoring (POM)
The Process Orchestration and Monitoring (POM) application is a user interface for scheduling, tracking, and managing both nightly as well as intraday batch jobs for applications such as RI, MFP, and AI Foundation. Two important screens from the POM application are Batch Monitoring and Batch Administration. The Batch Monitoring window provides a runtime view of the statuses and dependencies of the different batch cycles running on the current business day. Batch Administration allows you to modify the batch schedules and synchronize them with Retail Home.
For general information about POM and the features it provides, review the POM Implementation Guide and POM User Guides.
POM and Customer Modules Management
A required implementation step for RAP will be to synchronize customer modules from Retail Home to POM to set up your starting batch processes and turn off any processes you are not using. The steps below explain the general process for syncing POM and Retail Home, which are used by Retail Insights and AI Foundation applications to set up the nightly batches. They are also required for the RAP common components used by all the modules.
  1. Log in to the Retail Home application as a user with the RETAIL_HOME_ADMIN (or RETAIL_HOME_ADMIN_PREPROD) user role.
  2. Navigate to Settings ->Application Administration -> Customer Modules Management.
  3. Configure your batch modules as needed, disabling any components which you do not plan to implement, then click the Save button to complete the setup.
  4. Now log in to the POM application URL with a user granted the BATCH_ADMINISTRATOR_JOB or pre-prod equivalent role.
  5. Navigate to Tasks -> Batch Administration.
  6. Click on the tile named AIF DATA <Release_#> to view the RI and data warehouse batch jobs, which should be loaded into the table below the tiles.
    RI Batch Jobs
  7. Click the Sync with MDF button (above the table) and then click the OK button in the Warning message popup. Once clicked, the Platform Services calls are initiated between Retail Home and POM to sync the module status.
    Warning Message
  8. While the modules are synchronizing, you will see a message: 'Some features are disabled while a schedule is being synced'. Do not attempt to modify the schedule or make other changes while the sync is in progress.
    Message: Some Features Are Disabled
  9. Once the sync is complete, a JSON file with the batch schedule summary is downloaded. This file contains the current and previous status of an application and module in MDF and POM after sync. For example: {"scheduleName":"RI","synced":true,"enabledModules":[{"state":"MATCHED_MODULE","mdfStatus":"ENABLED","prevMdfStatusInPom":"ENABLED","prevStatusInPom":"ENABLED","publishToPom":true,"applicationName":"RI","moduleName":"RMI_SI_ONORDER","matchedModule":true},…
  10. Click the Nightly or the Standalone tab above the table and enter a filter for the Module column (based on the modules that were activated or deactivated) and press Enter. The jobs will be enabled or disabled based on the setup in Customer Modules Management.
  11. Navigate to Tasks → Batch Monitoring. Click on the same application tile as before. If the batch jobs are not listed, change the Business Date option to the 'Last Schedule Date' shown on the tile.
    Business Date Selection Menu
  12. Once the date is changed, the batch jobs are loaded in the table. Click the Restart Schedule button so that module changes are reflected in the new schedule. Click OK on the confirmation pop-up. After a few seconds, a 'Restarted' message is displayed.
  13. In the same screen, filter the Job column (for example,'W_HOUSEHOLD') to check the status of jobs. The status is either 'Loaded' or 'Disabled' based on the configuration in the Customer Modules Management screen in Retail Home.
A specific module in Retail Home may appear under several applications, and jobs within a module may be used by multiple processes in POM. The rule for synchronizing modules is, if a given POM job is enabled in at least one module, it will be enabled in POM (even if it is disabled in some other modules). Only when a job is not needed for any modules will it be disabled.
Control & Tactical Center
Retail Insights and AI Foundation modules make use of a centralized configuration interface named the Control & Tactical Center. From here the user can review and override the system configurations for different applications through the Manage System Configurations screen. The table can be filtered by Application and their configured tables. There is also a Description section on the right side that displays the details of the filtered table.
Manage System Configurations Tab
Here are the steps for accessing and using this feature:
  1. To access the system configurations, start from the Retail Home URL sent to your cloud administrator on first provisioning a new environment. It should look similar to the URL format below.
  2. Using the Retail Home application menu, locate the link for the Retail AI Foundation Cloud Services. Alternatively, you can directly navigate to the application using a URL similar to the format below.
    https://{service}.retail.{region}ocs.oraclecloud.com/{solution-customer-env}/orase/faces/Home
  3. In the task menu, navigate to Control & Tactical Center → Strategy & Policy Management. A new window opens.
    Make sure your user has the ADMINISTRATOR_JOB role in OCI IAM before logging into the system.
  4. Click Manage System Configurations in the new application screen.
  5. Select an application in the dropdown menu to pick the desired set of configurations. Based on the selection, the Filter and Table options are populated with the configured columns and data. The Description section also displays the details of the selected table.
Specifically for the initial environment setup, you will be working mainly within the Retail Insights group of configuration tables. You will also use the Strategy & Policy Management interface to access the forecasting configurations needed to set up and generate forecasts for Planning applications. It is also used to manage the business policies and rules used by Lifecycle Pricing Optimization. Any required configurations in these areas will be covered later in this document.
Oracle Analytics
Retail Analytics and Planning implementations largely involve processing large volumes of data through several application modules, so it is important to know how to access the database to review settings, monitor load progress, and validate data tables. Database access is provided through the Oracle Analytics Cloud application, which is included with all Retail Analytics and Planning environments. The URL to access the DV application will be similar to the below URL:
https://{analytics-tenant-and-region}.analytics.ocp.oraclecloud.com/ui/dv/?pageid=home
The best way to write ad hoc SQL against the database is through APEX. However, Oracle Analytics can be used to create reusable datasets based on SQL that can be built into reports for longer term usage.
The RAP database comprises several areas for the individual application modules, but the majority of objects from RI and AIF are exposed in Oracle Analytics as a connection to the RAFEDM01 database user. This user has read-only access to the majority of database objects which are involved in RI and AI Foundation implementations, as well as the tables involved in publishing data to the Planning modules. Follow the steps below to verify access to this database connection:
  1. Log in to the application with a user that includes the DVContentAuthor group in OCI IAM (group names vary by cloud service; they will be prefixed with the tenant ID).
  2. Expand the navigation panel using the Navigator icon in the upper left corner.
    Navigation Panel
  3. Click Data and, once the screen loads, click Connections. Confirm that you have a connection already available for RAFEDM01-Connection (Retail Analytics Front End Data Mart).
    Connections
  4. Click the connection. The Add Data Set screen will load using the selected connection. A list of database users are displayed in the left panel.
    If any errors are displayed or a password is requested, contact Oracle Support for assistance.
    Data Sets
  5. Expand the RAFEDM01 user.
  6. Select C_ODI_PARAM from the list of database tables and drag-and-drop the table name into the center of the screen.
  7. Wait for the table to be analyzed and results to be displayed. Confirm that multiple rows of data are shown in the bottom panel:
    All Tables Selected
  8. If you are performing a one-time query that does not need to be repeated or reused, you can stop at this point. You can also add a Manual SQL query using the SQL object at the top of the left panel, to write simple queries on the database. However, if you want to create a reusable dataset, or expose the data for multiple users, proceed to the next steps.
  9. Click the Save icon in the upper right corner of the screen and provide a name for the new dataset:
    Save Dataset Window
  10. Click the table name (C_ODI_PARAM) at the bottom of the screen to modify the dataset further for formatting and custom fields (if desired).
  11. You can format the dataset on this screen for use in analytics workbooks. You may rename the columns, change the datatype between Measure and Attribute, create new columns based on calculated values, and extract values from existing columns (such as getting the month from a date). Refer to Oracle Analytics documentation on Dataset creation for full details. When finished, click Create Workbook in the upper right corner to open a new workbook with it.
    Project Created
Once you have verified database connectivity, you may continue on to creating more datasets and workbooks as needed. Datasets will be saved for your user and can be reused at later dates without having to re-query the database. Saved datasets can be accessed using the Data screen from the Navigator panel.
File Transfer Services
File Transfer Services (FTS) for the Retail Analytics and Planning cloud services are being made available in this release, replacing SFTP in new environments. They will allow you to manage uploading and downloading files to Oracle Cloud Infrastructure Object Storage, which is an internet-scale, high-performance storage platform that offers reliable and cost-efficient data durability.
Access to files is through a pre-authenticated request (PAR), which is a URL that requires no further authentication to upload or download files to the cloud. To retrieve a PAR, you must use the appropriate file transfer REST service. These new services will enable you to import files to and export files from Object Storage used by the solutions. The primary role of these services is to ensure that only valid external users can call the service by enforcing authorization policies. Where supported, the files can be compressed (zipped) before upload.
The general flow of activities involving FTS and an external integrating system are as follows for transferring files into our cloud service:
  1. The third-party solution calls the service, requesting pre-authentication to upload files from Object Storage, including the incoming prefix and file name. On receiving the PAR, the file is uploaded using the URL included within the response. A PAR has a validity of 10 minutes; an upload can take longer than 10 minutes but after it is returned it must be started within that period.
  2. The cloud service batch processing will retrieve the files from Object Storage, after they have passed an anti-virus and malware scan.
  3. The batch processing will delete the file from Object Storage to ensure it is not re-processed in the next batch run. The batch processing uncompresses the file and processes the data.
Object Storage Process Flow
To interact with FTS you must use the REST APIs provided. The table below lists the API end points for different file operations.
Operation Method FTS API Endpoint
Ping
GET
{baseUrl}/services/private/FTSWrapper/ping
List Prefixes
GET
{baseUrl}/services/private/FTSWrapper/listprefixes
List Files
GET
{baseUrl}/services/private/FTSWrapper/listfiles
Move Files
POST
{baseUrl}/services/private/FTSWrapper/movefiles
Delete Files
DELETE
{baseUrl}/services/private/FTSWrapper/delete
Request Upload PAR
POST
{baseUrl}/services/private/FTSWrapper/upload
Request Download PAR
POST
{baseUrl}/services/private/FTSWrapper/download
The {baseUrl} is the URL for your RAP service that is supplied to you when your service is provisioned, and can be located from Retail Home as it is also the platform service URL. Refer to the Required Parameters section for additional parameters you will need to make FTS requests.
Required Parameters
To leverage File Transfer Services, several pieces of information are required. This information is used in API calls and also inserted into automated scripts, such as the test script provided later in this document.
The below parameters are required for uploading data files to object storage.
BASE_URL="https://__YOUR_TENANT_BASE_URL__"
TENANT="__YOUR-TENANT_ID__"
IDCS_URL="https://_YOUR__IDCS__URL__/oauth2/v1/token"
IDCS_CLIENTID="__YOUR_CLIENT_APPID__"
IDCS_CLIENTSECRET="__YOUR_CLIENT_SECRET___"
IDCS_SCOPE="rgbu:rsp:psraf-__YOUR_SCOPE__"
Base URL
The substring before the first ‘/’ in the Application URL is termed as the base URL.
Example URL: https://rap.retail.eu-frankfurt-1.ocs.oraclecloud.com/rgbu-rap- hmcd-stg1-rsp/orase/faces/Home
In the above URL, BASE_URL = https://rap.retail.eu-frankfurt-1.ocs.oraclecloud.com
Tenant
The string after the Base URL and before the Application URL starts would be the Tenant.
In the above URL, TENANT = rgbu-rap-hmcd-stg1-rsp
OCI IAM URL
Your authentication URL is the one used when you first access any of your cloud services and are redirected to a login screen. You will get the base URL from the login screen and combine it with the necessary path to fetch the authentication token.
Example Base URL: https://oci—iam-a4cbf187f29d4f41bc03fffb657d5513.identity.oraclecloud.com/
Using the above URL, IDCS_URL = https://oci—iam-a4cbf187f29d4f41bc03fffb657d5513.identity.oraclecloud.com/oauth2/v1/token
OCI IAM Scope
The authentication scope is a code associated with the specific environment you are planning to interact with. It has a static prefix based on the application, appended with an environment-specific code and index.
Base format: rgbu:rsp:psraf-<ENV><ENVINDEX>
Where <ENV> is replaced with one of the codes in (PRD, STG) and <ENVINDEX> is set to 1, unless you have multiple staging environments, and then the index can be 2 or greater. For these applications (that is, RI and AIF) use the rsp code. For other applications, the code is rpas.
To determine this information, look at the URL for your environment, such as:
https://rap.retail.eu-frankfurt-1.ocs.oraclecloud.com/rgbu-rap-hmcd-stg1-rsp/orase/faces/Home
In the tenant string, you can see the code stg1. This can be added to your scope string (ensuring it is in uppercase characters only).
IDCS_SCOPE = rgbu:rsp:psraf-STG1
Client ID and Secret
The client ID and secret are authentication keys generated for your specific connection and must be passed with every request. Retail Home provides an interface to get these values when you login with a user having the PLATFORM_SERVICES_ADMINISTRATOR group.
  1. Navigate to the Manage OAuth Clients screen from the Settings menu, under Application Administration.
  2. Click the plus (+) icon to create a new OAuth 2.0 client.
  3. Enter the requested details in the window. The application name should be unique to the connection you are establishing and cannot be used to generate multiple client ID/secret pairs.
    Create IDCS Oauth 2.0 Client Window
    The application name cannot be re-used for multiple requests. It also cannot contain spaces. The scope should be the string previously established in OCI IAM Scope. The description is any value you wish to enter to describe the application name being used.
  4. Click OK to submit the form and display a new popup with the client ID and secret for the specified Application Name. Do NOT close the window until you have captured the information and verified it matches what is shown on screen. Once you close the window, you cannot recover the information and you will need to create a new application.
MFP Example
To determine IDCS_SCOPE, refer to the tenant string portion (for example, rgbu-rap-cust-stg1-mfpscs) of your cloud service URL (for example,https://rap.retail.us-ashburn-1.ocs.oraclecloud.com/rgbu-rap-cust-stg1-mfpscs/rpasceui/)
Planning Cloud Service URL Patterns SCOPE
rgbu:rpas:psraf-MFPSCS-STG1
https://rap.retail.us-ashburn-1.ocs.oraclecloud.com/rgbu-rap-cust-stg1-rpasce/rpasceui/
rgbu:rpas:psraf-RPASCE-STG1
Based on the tenant string (for example, rgbu-rap-cust-stg1-mfpscs), the environment index is stg1 and the application is mfpscs. For this combination, the IDCS scope will look like the configuration below (ensuring it is in uppercase characters only):
IDCS_SCOPE = rgbu:rpas:psraf-MFPSCS-STG1
Create the OAuth Client in Retail Home with the following parameters:
  • App Name: MFP_STG1
  • Description: FTS for MFP on STG1
  • Scope 1: rgbu:rpas:psraf-MFPSCS-STG1
This generates an OAuth Client with details like this:
  • Oauth client:
  • Client Id: MFP_STG1_APPID
  • Client Secret: 6aae7818-309b-4e7a-874e-f26356a675b1
You will need to capture Client Id and Client Secret. So set the FTS script variables as follows:
BASE_URL="https://rap.retail.eu-frankfurt-1.ocs.oraclecloud.com"
TENANT="rgbu-rap-hmcd-stg1-mfpscs"
IDCS_URL="https://oci—iam-a4cbf187f29d4f41bc03fffb657d5513.identity.oraclecloud.com/oauth2/v1/token"
IDCS_CLIENTID="MFP_STG1_APPID"
IDCS_CLIENTSECRET="6aae7818-309b-4e7a-874e-f26356a675b1"
IDCS_SCOPE="rgbu:rpas:psraf-MFPSCS-STG1"
IPO Example
To determine the IDCS_SCOPE, refer to the tenant string portion (for example, rgbu-rap-cust-stg1-ipocs) of your cloud service URL (for example, https://rap.retail.us-ashburn-1.ocs.oraclecloud.com/rgbu-rap-cust-stg1-ipo/rpasceui/)
https://rap.retail.us-ashburn-1.ocs.oraclecloud.com/rgbu-rap-cust-stg1-ipocs/rpasceui/
rgbu:rpas:psraf-IPOCS-STG1
Based on the tenant string (for example, rgbu-rap-cust-stg1-ipocs), the environment index is stg1 and the application is ipocs. For this combination, the IDCS scope will look like the configuration below (ensuring it is in uppercase characters only):
IDCS_SCOPE = rgbu:rpas:psraf-IPOCS-STG1
  • App Name: IPOCS_STG1
  • Description: FTS for IPOCS on STG1
  • Scope 1: rgbu:rpas:psraf-IPOCS-STG1
  • Oauth client:
  • Client Id: IPOCS_STG1_APPID
TENANT="rgbu-rap-hmcd-stg1-ipocs"
IDCS_CLIENTID="IPOCS_STG1_APPID"
IDCS_SCOPE="rgbu:rpas:psraf-IPOCS-STG1"
AP Example
To determine the IDCS_SCOPE, refer to the tenant string portion (for example, rgbu-rap-cust-stg1-apcs) of your cloud service URL (for example, https://rap.retail.us-ashburn-1.ocs.oraclecloud.com/rgbu-rap-cust-stg1-apcs/rpasceui/)
rgbu:rpas:psraf-APCS-STG1
Based on the tenant string (for example, rgbu-rap-cust-stg1-apcs), the environment index is stg1 and the application is apcs. For this combination, the IDCS scope will look like the configuration below (ensuring it is in uppercase characters only):
IDCS_SCOPE = rgbu:rpas:psraf-APCS-STG1
  • App Name: AP_STG1
  • Description: FTS for AP on STG1
  • Scope 1: rgbu:rpas:psraf-AP-STG1
  • Oauth client:
  • App Name: AP_STG1
  • Client Id: AP_STG1_APPID
TENANT="rgbu-rap-hmcd-stg1-apcs"
IDCS_CLIENTID="AP_STG1_APPID"
IDCS_SCOPE="rgbu:rpas:psraf-AP-STG1"
Common HTTP Headers
Each call to FTS should contain the following HTTP headers:
Content-Type: application/json
Accept: application/json
Accept:-Language: en
Authorization: Bearer {ClientToken}
The {ClientToken} is the access token returned by OCI IAM after requesting client credentials. This is refreshed periodically to avoid authentication errors.
Retrieving Identity Access Client Token
The access client token is returned from a POST call to the OCI IAM URL, provided at provisioning, along with the following:
Headers
Content-Type: application/x-www-form-urlencoded
Authorization: Basic {ociAuth}
ociAuth is the base64 encoding of your {clientId}:{clientSecret}
Data (URLEncoded)
grant_type=client_credentials
scope=rgbu :rpas :psraf-{environment}
FTS API Specification
An example shell script implementing these API calls can be found in Sample Public File Transfer Script for Planning Apps and Sample Public File Transfer Script for RI and AIF. The sample script will require all of the parameters discussed so far in this chapter to be added to it before it can be used to issue FTS commands. Refer to the table below for a more detailed list of services available in FTS.
The baseUrl in these examples is not the same as the BASE_URL variable passed into cURL commands. The baseUrl for the API itself is the hostname and tenant, plus the service implementation path (for example, RetailAppsPlatformServices). The sample scripts provided in the appendix show the full path used by the API calls.
Ping
Returns the status of the service, and provides an external health-check.
Method
GET
Endpoint
Parameters
Common headers
Request
None
Response
{ appStatus:200 }
The appStatus code follows HTTP return code standards.
List Prefixes
Returns a list of the known storage prefixes. These are analogous to directories, and are restricted to predefined choices per service.
Method
GET
Endpoint
Parameters
Common headers
Request
None
Response
A JSON array of strings containing the known prefixes.
List Files
Returns a list of the file within a given storage prefix.
Method
GET
Endpoint
Parameters
Common headers
Request
Query parameters (…/listfiles?{parameterName}) that can be appended to the URL to filter the request:
prefix – the storage prefix to use
contains – files that contain the specified substring
scanStatus – file status returned by malware/antivirus scan
limit – control the number of results in a page
offset – page number
sort – the sort order key
Response
A JSON resultSet containing array of files. For each file, there is metadata including: name, size, created and modified dates, scan status and date, scan output message.
Move Files
Moves one or more files between storage prefixes, while additionally allowing the name to be modified
Method
GET
Endpoint
Parameters
Common headers
Request
An array of files containing the current and new storage prefixes and file names, as shown below.
{"listOfFiles": [
	{"currentPath":
		{ "storagePrefix": "string",
			"fileName": "string"},
			"newPath": {
Response
HTTP 200, request succeeded;
HTTP 500, an error was encountered.
Delete Files
Deletes one more or files
Method
DELETE
Endpoint
Parameters
Common headers
Request
A JSON array of files to be deleted. One or more pairs of storagePrefix and filename elements can be specified within the array.
{"listOfFiles":
Response
A JSON array of each file deletion attempted and the result.
Request Upload PAR
Request PAR for uploading one or more files
Method
POST
Endpoint
Parameters
Common headers
Request
A JSON array of files to be uploaded. One or more pairs of storagePrefix and filename elements can be specified within the array.
{ "listOfFiles":
Response
A parList containing an array containing elements corresponding to the request including the PAR accessUri and name of file.
Request PARs for downloading one or more files
Method
POST
Endpoint
Parameters
Common headers
Request
A JSON array of files to be downloaded. One or more pairs of storagePrefix and filenames can be specified within the array.
{ "listOfFiles":
Response
FTS Script Usage
Assuming you have taken the sample script and named it file_transfer.sh on a Unix system, you may use commands like those below to call the APIs.
Upload Files
For RAP input files (excluding direct-to-RPASCE input files) the input files must be uploaded to the object storage with a prefix of ris/incoming.
  • Prefix: ris/incoming
  • File Name: RI_RMS_DATA.zip
  • Command:
    sh file_transfer.sh uploadfiles ris/incoming RI_RMS_DATA.zip
Download Files
For RAP output files (excluding direct-from-RPASCE output files) the files must be downloaded from the object storage with a prefix of ris/outgoing.
  • Prefix: ris/outgoing
  • File Name: cis_custseg_exp.csv
  • Command:
    sh file_transfer.sh downloadfiles ris/outgoing cis_custseg_exp.csv
Download Archives
For RAP files that are automatically archived as part of the batch process, you have the ability to download these files for a limited number of days before they are erased (based on the file retention policy in your OCI region). Archive files are added to sub-folders so the steps are different from a standard download.
  1. POM job logs will show the path to the archive
    For example: incoming-10072022-163233/RAP_DATA.zip
  2. Create the directory in your local server matching the archive name.
    For example: mkdir incoming-10072022-163233
  3. Use the downloadfiles command with the ris/archive prefix and the file path as the sub-folder and filename together.
    For example: sh file_transfer.sh downloadfiles ris/archive incoming-10072022-163233/RAP_DATA.zip
Analytics Publisher
The Analytics Publisher component of Oracle Analytics is available for reporting and export file generation where the data needs to be written into a specific template or layout and must be delivered to other sources such as email or Object Storage (OS). SFTP is no longer available, so if you have previously used SFTP as the report delivery method, you will now use OS.
Configuring Burst Reports for Object Storage
After configuring the Publisher data model, as you build your burst query by navigating to the bursting section, you need to be aware of some of the key parameters to be supplied to the burst query that are specific to Object Storage.
Sample Bursting Query for object storage as the delivery channel:
select 0 KEY,
'<template_name>' TEMPLATE,
'RTF' TEMPLATE_FORMAT,
'en-US' LOCALE,
'PDF' OUTPUT_FORMAT,
'OBJECTSTORAGE' DEL_CHANNEL,
'<output_name>' OUTPUT_NAME,
'OS' PARAMETER1,
'<prefix>'PARAMETER2,
'<file_name>' PARAMETER3
FROM "Retail Insights As-Is"
Key parameters that are specific to object storage are:
  • DEL_CHANNEL — This needs to be keyed in as OBJECTSTORAGE.
  • PARAMETER1 — Use OS as the parameter value for this, because this is the preconfigured server name. The value for this should be kept as OS and should not be changed.
  • PARAMETER2 — Prefix under the object storage bucket where the file will be uploaded. The prefix should not start or end with a / character; for example ris/outgoing is a possible prefix to use.
  • PARAMETER3 — File name. The file will be created under the prefix; for example a filename of order_list with type as PDF will be created as ris/outgoing/order_list.pdf
Delivering Scheduled Reports through Object Storage
If the report is not using a bursting definition then, while adding the destination for the reports delivery when you schedule a report job, you will need the following set of inputs that are required to push the file to object storage.
  • Server – The server is preconfigured as OS for any tenant. OS must always be selected.
  • Prefix – The prefix under the object storage bucket where the file will be uploaded.
  • File Name – The file name with which the scheduled report output will be delivered to the object storage.
The way you set up these inputs is the same as when using the bursting option. For additional details on how to set up reports delivery through object storage, refer to Set Output Options in Oracle Cloud Visualizing Data and Building Reports in Oracle Analytics Cloud.
Downloading Reports from Object Storage
Once the reports are sent to object storage, use the createPar service to get a link to download the files. This service is available using a Retail Home API, which generates a Pre-authenticated Request (PAR) to download the file. The PAR is not accessible using File Transfer Services (FTS) commands; you must directly download the file by first calling the API and then pulling the data down from the returned URL.
For details on the service API, refer to the Retail Home Administration Guide Appendix B.
Sample message body when calling the Retail Home service:
  "disUrl": "https://rgbu.gbua.ocs.oc-test.com",
  "name": "Productlist",
  "dateExpires": "2024-01-31",
  "objectName": "ris/incoming/Productlist.pdf"
The name should match the file name (without extension) that was specified in PARAMETER3 in the bursting query. The objectName is the combination of the prefix, file name, and file extension (all specified in the bursting query definition) that defines the full Object Storage path to the file. Although the OUTPUT_FORMAT value in the bursting query is uppercase (for example, PDF), the file extension used for the objectName will be lowercase (for example, pdf). The value used for dateExpires must be greater than the current date, but not more than 365 days in the future.
When making the request, you must also add a context type header with a value of application/json or you will not receive a response. If the requested file is found, then you will get a response like the following:
  "status": "Success",
  "id": "B0ji5Vir/nDfUQVaFHNhYVjgHoRPO8ZnFjTUPcQIyXcEtY8HUoqeJNsdyFzqreqv:ris/incoming/Productlist.pdf",
  "url": "https://objectstorage.us-phoenix-1.oraclecloud.com/p/X6BRpziLKQ3xoRcSToi68L31NHxm2rhTc2lbrTpvmWm9vIpCVWNiC63tYTCWgxYW/n/oraclegbudevcorp/b/cds_gbua_cndevcorp_rgbu_rgbu_tpn24ouxsgftuy5qh4te_RIRSP_STG5009_1/o/ris/incoming/Productlist.pdf"
The URL can be passed into any method you would normally use to download a file, such as a wget command.
Application Express (APEX)
The Retail Analytics and Planning includes a dedicated instance of Application Express (APEX) that is pre-configured for read-only database access to RAP tables and views. APEX is managed as a part of the Innovation Workbench (IW) module that includes APEX and Data Studio. You can access APEX from a task menu link in the AI Foundation Cloud Services interface, or by navigating directly to the ORDS endpoint like below:
https://{base URL}/{solution-customer-env}/ords
For example:
https://ocacs.ocs.oc-test.com/nrfy45ka2su3imnq6s/ords/
For first time setup of the administrator user account for APEX, refer to the RAP Administration Guide.
After you are logged into APEX, click the SQL Workshop icon or access the SQL Workshop menu to enter the SQL Commands screen. This screen is where you will enter SQL to query the RAP database objects in the RI and AI Foundation schemas.
APEX SQL Workshop Menu
To see the list of available objects to query, access the Object Browser. All RI and AI Foundation objects are added as synonyms, so select that menu option from the panel on the left.
APEX Object Browser
If you do not see any RI tables in the synonym list, then you may need to run a set of ad hoc jobs in POM to expose them. Run the REFRESH_GRANT_SYNONYM_ADHOC process from the AI Foundation Data schedule’s standalone job list. Once the jobs execute successfully, start a new session of APEX and navigate back to the list of Synonyms in the Object Browser screen to confirm the table list is updated.
Database Access Levels
Your ability to query and interact with AIF database objects depends on the environment you are working with (Production or Non-Production). The following grants and privileges are given to end users in APEX specifically for tables and views in the RI and AIF database users.
Database Grant Non-Prod Prod
Insert (Staging Tables)
Yes
Yes
Insert (Internal Tables)
Yes
No
Update (Staging Tables)
Yes
Yes
Update (Internal Tables)
Yes
No
Delete (Staging Tables)
Yes
Yes
Delete (Internal Tables)
Yes
No
Truncate
No
No
Create Object
No
No
Alter Object
No
No
Drop Object
No
No
A staging table is generally any table that receives data from an outside source, which can include flat files, direct integration between two Oracle solutions, or web services. For example, W_PRODUCT_DS is the staging table in the RADM01 schema that receives product information. Internal tables include the target tables where staged data will be moved to for the applications to read from during normal operations, temporary (TMP) tables, and configuration tables. There are a few exceptions made for application objects that must not be altered, but all tables that contain data you should need to interact with will be accessible in non-prod environments. W_PRODUCT_D is an example of a target table for the W_PRODUCT_DS staging table.
Postman
For automated API calls, Postman is the preferred way to interact with POM in order to call ad hoc processes and perform data load activities. The steps below explain how to configure Postman for first-time use with POM.
POM versions earlier than v21 allow Basic Authentication, while v21+ requires OAuth 2.0 as detailed below.
  1. As a pre-requisite, retrieve the Client ID and Client Secret from Retail Home’s ‘Create IDCS OAuth 2.0 Client’. Refer to the Retail Home Administration Guide for complete details on retrieving the Client ID and Client Secret info if you have not done it before.
  2. In the Postman application, click New->HTTP Request.
  3. Set Request Type as POST and set the Request URL (Example for RI schedule):
    https://<Region-LB>/<POM-Subnamespace>/ProcessServices/services/private/executionEngine/schedules/RI/execution
    For example:
    https://home.retail.us-region-1.ocs.oc-test.com/rgbu-common-rap-prod-pom/ProcessServices/services/private/executionEngine/schedules/RI/execution
  4. Perform the following steps before sending the POST request to retrieve your authentication token:
    1. Authorization Tab:
      Type: OAuth 2.0
      Add authorization data to: Request Headers
      Postman Authorization Tab
    2. Configure the New Token:
      1. Token Name: PROD5555
      2. Grant Type: Client Credentials
      3. Access Token URL: https://<Customer-OCI_IAM>/oauth2/v1/token
        For example: https://oci—iam-fe5f77f8a44.identity.c9dev.oc9dev.com/oauth2/v1/token
      4. Client ID: A unique “API Key” generated when registering your application in the Identity Cloud Services admin console.
      5. Client Secret: A private key similar to a password that is generated when registering your application in the Identity Cloud Services admin console.
      6. Scope: rgbu:pom:services-administrator-<Env-INDEX>
        For example: rgbu:pom:services-administrator-PROD5555
      7. Client Authentication: Send as Basic Auth header
      Postman Configure New Token
    3. Click the Get New Access Token button.
      Postman Authentication Complete Window
  5. The Access Token is displayed in the MANAGE ACCESS TOKENS pop-up window. Click the Use Token button.
    MANAGE ACCESS TOKENS Window
  6. The generated token is populated in the Access Token section.
    Access Token Field Populated
  7. In the Parameters, provide a key of skipVersion with a value of true.
    skipVersion Parameter
  8. Click the Body tab to enter the JSON for running POM batches.
  9. Select the raw radio button and JSON file type.
  10. Enter the JSON XML and click the Send button in the Body tab.
    1. If the returned Status is "200 OK" and 'executionEngineInfo': “STARTED” is in the response body, then the batch started as expected.
    2. If the status is not 200 and either of 401 (authorization error) or 500 (incorrect body content) or 404 (server down) and so on, then perform error resolution as needed.
    Example request and response for the HIST_ZIP_FILE_LOAD_ADHOC process:
    Sample JSON Request and Response
    Additional examples of Postman Body JSON XML are listed below.
    Nightly Batch
    "cycleName"    :  "Nightly",
    "flowName"     :  "Nightly",
    "requestType"  :  "POM Scheduler"
    With One Process – Applicable for Nightly and Ad Hoc
    "requestType"   :  "POM Scheduler",
    "processName"   :  "LOAD_AGGREGATION_BCOST_IT_DY_A_PROCESS"
    With Dynamic Parameters – Applicable for Nightly and Ad Hoc
    "cycleName"         :  "Adhoc",
    "flowName"          :  "Adhoc",
    "processName"       :  "HIST_INVRTV_LOAD_ADHOC",
    "requestParameters" :  "jobParams.HIST_LOAD_INVRTV_DAY_JOB=2020-09-09 2021-09-09"
