3 Data Loads and Initial Batch Processing
This chapter describes the common data requirements for implementing any of the Retail Analytics and Planning modules, where to get additional information for optional or application-specific data interfaces, and how to load an initial dataset into the cloud environments and distribute it across your desired applications.
Data Requirements
Preparing data for one or more Retail Analytics and Planning modules can consume a significant amount of project time, so it is crucial to identify the minimum data requirements for the platform first, followed by additional requirements that are specific to your implementation plan. Data requirements that are called out for the platform are typically shared across all modules, meaning you only need to provide the inputs once to leverage them everywhere. This is the case for foundational data elements, such as your product and location hierarchies. Foundation data must be provided for any module of the platform to be implemented. Foundation data is provided using different sources depending on your current software landscape, including the on-premise Oracle Retail Merchandising System (RMS) or 3rd-party applications.
Figure 3-1 Inbound Foundation Data Flows
Inbound Data Flow Diagram
Retail Insights is used as the foundational data warehouse that collects and coordinates data on the platform. You do not need to purchase Retail Insights Cloud Service to leverage the data warehouse for storage and integration; it is included as part of any RAP solution. Regardless of which RAP solutions you are implementing, the integration flows shown above are used.
Application-specific data requirements are in addition to the shared foundation data, and may only be used by one particular module of the platform. These application data requirements may have different formats and data structures from the core platform-level dataset, so pay close attention to those additional interface specifications. References and links are provided later in this chapter to guide you to the relevant materials for application-specific inputs and data files.
If you are using RMS as your primary data source, then you may not need to produce some or all of these foundation files, as they will be created by other Oracle Retail processes for you. However, it is often the case that historical data requires a different set of foundation files from your future post-implementation needs. If you are loading manually-generated history files, or you are not using an Oracle Retail data source for foundation data, then review the rest of this section for details.
Platform Data Requirements
There is a subset of core platform data files that can be created and loaded once and then used across some or all application modules. These files use a specific format as detailed below.
Every application included with Retail Analytics and Planning has additional data needs beyond this foundation data. But this common set of files can be used to initialize the system before moving on to those specific requirements.
The first table defines the minimum dimensional data. A dimension is a collection of descriptive elements, attributes, or hierarchical structures that provide context to your business data. Dimensions tell the platform what your business looks like and how it operates. This is not the entire list of possible dimension files, just the main ones needed to use the platform. Refer to Legacy Foundation File Reference for a complete list of available platform foundation files, along with a cross-reference to the legacy interfaces they most closely align with. A complete interface specification document is also available in My Oracle Support to assist you in planning your application-specific interface needs.
Table 3-1 Common Foundation Dimensions
Dimension Filename(s) Usage
Product
PRODUCT.csv
The product foundation data includes the items you sell, their core merchandise attributes, and their hierarchical structure in your source systems.
Product
PRODUCT_ALT.csv
Alternate product attributes and hierarchy levels intended for downstream Planning application extensions.
Organization
ORGANIZATION.csv
The organization foundation data includes all of your business entities involved in the movement or sale of merchandise. This includes stores, warehouses, partner/finisher locations, web stores, and virtual warehouses. It also includes your organizational hierarchy and core location attributes.
Organization
ORGANIZATION_ALT.csv
Alternate location attributes and hierarchy levels intended for downstream Planning application extensions.
Calendar
CALENDAR.csv
The calendar foundation data defines your business (or fiscal) calendar. This is the calendar that you operate in when making critical business decisions, reporting on financial results, and planning for the future. The most common calendar used by all modules of the platform is a 4-5-4 fiscal calendar.
Calendar CALENDAR_ALT.csv Alternate calendar attributes and hierarchy levels intended for downstream Planning application extensions.
Exchange Rates
EXCH_RATE.csv
Exchange rates define the conversion of monetary values from the currency they are recorded in to your primary operating currency. Most data is provided to the platform in the local currency of the data source, and it is converted to your primary currency during the load process.
Product Attributes
ATTR.csv
PROD_ATTR.csv
Product attributes describe the physical and operational characteristics of your merchandise and are a critical piece of information for many AI Foundation modules, such as Demand Transference and Size Profile Optimization. They are not required as an initial input to start data loads but will eventually be needed for most applications to function.
System Parameters
RA_SRC_CURR_PARAM_G.dat
Parameters file that supports certain batch processes, such as the ability to load multiple ZIP files and run batches in sequence. Include this file with nightly batch uploads to specify the current business date, which enables the system to run multiple batches in sequence without customer input. Required once you begin nightly or weekly batch uploads.
The other set of foundation files are referred to as facts. Fact data covers all of the actual events, transactions, and activities occurring throughout the day in your business. Each module in the platform has specific fact data needs, but the most common ones are listed below. At a minimum, you should expect to provide Sales, Inventory, and Receipts data for use in most platform modules. The intersection of all data (meaning which dimensional values are used) is at a common level of item/location/date. Additional identifiers may be needed on some files; for example, the sales data should be at the transaction level, the inventory file has a clearance indicator, and the adjustments file has type codes and reason codes.
Table 3-2 Common Foundation Facts
Sales
SALES.csv
Transaction-level records for customer sales (wholesale data provided separately). Used across all modules.
Inventory
INVENTORY.csv
Physical inventory levels for owned merchandise as well as consignment and concession items. Used across all modules.
Receipts
RECEIPT.csv
Inventory receipts into any location, including purchase order and transfer receipts. Used by Insights, Planning, and the AI Foundation modules to identify the movement of inventory into a location and to track first/last receipt date attributes.
Adjustments
ADJUSTMENT.csv
Inventory adjustments made at a location, including shrink, wastage, theft, stock counts, and other reasons. Used by Insights and Planning modules.
Purchase Orders
ORDER_HEAD.csv
ORDER_DETAIL.csv
The purchase order data for all orders placed with suppliers. Held at a level of order number, supplier, item, location, and date. Separate files are needed for the order attributes and order quantities/amounts. Used by Insights and Planning modules.
Markdowns
MARKDOWN.csv
The currency amount above or below the listed price of an item when that item's price is modified for any reason (planned markdown, POS discount, promotional sale, and so on). Used By Insights and Planning modules.
Transfers
TRANSFER.csv
The movement of inventory between two locations (both physical and virtual). Used By Insights and Planning modules.
Returns to Vendor
RTV.csv
The return of owned inventory to a supplier or vendor. Used by Insights and Planning modules.
Prices
PRICE.csv
The current selling retail value of an item at a location. Used by Insights and AI Foundation modules.
Costs
COST.csv
The base unit cost and derived net costs of an item at a location. Used by Retail Insights only.
Wholesale/Franchise
SALES_WF.csv
Sales and markdown data from wholesale and franchise operations. Used by all modules.
Deal Income
DEAL_INCOME.csv
Income associated with deals made with suppliers and vendors. Used by Insights and Planning modules.
Details on which application modules make use of specific files (or columns within a file) can be found in the RAP Data Dictionary workbook in your Oracle Analytics catalog. Make sure you have a full understanding of the data needs for each application you are implementing before moving on to later steps in the process. If it is your first time creating these files, read Data File Generation, for important information about key file structures and business rules that must be followed for each foundation file.
File Upload Samples
When you first upload foundation data into the platform, you will likely provide a small subset of the overall set of files required by your applications. The following examples show a possible series of initial file uploads to help you verify that you are providing the correct sets of data. All dimension files in initialization and history loads must be full snapshots of data; never send partial or incremental files.
Example #1: Calendar Initialization
When you first configure the system you must upload and process the CALENDAR.csv file. You will generate the file following the specifications, and also provide a context (ctx) file, as described in Data File Generation.
File to upload: RAP_DATA_HIST.zip
Zip file contents:
  • CALENDAR.csv
  • CALENDAR.csv.ctx
Example #2: Product and Location Setup
You have finalized the calendar and want to initialize your core product and organization dimensions. You must provide the PRODUCT.csv and ORGANIZATION.csv files along with their context files, as described in Data File Generation.
Zip file contents:
  • PRODUCT.csv
  • PRODUCT.csv.ctx
  • ORGANIZATION.csv
  • ORGANIZATION.csv.ctx
Example #3: Full dimension load
You have a set of dimension files you want to process using the initial dimension load ad hoc processes in POM.
Zip file contents:
  • PRODUCT.csv
  • PRODUCT.csv.ctx
  • ORGANIZATION.csv
  • ATTR.csv
  • ATTR.csv.ctx
  • PROD_ATTR.csv
  • PROD_ATTR.csv.ctx
  • EXCH_RATE.csv
  • EXCH_RATE.csv.ctx
Example #4: Sales Data Load
You have finished the dimensions and you are ready to start processing sales history files.
Zip file contents:
  • SALES.csv
  • SALES.csv.ctx
Example #5: Multi-File Fact Data Load
Once you are confident in your data file format and contents, you may send multiple files as separate ZIP uploads for sequential loading in the same run. This process uses a numerical sequence on the end of the ZIP file name. The actual method to loop over these files is to use the RI_FLOW_ADHOC standalone flow in the AIF DATA POM schedule, which executes the fact history load for all the standard history load files. Make sure you only schedule a number of recurring flow executions equal to the number of ZIPs you will upload. If you run the flow without any ZIPs remaining to be processed, all jobs will still attempt to execute with 0 rows of data in the staging tables. This will cause the flow to fail as some loads are designed to stop the process if there is no data available.
Files to upload: RAP_DATA_HIST.zip.1, RAP_DATA_HIST.zip.2, RAP_DATA_HIST.zip.3
Zip file contents (in each uploaded zip):
  •  SALES.csv
  •  SALES.csv.ctx – The CTX is only required in the first ZIP file, but it’s best to always include it so you can refer to it later in archived files, if needed.
In this example you are loading sales month by month iteratively, but the standalone flow supports all other fact loads as well. You can also combine multiple fact files (for different facts with the same period of time) in each ZIP file upload. Track the status of the files in the C_HIST_FILES_LOAD_STATUS table after each cycle execution; it shows whether the file was loaded successfully and how many more files are available to process.
Uploading ZIP Packages
When providing data to the platform, push the compressed files into Object Storage using a ZIP file format. Review the File Transfer Services section for details on how to interact with Object Storage. The ZIP file you use will depend on the data you are attempting to load. The default ZIP file packages are below, but the history ZIP file name is configurable in C_ODI_PARAM using parameter name HIST_ZIP_FILE if a different one is desired.
Table 3-3 Platform ZIP File Usage
Filenames Frequency Notes
RAP_DATA_HIST.zip
Ad Hoc
Used for:
  •  Historical files, such as sales and inventory history for the last 1-2 years.
  •  Loading initial dimensions, such as calendar, merchandise, and location hierarchies prior to history loads.
  •  Initial seeding loads.
RAP_DATA_HIST.zip.1
RAP_DATA_HIST.zip.2 …
RAP_DATA_HIST.zip.N
Ad Hoc / Intraday
Multiple zip uploads are supported for sending historical fact data which should be loaded sequentially. Append a sequence number on the ZIP files starting from 1 and increasing to N, where N is the number of files you are loading. Track the status of the files in C_HIST_FILES_LOAD_STATUS table.
RAP_DATA.zip
RI_RMS_DATA.zip
RI_CE_DATA.zip
RI_MFP_DATA.zip
RI_EXT_DATA.zip
Daily
Can be used for daily ongoing loads into the platform (for RI and foundation common inputs), and for any daily data going to downstream applications through AIF DATA nightly batch. Different files can be used for different source systems.
RI_REPROCESS_DATA.zip
Ad Hoc
Used to upload individual files which will be appended into an existing nightly batch file set.
ORASE_WEEKLY_ADHOC.zip
Ad Hoc
Used for loading AI Foundation files with ad hoc processes.
ORASE_WEEKLY.zip
Weekly
Used for weekly batch files sent directly to AI Foundation.
ORASE_INTRADAY.zip
Intraday
Used for intraday batch files sent directly to AI Foundation.
Other supported file packages, such as output files and optional input files, are detailed in each module’s implementation guides. Except for Planning-specific integrations and customizations (which support additional integration paths and formats), it is expected that all files will be communicated to the platform using one of the filenames above.
Preparing to Load Data
Implementations can follow this general outline for the data load process:
  1. Initialize the business and system calendars and configure partitioning parameters, which prepares the database for loading fact data.
  2. Load initial dimension data into the dimension and hierarchy tables and perform validation checks on the data from DV/APEX or using RI reports.
  3. If implementing any AI Foundation or Planning module, load the dimension data to those systems now. Data might work fine on the input tables but have issues only visible after processing in those systems. Don’t start loading history data if your dimensions are not working with all target applications.
  4. Load the first set of history files (for example, one month of sales or inventory) and validate the results using DV/APEX.
  5. If implementing any AI Foundation or Planning module, stop here and load the history data to those systems as well. Validate that the history data in those systems is complete and accurate per your business requirements.
  6. Continue loading history data into RAP until you are finished with all data. You can stop at any time to move some of the data into downstream modules for validation purposes.
  7. After history loads are complete, all positional tables, such as Inventory Position, need to be seeded with a full snapshot of source data before they can be loaded using regular nightly batches. This seeding process is used to create a starting position in the database which can be incremented by daily delta extracts. These full-snapshot files can be included in the first nightly batch you run, if you want to avoid manually loading each seed file through one-off executions.
  8. When all history and seeding loads are completed and downstream systems are also populated with that data, nightly batches can be started.
Before you begin this process, it is best to prepare your working environment by identifying the tools and connections needed for all your Oracle cloud services that will allow you to interact with the platform, as detailed in Implementation Tools and Data File Generation.
Prerequisites for loading files and running POM processes include:
Prerequisite Tool / Process
Upload ZIPs to Object Storage
File Transfer Service (FTS) scripts
Invoke adhoc jobs to unpack and load the data
Postman (or similar REST API tool)
Monitor job progress after invoking POM commands
POM UI (Batch Monitoring tab)
Monitoring data loads
APEX / DV (direct SQL queries)
Users must also have the necessary permissions in Oracle Cloud Infrastructure Identity and Access Management (OCI IAM) to perform all the implementation tasks. Before you begin, ensure that your user has at least the following groups (and their _PREPROD equivalents if using a stage/dev environment):
Access Needed Groups Needed
Batch Job Execution
BATCH_ADMINISTRATOR_JOB
PROCESS_SERVICE_ADMIN_JOB
Database Monitoring
<tenant ID>-DVContentAuthor (DV)
DATA_SCIENCE_ADMINISTRATOR_JOB (APEX)
Retail Home
RETAIL_HOME_ADMIN
PLATFORM_SERVICES_ADMINISTRATOR
PLATFORM_SERVICES_ADMINISTRATOR_ABSTRACT
RI and AI Foundation Configurations
ADMINISTRATOR_JOB
MFP Configurations
MFP_ADMIN_STAGE / PROD
IPO Configurations
IPO_ADMIN_STAGE / PROD
AP Configurations
AP_ADMIN_STAGE / PROD
Managing System Dates
All Retail Analytics and Planning solutions operate on calendar-based data, but the way the current date is tracked and used is specific to each application due to their unique data needs and business processes. Anytime this document uses terms like “current date” or “today’s date”, it is not referring to the actual calendar date. These terms refer to the date of the business calendar the application is treating as the current day of processing for any operations it will perform on calendar-based data. Understanding how each application sets and uses this date is critical to working with any RAP solution.
Data Warehouse Current Business Date
Locating the Current Date
The shared data warehouse used for integrating data to all RAP solutions has a specific table used to track the current date, named W_RTL_CURR_MCAL_G. This table tracks the current day of the fiscal calendar that all data being processed is relative to, as well as related primary key values used during data loads of calendar information. The most important value in this table is in column MCAL_NUM on the row where MCAL_TYPE = ‘DT’. This date (in YYYYMMDD format) is the current business date used by all processes in the AIF DATA batch schedule in POM. Anytime a date value is needed by any job in that schedule, this is the value that will be referenced. This value impacts many of your implementation activities, as detailed below:
  • Dimension data, such as the product and location hierarchy, includes fields for the effective start and end dates of each record, and some tables may use the current business date in W_RTL_CURR_MCAL_G as the effective start date of the record. That record would then be considered as active and valid only from that date forwards. Attempting to use these records prior to the effective start date will not be allowed by many data warehouse programs.
  • Some programs in the AIF DATA batch jobs will behave differently when you are running them for the first time on a given business date, compared to if you re-run them again within the same date. Most programs in the nightly batch are designed to run only once per business date and it is not recommended to run them again for the same date unless Oracle advises it as part of resolving a Service Request.
  • Data warehouse table partitions are created by calendar date and are generated for a range of time before and after the current business date in W_RTL_CURR_MCAL_G.
  • There is a classification of fact data known as positional data, which includes Inventory Positions and Purchase Orders. These datasets are always loaded for the current business date in the nightly batch cycle. All positional datasets load daily data by inserting database records for the current business date from W_RTL_CURR_MCAL_G. Positional data cannot be loaded for any other date except when using specific history load programs in ad hoc processes.
  • Integrations from the data warehouse to other systems such as Merchandise Financial Planning use the current business date as a point of reference where needed. Positional data like inventory positions is always exported relative to the current business date. Calculated values like the end-of-week date on purchase order amounts will be derived from the current date.
Maintaining the Current Date
The current business date in the data warehouse cannot be changed directly; it requires the use of two specific batch programs (one for ad hoc execution and a different one for nightly batches). For directly setting the current business date outside of the nightly batch, use the standalone process RESET_BUSINESS_DATE_ADHOC, which has just one job named RESET_BUSINESS_DATE_JOB. Edit the POM job parameter to specify the business date to set and it will directly move the data warehouse business date to that value in the W_RTL_CURR_MCAL_G table. In the nightly batch, W_RTL_CURR_MCAL_G_JOB will advance the business date by one day each time it runs, so it does not require any input parameters, as it always uses the prior values from W_RTL_CURR_MCAL_G.
During an implementation, you must update the current business date at the following times:
  • Initial dimension load requires that you move the date back into the past, to a point where your historical data will start. This past date must fall within the range of dates provided in your initial calendar file. Having the date in the past ensures the effective start date on dimension records is sufficiently far back to allow for loading fact data on it. You must keep the current business date in the past, preferably not changing it at all, until you finish all history loads.
  • When loading seed data for positional facts prior to starting nightly batch, you must set the current business date to match the date in the seed data being loaded.
  • Before starting nightly batches, the current business date must be one day prior to the first batch date. This allows the first execution of W_RTL_CURR_MCAL_G_JOB in the nightly batch to advance the date to the current date of incoming data.
From an end-user perspective, the current business date in the data warehouse represents the most recent date of data that has been processed by the system. For example, if the incoming data files for the nightly batch contain data for 2024-09-17, then the current business date at the end of that nightly batch run will also be 2024-09-17. This is typically going to be one day behind the actual current date on a calendar, because the data warehouse only processes complete days of information, so it will be current through close-of-business for yesterday’s date. This is distinctly different from operational systems like Merchandising Foundation Cloud Services (MFCS), which always wants to be on the actual current date because those systems are working with real-time information. For the scenario where the data warehouse has 2024-09-17 as the current date, MFCS will have 2024-09-18 as the current date at the end of its own batch. Similarly, the date displayed in the POM application is not linked with the date in the data warehouse. After the nightly schedule finishes, the POM date will show today’s date. Again, this is one day later than the data warehouse current business date.
Business Date Validation
The AIF DATA nightly batch includes validation of the current business date at two different points. These validations are used to ensure the correct dataset for the current business date is the one being processed, and you have not accidentally started a batch for the wrong date.
The first validation happens in the job BATCH_VALIDATION_JOB. It will compare the date currently in the W_RTL_CURR_MCAL_G table with the incoming business date on your new data. The date used for comparison will come either as a row on the file RA_SRC_CURR_PARAM_G.dat (if it exists) which you would be uploading as part of the nightly batch files, or it will be read directly from the table RA_SRC_CURR_PARAM_G when it is being integrated directly from Merchandising Foundation Cloud Service (MFCS). The validation specifically checks that the incoming data is one day later than the current business date and it will fail in all other cases. Using the previous examples, if your current business date is 2024-09-17 in W_RTL_CURR_MCAL_G then the incoming date on RA_SRC_CURR_PARAM_G must be 2024-09-18, as this represents the date you are now loading data for.
The second validation happens in the job FACT_POSFACT_VALIDATOR_JOB. It will compare the date currently in the W_RTL_CURR_MCAL_G table (after it has been advanced to the next day) with the dates in the DAY_DT column of every positional fact table, such as W_RTL_INV_IT_LC_DY_FS and W_RTL_PRICE_IT_LC_DY_FS. Positional fact data must always be provided for the current date only because these facts do not support posting to past or future dates. The job will fail if any dates do not exactly match. This validation ensures that you did not accidentally include positional fact data files from a prior date, which can happen if you had some issue producing new data in your source systems and allowed an old file to be uploaded for the next batch run.
AI Foundation Date Usage
AI Foundation applications typically operate on wide ranges of dates rather than one specific date at a time, so they do not always need to know what today’s date is. Instead, integrations between the data warehouse and AIF applications will usually be based on the range of dates currently in the data warehouse tables at the time a given job executes, combined with input date parameters on the AIF job itself. For example, the first time you run the sales transaction load using AIF APPS programs, it will identify the range of dates in the data warehouse table and import all of that data in chronological order. When running the program to extract sales in the nightly batch for AIF APPS, it will only extract data that has been created or changed since the last time it ran, so it does not really matter what the current business date in the data warehouse is. If an AIF application does need to manage some form of current business date, it will do so by updating a parameter on the RSE_CONFIG table. Only the Inventory Optimization module does this currently, using the parameter IO_CURRENT_DATE. If you are ever unsure the date Inventory Optimization is using while executing, you can query this parameter to get that information.
Programs internal to the AIF APPS batch schedule also track the last date they processed data for using a table named RSE_PROC_STAT. This table ensures that programs are aware of which dates have already been processed, such that the next time they execute they will look for the next available period of time and not re-run past periods. A common reason to look at the RSE_PROC_STAT table is when you encounter an AIF APPS program that appears to do nothing, and you expected it to produce some output. It may not have done any work because it has already run for a certain date, recorded that date in RSE_PROC_STAT, and there is no new data available after that date, so the program ends immediately. During an implementation, you may encounter times when you need to delete some dates in RSE_PROC_STAT to force a re-run of all past dates of data.
Planning Application Date Usage
Planning applications built on the RPAS platform, such as Merchandise Financial Planning (MFP), have their own concept of current business date centered around a variable named RPAS_TODAY. The value of RPAS_TODAY is initially managed by the implementation team, as it affects many aspects of the planning application functionality, such as which weeks are considered elapsed or unelapsed in workbooks. The value of RPAS_TODAY is updated using the List/Set/Unset PDS Environment Variables task in the RPAS online administration tools (OAT). The value of RPAS_TODAY is not linked with the data warehouse, nor with AI Foundation applications, so it is remember which dates are being used when integrating data between applications. During implementation, it is expected that RPAS_TODAY will be controlled separately from the other systems and they will usually not align until you start running nightly batches.
When using POM for executing batches for a planning application, the value of RPAS_TODAY should by unset within OAT, and then it will automatically use the current business date as defined in the POM UI, plus or minus an offset value if you need the application to run for a different date than the date displayed on the POM UI. This process is explained in more detail in the Retail Predictive Application Server Cloud Edition Administration Guide chapter “RPASCE Batch Schedule with POM”. Only planning applications use the POM date; Retail Insights and AI Foundation applications do not reference the POM date at any time.
Calendar Setup
This is the first step that must be performed in all new environments, regardless of applications being implemented or source systems being used. Before beginning this step, ensure your configurations are complete per the initial configuration sections in the prior chapter. For example, your START_DT and END_DT variables must be set correctly for your Gregorian calendar range (START_DT at least 12 months before start of history data and END_DT at least 2 years into the future). C_MODULE_EXACT_TABLE must be configured if you need PLAN partitions for planning data loads.
  1. Upload the calendar file CALENDAR.csv (and associated context file) through Object Storage (packaged using the RAP_DATA_HIST.zip file). If you are using Merchandising Foundation Cloud Service, then you may extract the calendar from that system instead, following the guidance in section Using RDE for Calendar Setup (Gen 2 Architecture). The calendar extract from MFCS will move the data only as far as the W_MCAL_PERIOD_DS table, so steps 4+ here are still required.
  2. Locate the HIST_ZIP_FILE_LOAD_ADHOC process in the AIF DATA schedule, and verify all jobs are enabled. Execute the process from the UI or using an external API invocation. Example Postman message body:
    "cycleName":"Adhoc",
    "flowName":"Adhoc",
    "processName":"HIST_ZIP_FILE_LOAD_ADHOC"
  3. Verify that the jobs in the ZIP file load process completed successfully using the POM Monitoring screen. Download logs for the tasks as needed for review.
  4. Locate the CALENDAR_LOAD_ADHOC process in the AIF DATA schedule. By default, you should enable all jobs in the process. If using an MFCS calendar extract, then disable the job SI_W_MCAL_PERIOD_DS_JOB because this would overwrite the MFCS calendar with the file-based input data.
  5. Locate the job CREATE_PARTITION_PRESETUP_JOB and edit the parameters for the job. Specify a date in format YYYY-MM-DD that is before the start of your historical data but still within the range of fiscal calendar periods you plan to load. This job is responsible for setting the first date that all calendar-based partitions can be created for in the data warehouse. It automates the configuration of the C_MODULE_ARTIFACT table column PARTITION_HISTORY_DATE and should not be skipped or disabled. If you do not run this job now, then you will be required to manually update C_MODULE_ARTIFACT table before proceeding to load other data.
  6. Execute the CALENDAR_LOAD_ADHOC process. This transforms the calendar data and moves it into all internal data warehouse tables. If you are calling the process from an API, then a sample message body is below:
    Sample Postman message body:
      "flowName":"Adhoc",
      "processName":"CALENDAR_LOAD_ADHOC",
      "requestParameters":"jobParams.CREATE_PARTITION_PRESETUP_JOB=2022-02-06"
  7. If this is your first time loading a calendar file, check the RI_DIM_VALIDATION_V view to confirm no warnings or errors are detected. Refer to the AI Foundation Operations Guide for more details on the validations performed. The validation job will fail if it doesn’t detect data moved to the final table (W_MCAL_PERIOD_D). Refer to Sample Validation SQLs for sample queries you can use to check the data.
  8. If the process failed and you need to start over with a new file/extract, you must Restart the Schedule in POM and then run the ad hoc process C_LOAD_DATES_CLEANUP_ADHOC before repeating these steps. This will remove any load statuses from the prior run and give you a clean start on the next execution.
    If any job having STG in the name fails during the run, then review the POM logs and it should provide the name of an external LOG or BAD table with more information. These error tables can be accessed from APEX using a support utility. Refer to the AI Foundation Operations Guide section on “External Table Load Logs” for the utility syntax and examples.
    Once the full process completes successfully, you should verify your data in the core calendar tables in a data warehouse such as W_MCAL_DAY_D, W_MCAL_WEEK_D, and W_MCAL_PERIOD_D. This process is only for populating the data warehouse, it does not move the calendar to the AIF or RPAS applications as there are separate programs for those integrations.
Loading Data from Files
When history and initial seed data comes from flat files, use the following tasks to upload them into RAP:
Table 3-4 Flat File Load Overview
Activity Description
Initialize Dimensions
Initialize dimensional data (products, locations, and so on) to provide a starting point for historical records to join with. Separate initial load processes are provided for this task.
Load History Data
Run history loads in one or multiple cycles depending on the data volume, starting from the earliest date in history and loading forward to today.
Reloading Dimensions
Reload dimensional data as needed throughout the process to maintain correct key values for all fact data. Dimensional files can be provided in the same package with history files and ad hoc processes run in sequence when loading.
Seed Positional Facts
Seed initial values for positional facts using full snapshots of all active item/locations in the source system. This must be loaded for the date prior to the start of nightly batches to avoid gaps in ongoing data.
Run Nightly Batches
Nightly batches must be started from the business date after the initial seeding was performed.
Completing these steps will load all of your data into the Retail Insights data model, which is required for all implementations. From there, proceed with moving data downstream to other applications as needed, such as AI Foundation modules and Merchandise Financial Planning.
All steps are provided sequentially, but can be executed in parallel. For example, you may load dimensions into RI, then on to AI Foundation and Planning applications before loading any historical fact data. While historical fact data is loaded, other activities can occur in Planning such as the domain build and configuration updates.
Loading Dimensions into RI
You cannot load any fact data into the platform until the related dimensions have been processed and verified. The processes in this section are provided to initialize the core dimensions needed to begin fact data loads and verify file formats and data completeness. Some dimensions which are not used in history loads are not part of the initialization process, as they are expected to come in the nightly batches at a later time.
For the complete list of dimension files and their file specifications, refer to the RAP Data Dictionary workbook in your Oracle Analytics catalog. The steps below assume you have enabled or disabled the appropriate dimension loaders in POM per your requirements. The process flow examples also assume CSV file usage, different programs are available for legacy DAT files. The AI Foundation Operations Guide provides a list of all the job and process flows used by foundation data files, so you can identify the jobs required for your files and disable unused programs in POM.
When you are using RDE jobs to source dimension data from RMFCS and you are not providing any flat files like PRODUCT.csv, it is necessary to disable all file-based loaders in the RI_DIM_INITIAL_ADHOC process flow from POM. Any job name starting with the following text can be disabled, because RDE jobs will bypass these steps and insert directly to staging tables:
  • COPY_SI_
  • STG_SI_
  • SI_
  • STAGING_SI_
  1. Disable any dimension jobs you are not using from Batch Administration, referring to the process flows for DAT and CSV files in the AIF Operations Guide as needed. If you are not sure if you need to disable a job, it’s best to leave it enabled initially. Restart the POM schedule in Batch Monitoring to apply the changes.
  2. Provide your dimension files and context files through File Transfer Services (packaged using the RAP_DATA_HIST.zip file). All files should be included in a single zip file upload. If you are using data from Merchandising, this is where you should run the RDE ADHOC processes such as RDE_DIM_FLOW_ADHOC.
  3. Execute the HIST_ZIP_FILE_LOAD_ADHOC process if you need to unpack a new ZIP file.
  4. If you are using DAT file formats (such as when RDE v19 or earlier is used to produce an RIHIST_RMS_DATA.zip package) then you need to use the DAT_REPROCESS_ADHOC process to import your files and stage them for further processing. For all other use cases, skip this step.
  5. Execute the RI_DIM_INITIAL_ADHOC process to stage, transform, and load your dimension data from the files. If using the POM UI, then before starting the process you must edit the parameter on the job ETL_BUSINESS_DATE_JOB. The ETL date on the command should be at a minimum one day before the start of your history load timeframe, but 3-6 months before is ideal. It is best to give yourself a few months of space for reprocessing dimension loads on different dates prior to start of history, but the date must also fall within the range of fiscal periods you loaded in the calendar. Date format is YYYY-MM-DD; any other format will not be processed. After running the process, you can verify the dates are correct in the W_RTL_CURR_MCAL_G table. If you are using an API call to start the process, then a sample message body is below:
      "flowName":"Adhoc",
      "processName":"RI_DIM_INITIAL_ADHOC",
      "requestParameters":"jobParams.ETL_BUSINESS_DATE_JOB=2021-12-31"
If this is your first dimension load, you will want to validate the core dimensions such as product and location hierarchies using APEX. Refer to Sample Validation SQLs for sample queries you can use for this.
If any jobs fail during this load process, you may need to alter one or more dimension data files, re-send them in a new zip file upload, and re-execute the programs. Only after all core dimension files have been loaded (CALENDAR, PRODUCT, ORGANIZATION, and EXCH_RATE) can you proceed to history loads for fact data. Make sure to query the RI_DIM_VALIDATION_V view for any warnings/errors after the run. Refer to the AI Foundation Operations Guide for more details on the validation messages that may occur. This view primarily uses the table C_DIM_VALIDATE_RESULT, which can be separately queried instead of the view to see all the columns available on it.
If you need to reload the same file multiple times due to errors, you must Restart the Schedule in POM and then run the ad hoc process C_LOAD_DATES_CLEANUP_ADHOC before repeating these steps. This will remove any load statuses from the prior run and give you a clean start on the next execution.
Starting with version 23.1.101.0, the product and organization file loaders have been redesigned specifically for the initial ad hoc loads. In prior versions, you must not reload multiple product or organization files for the same ETL business date, as it treats any changes as a reclassification and can cause data issues while loading history. In version 23.x, the dimensions are handled as “Type 1” slowly changing dimensions, meaning the programs do not look for reclasses and instead perform simple merge logic to apply the latest hierarchy data to the existing records, even if levels have changed.
As a best practice, you should disable all POM jobs in the RI_DIM_INITIAL_ADHOC process except the ones you are providing new files for. For example, if you are loading the PRODUCT, ORGANIZATION, and EXCH_RATE files as your dimension data for AI Foundation, then you could just execute the set of jobs for those files and disable the others. Refer to the AI Foundation Operations Guide for a list of the POM jobs involved in loading each foundation file, if you wish to disable jobs you do not plan to use to streamline the load process.
Hierarchy Deactivation
Foundation dimension ad hoc loads are treated differently than the nightly batch programs specifically for product and location data. They use Type 1 slowly-changing dimension (SCD) behavior, which means that the system will not create new records every time a parent/child relationship changes (also known as reclassification). Instead, they will perform a simple merge on top of existing data to maintain as-is hierarchy definitions. If you change hierarchy classifications on items or locations from one dimension load to the next, the old classifications are overwritten and lost.
The foundation data model holds hierarchy records separately from product data, so it is also necessary to perform maintenance on hierarchies to maintain a single active set of records that should be propagated downstream to other RAP applications. This maintenance is performed using the program W_PROD_CAT_DH_CLOSE_JOB in the RI_DIM_INITIAL_ADHOC process. The program will detect unused hierarchy nodes which have no children after the latest data has been loaded into W_PROD_CAT_DH and it will close them (set to CURRENT_FLG=N). This is required because, in the data model, each hierarchy level is stored as a separate record, even if that level is not being used by any products on other tables. Without the cleanup activity, unused hierarchy levels would accumulate in W_PROD_CAT_DH and be available in AI Foundation, which is generally not desired.
There are some scenarios where you may want to disable this program. For example, if you know the hierarchy is going to change significantly over a period of time and you don’t want levels to be closed and re-created every time a new file is loaded, you must disable W_PROD_CAT_DH_CLOSE_JOB. You can re-enable it later and it will close any unused levels that remain after all your changes are processed. Also be aware that the program is part of the nightly batch process too, so once you switch from historical to nightly loads, this job will be enabled and will close unused hierarchy levels unless you intentionally disable it. This job must be disabled if you are using RDE programs to load Merchandising data from Merchandising Foundation Cloud Services (MFCS), because the hierarchy is automatically maintained without using this job..
Loading Dimensions to Other Applications
Once you have successfully loaded dimension data, you should pause the dataload process and push the dimensions to AI Foundation Cloud Services and the Planning Data Store (if applicable). This allows for parallel data validation and domain build activities to occur while you continue loading data. Review sections Sending Data to AI Foundation Applications and Sending Data to Planning Applications for details on the POM jobs you may execute for this.
The main benefits of this order of execution are:
  1. Validating the hierarchy structure from the AI Foundation interface provides an early view for the customer to see some application screens with their data.
  2. Planning apps can perform the domain build activity without waiting for history file loads to complete, and can start to do other planning implementation activities in parallel to the history loads.
  3. Data can be made available for custom development or validations in Innovation Workbench.
Do not start history loads for facts until you are confident all dimensions are working throughout your solutions. Once you begin loading facts, it becomes much harder to reload dimension data without impacts to other areas. For example, historical fact data already loaded will not be automatically re-associated with hierarchy changes loaded later in the process.
Load History Data
Historical fact data is a core foundational element to all solutions in Retail Analytics and Planning. As such, this phase of the implementation can take the longest amount of time during the project, depending on the volumes of data, the source of the data, and the amount of transformation and validation that needs to be completed before and after loading it into the Oracle database.
It is important to know where in the RAP database you can look to find what data has been processed, what data may have been rejected or dropped due to issues, and how far along in the overall load process you are. The following tables provide critical pieces of information throughout the history load process and can be queried from APEX.
Table 3-5 Inbound Load Status Tables
Table Usage
C_HIST_LOAD_STATUS
Tracks the progress of historical ad hoc load programs for inventory and pricing facts. This table will tell you which Retail Insights tables are being populated with historical data, the most recent status of the job executions, and the most recently completed period of historical data for each table. Use APEX or Oracle Analytics to query this table after historical data load runs to ensure the programs are completing successfully and processing the expected historical time periods.
Tracks the progress of zip file processing when loading multiple files in sequence using scheduled standalone process flows.
C_LOAD_DATES
Tracks the status of jobs run from the AIF DATA schedule in POM that involve extracting, transforming, or loading data. When a job has an entry in this table, restarting it will behave differently from the initial run. Restarting a job with a “Success” status will skip the job and do nothing. Restarting a job with “Failed” status will attempt to re-run the job.
C_LOAD_DATES_DETAILS
Tracks the individual steps of a program in C_LOAD_DATES when task-level restartability is enabled. Managing the steps of a program on this table allows for a failed run of a job to restart from the step where it failed, instead of starting from the beginning of the program. If you need to start a program over from the beginning, you would have to purge all the records from both C_LOAD_DATES and C_LOAD_DATES_DETAILS tables.
W_ETL_REJECTED_RECORDS
Summary table capturing rejected fact record counts that do not get processed into their target tables in Retail Insights. Use this to identify other tables with specific rejected data to analyze. Does not apply to dimensions, which do not have rejected record support at this time.
E$_W_RTL_SLS_TRX_IT_LC_DY_TMP
Example of a rejected record detail table for Sales Transactions. All rejected record tables start with the E$_ prefix. These tables are created at the moment the first rejection occurs for a load program. W_ETL_REJECTED_RECORDS will tell you which tables contain rejected data for a load. These tables may not initially be granted to APEX for you to read from. To grant access, run the REFRESH_GRANT_SYNONYM_ADHOC ad hoc process in the AIF DATA schedule in POM. This will allow you to select from these error tables to review rejection details.
When loading data from flat files for the first time, it is common to have bad records that cannot be processed by the RAP load procedures, such as when the identifiers on the record are not present in the associated dimension tables. The foundation data loads leverage rejected record tables to capture all such data so you can see what was dropped by specific data load and needs to be corrected and reloaded. These tables do not exist until rejected records occur during program execution, and are not initially granted to APEX unless you have run REFRESH_GRANT_SYNONYM_ADHOC. Periodically monitor these tables for rejected data which may require reloading.
The overall sequence of files to load will depend on your specific data sources and conversion activities, but the recommendation is listed below as a guideline.
  1. Sales – Sales transaction data is usually first to be loaded, as the data is critical to running most applications and needs the least amount of conversion.
  2. Inventory Receipts – If you need receipt dates for downstream usage, such as in Lifecycle Pricing Optimization, then you need to load receipt transactions in parallel with Inventory Positions. For each file of receipts loaded, also load the associated inventory positions afterwards.
  3. Inventory Position – The main stock-on-hand positions file is loaded next. This history load also calculates and stores data using the receipts file, so INVENTORY.csv and RECEIPT.csv must be loaded at the same time, for the same periods.
  4. Pricing – The price history file is loaded after sales and inventory are complete because many applications need only the first two datasets for processing. Potentially, price history may also be the largest volume of data; so it’s good to be working within your other applications in parallel with loading price data.
  5. All other facts – There is no specific order to load any of the other facts like transfers, adjustments, markdowns, costs, and so on. They can be loaded based on your downstream application needs and the availability of the data files.
For your first time implementing this history load process, you may also leverage the reference paper and scripts in My Oracle Support (Doc ID 2539848.1) titled AI Foundation Historical Data Load Monitoring. This document will guide you through one way you can monitor the progress of history loads, gather statistics on commonly used tables, and verify that data is moving from the input tables to the target tables in the database.
Automated History Loads
Once you have performed your history loads manually a couple of times (following all steps in later sections) and validated the data is correct, you may wish to automate the remaining file loads. A standalone process flow RI_FLOW_ADHOC is available in POM that can run the fact history loads multiple times using your specified start times. Follow the steps below to enable this process:
  1. Upload multiple ZIP files using FTS, each containing one set of files for the same historical period. Name the files like RAP_DATA_HIST.zip, RAP_DATA_HIST.zip.1, RAP_DATA_HIST.zip.2 and so on, incrementing the index on the end of the zip file name after the first one.
  2. In the POM batch administration screen, ensure all of the jobs in the RI_FLOW_ADHOC are enabled, matching your initial fact history standalone runs. The following processes in the process flow are common to all runs and all jobs should be enabled in them:
    • FLOW_LOAD_START_PROCESS
    • FLOW_LOAD_END_PROCESS
    • CLEANUP_C_LOAD_DATES_FLOW_PROCESS
    • ZIP_FILE_LOAD_FLOW_PROCESS
    • FACT_FLOW_END_PROCESS
  3. Schedule the standalone flows from Scheduler Administration to occur at various intervals throughout the day. Space out the cycles based on how long it took to process your first file.
  4. Monitor the load progress from the Batch Monitoring screen to see the results from each run. Monitor the table C_HIST_FILES_LOAD_STATUS to verify the ZIP files you uploaded were all processed successfully. Validate that data is being loaded successfully in your database periodically throughout the standalone runs. If a run fails for any reason, it will not allow more runs to proceed until the issue is resolved.
Sales History Load
RAP supports the loading of sales transaction history using actual transaction data or daily/weekly sales totals. If loading data at an aggregate level, all key columns (such as the transaction ID) are still required to have some value. The sales data may be provided for a range of dates in a single file. The data should be loaded sequentially from the earliest week to the latest week but, unlike inventory position, you may have gaps or out-of-order loads, because the data is not stored positionally. Refer to Data File Generation for more details on the file requirements.
Many parts of AI Foundation require transactional data for sales, so loading aggregate data should not be done unless you have no better alternative.
If you are not loading sales history for Retail Insights specifically, then there are many aggregation programs that can be disabled in the POM standalone process. Most aggregation programs (jobs ending in _A_JOB) populate additional tables used only in BI reporting. The following list of jobs must be enabled in the HIST_SALES_LOAD_ADHOC process to support AIF and Planning data needs, but all others can be disabled for non-RI projects:
  • VARIABLE_REFRESH_JOB
  • ETL_REFRESH_RI_JOB
  • W_EMPLOYEE_D_JOB
  • SEED_EMPLOYEE_D_JOB
  • W_PARTY_PER_D_JOB
  • SEED_PARTY_PER_D_JOB
  • W_RTL_CO_HEAD_D_JOB
  • W_RTL_CO_LINE_D_JOB
  • SEED_CO_HEAD_D_JOB
  • SEED_CO_LINE_D_JOB
  • W_RTL_SLS_TRX_IT_LC_DY_F_JOB
  • RA_ERROR_COLLECTION_JOB
  • RI_GRANT_ACCESS_JOB
  • RI_CREATE_SYNONYM_JOB
  • ANAYLZE_TEMP_TABLES_JOB
  • W_RTL_SLS_IT_LC_DY_TMP_JOB
  • W_RTL_SLS_IT_LC_WK_A_JOB
  • W_RTL_PROMO_D_TL_JOB
  • SEED_PROMO_D_TL_JOB
  • W_PROMO_D_RTL_TMP_JOB
  • W_RTL_SLSPR_TRX_IT_LC_DY_F_JOB
  • W_RTL_SLSPK_IT_LC_DY_F_JOB
  • W_RTL_SLSPK_IT_LC_WK_A_JOB
  • REFRESH_RADM_JOB
The other process used, HIST_STG_CSV_SALES_LOAD_ADHOC, can be run with all jobs enabled, as it is only responsible for staging the files in the database. Make sure to check the enabled jobs in both processes before continuing.
If you will be loading extremely large volumes of data in a single file (100M+ records), then you may encounter issues where the POM job to load the file completes before the file is finished importing. This is due to a default maximum runtime of 3600 seconds on these types of POM jobs. You may increase the maximum runtime by editing the job parameters of COPY and STG job types to append the parameter: maxRunTime=12345. The numeric value should be the number of seconds you expect the process to run for. For example, locate the jobs COPY_SI_SALES_JOB and STG_SI_SALES_JOB in the process HIST_STG_CSV_SALES_LOAD_ADHOC, then edit the parameters to look like the below:
disJobType=OBJ_STORE_PUT||object=ri/data/staging/SALES.csv||objectFilepath=/u01/retail/ri/mmhome/data/staging/SALES.csv|| maxRunTime=25200
disJobType=EXT_TBL_LOAD||tblName=W_RTL_SLS_TRX_IT_LC_DY_FTXS||fileName=ri/data/staging/SALES.csv|| maxRunTime=25200
Always edit the parameters from Batch Administration and then restart your POM schedule to apply the changes in Batch Monitoring.
After confirming the list of enabled sales jobs and applying any necessary configuration changes, perform the following steps:
  1. Create the file SALES.csv containing one or more days of sales data along with a CTX file defining the columns which are populated. Optionally include the SALES_PACK.csv file as well.
  2. Upload the history files to Object Storage using the RAP_DATA_HIST.zip file.
  3. Execute the HIST_ZIP_FILE_LOAD_ADHOC process.
  4. Execute the HIST_STG_CSV_SALES_LOAD_ADHOC process to stage the data in the database. Validate your data before proceeding. Refer to Sample Validation SQLs for sample queries you can use for this.
  5. Execute the HIST_SALES_LOAD_ADHOC batch processes to load the data. If no data is available for certain dimensions used by sales, then the load process can seed the dimension from the history file automatically. Enable seeding for all of the dimensions according to the initial configuration guidelines; providing the data in other files is optional.
    Several supplemental dimensions are involved in this load process, which may or may not be provided depending on the data requirements. For example, sales history data has promotion identifiers, which would require data on the promotion dimension.
    Sample Postman message bodies:
      "flowName":"Adhoc",
      "processName":"HIST_STG_CSV_SALES_LOAD_ADHOC"
      "flowName":"Adhoc",
      "processName":"HIST_SALES_LOAD_ADHOC"
After the load is complete, you should check for rejected records, as this will not cause the job to fail but it will mean not all data was loaded successfully. Query the table W_ETL_REJECTED_RECORDS from IW to see a summary of rejections. If you cannot immediately identify the root cause (for example, missing products or locations causing the data load to skip the records) there is a utility job W_RTL_REJECT_DIMENSION_TMP_JOB that allows you analyze the rejections for common reject reasons. Refer to the AIF Operations Guide for details on configuring and running the job for the first time if you have not used it before.
This process can be repeated as many times as needed to load all history files for the sales transaction data. If you are sending data to multiple RAP applications, do not wait until all data files are processed to start using those applications. Instead, load a month or two of data files and process them into all apps to verify the flows before continuing.
Data cannot be reloaded for the same records multiple times, as sales data is treated as additive. If data needs correction, you must post only the delta records (for example, send -5 to reduce a value by 5 units) or erase the table and restart the load process using RI_SUPPORT_UTIL procedures in APEX. Raise a Service Request with Oracle if neither of these options resolve your issue.
Once you have performed the load and validated the data one time, you may wish to automate the remaining file loads. A standalone process flow RI_FLOW_ADHOC is available in POM that can run the sales history load multiple times using your specified start times. Follow the steps below to leverage this process:
  1. Upload multiple ZIP files each containing one SALES.csv and naming them as RAP_DATA_HIST.zip, RAP_DATA_HIST.zip.1, RAP_DATA_HIST.zip.2 and so on, incrementing the index on the end of the zip file name. Track the status of the files in the C_HIST_FILES_LOAD_STATUS table once they are uploaded and at least one execution of the HIST_ZIP_FILE_UNLOAD_JOB process has been run.
  2. In the POM batch administration screen, ensure all of the jobs in the RI_FLOW_ADHOC are enabled, matching your initial ad hoc run. Schedule the standalone flows from Scheduler Administration to occur at various intervals throughout the day. Space out the runs based on how long it took to process your first file.
  3. Monitor the load progress from the Batch Monitoring screen to see the results from each run cycle.
Sales History Reloads
Sales is transactional data loaded additively (summing the incoming and existing records). The preferred method for correcting previously loaded sales is to send reversal/revision records or backposted delta records through the standard sales interfaces. This keeps RI, AIF, and other downstream exports and aggregates aligned with the corrected data. Do not load the full records again for data already loaded once, as the result will be a doubling of all values due to the additive load logic.
If you need to reprocess a SALES.csv file that was already loaded, your options are to use the Data Delete utility to remove select portions of the already loaded data, or the Data Cleanup utilities to remove all the data and load new files cleanly. If you only remove the specific records to be reloaded, then you must also follow the load with a run of the Aggregation Utility to regenerate your sales aggregate tables for the reloaded timeframe. Refer to the AIF Operations Guide for more details on these utilities.
Inventory Position History Load
RAP supports the loading of inventory position history using either full end-of-week snapshots or an initial snapshot followed by end-of-week incremental updates.
When using full weekly snapshots, the data may be provided one week at a time or as multiple weeks in a single file. The data must be loaded sequentially from the earliest week to the latest week with no gaps or out-of-order periods. For example, you cannot start with the most recent inventory file and go backward; you must start from the first week of history. Refer to Data File Generation for more details on the file requirements.
When using the initial snapshot followed by incremental updates, you may be able to provide the entire history as one file. The first week of inventory data in the file must be a complete snapshot of all the inventoried item/locations. For every week-ending date after the first, you must only provide the changed records relative to the prior weeks. This includes changes to the inventory where the balance drops to zero for that week. If you still need to split this data across multiple files, the first week in every file must be a full snapshot to establish starting positions for the incremental updates. Using this approach to loading history, the incremental data is applied to the full snapshot and the final end-of-week positions will be all new records in the current week plus unchanged records from the prior weeks. This greatly reduces the size of your history file, but requires you to extract incremental updates from the source system, which is not always possible. If you want to use the incremental inventory history load method, update the parameter RI_INV_HIST_LOAD_INC to a value of Y in C_ODI_PARAM_VW table in the AI Foundation Control & Tactical Center. The default value is N, meaning only full snapshot data is expected. If you plan to load your history data over multiple phases (where each phase is a different set of items or locations) then you cannot use this functionality, the incremental load logic expects the entire set of item/locations to be used in a single historical load activity.
A variety of C_ODI_PARAM_VW settings are also available in the Control Center to disable inventory features that are not required for your implementation. All of the following parameters can be changed to a value of N during the history load and enabled later for daily batches, as it will greatly improve the load times:
  • RI_INVAGE_REQ_IND – Disables calculation of first/last receipt dates and inventory age measures. Receipt date calculation is used in RI and required for Lifecycle Pricing Optimization (as a method of determining entry/exit dates for items). It is also required for Forecasting for the Short Lifecycle (SLC) methods. Set to Y if using any of these applications.
  • RA_CLR_LEVEL – Disables the mapping of clearance event IDs to clearance inventory updates. Used only in RI reporting.
  • RI_PRES_STOCK_IND – Disables use of replenishment data for presentation stock to calculate inventory availability measures. Used only in RI reporting.
  • RI_BOH_SEEDING_IND – Disables the creation of initial beginning-on-hand records so analytics has a non-null starting value in the first week. Used only in RI reporting.
  • RI_MOVE_TO_CLR_IND – Disables calculation of move-to-clearance inventory measures when an item/location goes into or out of clearance status. Used only in RI reporting.
  • RI_MULTI_CURRENCY_IND – Disables recalculation of primary currency amounts if you are only using a single currency. Should be enabled for multi-currency, or disabled otherwise.
If you will be loading inventory history after you have already started nightly batches, then you must also update two additional parameters:
  • INV_NIGHTLY_BATCH_IND – Change this to Y to indicate that nightly batches have been run but you are planning to load history for prior dates
  • INV_LAST_HIST_LOAD_DT – Set this to the final week of history data you plan to load, which must be a week-ending date and it must be before the nightly batches were started
Although it is supported, it is not advisable to load history data after nightly batches have started. It would be difficult to erase or correct historical data after it is loaded without affecting your nightly batch data as well. For this reason it is best to validate the history data thoroughly in a non-production environment before loading it to the production system.
If you will be loading extremely large volumes of data in a single file (100M+ records), then you may encounter issues where the POM job to load the file completes before the file is finished importing. This is due to a default maximum runtime of 3600 seconds on these types of POM jobs. You may increase the maximum runtime by editing the job parameters of COPY and STG job types to append the parameter: maxRunTime=12345. The numeric value should be the number of seconds you expect the process to run for. For example, locate the jobs COPY_SI_INVENTORY_JOB and STG_SI_INVENTORY_JOB in the process HIST_STG_CSV_INV_LOAD_ADHOC, then edit the parameters to look like the below:
disJobType=OBJ_STORE_PUT||object=ri/data/staging/INVENTORY.csv||objectFilepath=/u01/retail/ri/mmhome/data/staging/INVENTORY.csv|| maxRunTime=25200
disJobType=EXT_TBL_LOAD||tblName=W_RTL_INV_IT_LC_DY_FTXS||fileName=ri/data/staging/INVENTORY.csv|| maxRunTime=25200
After confirming the list of enabled inventory jobs and applying any necessary configuration changes, perform the following steps:
  1. If you need inventory to keep track of First/Last Receipt Dates for use in Lifecycle Pricing Optimization or Forecasting (SLC) then you must first load a RECEIPT.csv file for the same historical period as your inventory file (because it is used in forecasting, that may make it required for your Inventory Planning Optimization loads as well, if you plan to use SLC forecasting). You must also set RI_INVAGE_REQ_IND to Y. Receipts are loaded using the process HIST_CSV_INVRECEIPTS_LOAD_ADHOC. Receipts may be provided at day or week level depending on your history needs.
  2. Create the file INVENTORY.csv containing one or more weeks of inventory snapshots in chronological order along with your CTX file to define the columns that are populated. The DAY_DT value on every record must be an end-of-week date (Saturday by default).
  3. Optionally, also include the INVENTORY_PACK.csv file for pack-level inventory history. The main inventory file must only contain regular items and pack component items; it should not contain pack items. The INVENTORY_PACK.csv file is for pack item inventory positions, which are typically held only at warehouses. Pack-level inventory history is only relevant for Retail Insights reporting. Inventory Planning Optimization (IPO) only requires the current inventory positions for pack inventory at the warehouses; it does not need the history.
  4. Upload the history file and its context file to Object Storage using the RAP_DATA_HIST.zip file.
  5. Update column HIST_LOAD_LAST_DATE on the table C_HIST_LOAD_STATUS to be the date matching the last day of your overall history load (may be later than the dates in the current file). HIST_LOAD_LAST_DATE must be the final week-ending date of the entire planned timeframe. The date must exist as a week-ending date in the retail calendar (W_MCAL_WEEK_D) and must not include a time component other than midnight. This can be updated from the Control & Tactical Center. If you are loading history after your nightly batches were already started, then you must set this date to be the last week-ending date before your first daily/weekly batch. No other date value can be used in this case.
  6. Execute the HIST_ZIP_FILE_LOAD_ADHOC process.
  7. If you are providing RECEIPT.csv for tracking receipt dates in history, run HIST_CSV_INVRECEIPTS_LOAD_ADHOC at this time.
  8. Execute the HIST_STG_CSV_INV_LOAD_ADHOC process to stage your data into the database. Validate your data in W_RTL_INV_IT_LC_DY_FS (and optionally W_RTL_INVPK_IT_LC_DY_FS if using packs) before proceeding. Refer to Sample Validation SQLs for sample queries you can use for this.
  9. Execute the HIST_INV_LOAD_ADHOC batch process to load the file data. The process loops over the files one week at a time until all weeks are loaded. It updates the C_HIST_LOAD_STATUS table with the progress, which you can monitor from APEX or DV. Sample Postman message bodies:
      "flowName":"Adhoc",
      "processName":"HIST_STG_CSV_INV_LOAD_ADHOC"
      "flowName":"Adhoc",
      "processName":"HIST_INV_LOAD_ADHOC"
This process can be repeated as many times as needed to load all history files for the inventory position. Remember that inventory cannot be loaded out of order, and you cannot go back in time to reload files after you have processed them (for the same item/loc intersections). If you load a set of inventory files and then find issues during validation, erase the tables in the database and restart the load with corrected files.
If you finish the entire history load and need to test downstream systems (like Inventory Planning Optimization) then you must populate the table W_RTL_INV_IT_LC_G first (the history load skips this table). There is a separate standalone job HIST_LOAD_INVENTORY_GENERAL_JOB in the process HIST_INV_GENERAL_LOAD_ADHOC that you may execute to copy the final week of inventory from the fact table to this table. IPO also has the ability to use the last available week from W_RTL_INV_IT_LC_WK_A if you are not ready to populate the W_RTL_INV_IT_LC_G table with your final positional data.
Rejected Record Handling
If your inventory history has invalid data, you may get rejected records and the batch process will fail with a message that rejects exist in the data. If this occurs, you cannot proceed until you resolve your input data, because rejections on positional data MUST be resolved for one date before moving onto the next. If you move onto the next date without reprocessing any rejected data, that data is lost and cannot be loaded at a later time without starting over. When this occurs:
  1. The inventory history load will automatically populate the table W_RTL_REJECT_DIMENSION_TMP with a list of invalid dimensions it has identified. If you are running any other jobs besides the history load, you can also run the process W_RTL_REJECT_DIMENSION_TMP_ADHOC to populate that table manually. You have the choice to fix the data and reload new files or proceed with the current file
  2. After reviewing the rejected records, run REJECT_DATA_CLEANUP_ADHOC, which will erase the E$ table and move all rejected dimensions into a skip list. You must pass in the module code you want to clean up data for as a parameter on the POM job (in this case the module code is INV). The skip list is loaded to the table C_DISCARD_DIMM. Skipped identifiers will be ignored for the current file load, and then reset for the start of the next run.
      "flowName":"Adhoc",
      "processName":"REJECT_DATA_CLEANUP_ADHOC",
      "requestParameters":"jobParams.REJECT_DATA_CLEANUP_JOB=INV"
  3. If you want to fix your files instead of continuing the current load, stop here and reload your dimensions and/or fact data following the normal process flows.
  4. If you are resuming with the current file with the intent to skip all data in C_DISCARD_DIMM, restart the failed POM job now. The skipped records are permanently lost and cannot be reloaded unless you erase your inventory data and start loading files from the beginning.
Log a Service Request with Oracle Support for assistance with any of the above steps if you are having difficulties dealing with rejected records.
Unique Constraint Errors
If HIST_INV_LOAD_ADHOC fails with a unique constraint error while inserting to the inventory facts, verify the following:
  1. Check whether the same item/location/week already exists in the target inventory fact tables. If it does, erase the overlapping data in the target table and restart the failed job.
  2. Check the staging (FS) data for duplicate item/location/date rows. If duplicates exist in the staging table, correct the input or staged data, reset HIST_LOAD_STATUS for the TMP table record to INPROGRESS, then rerun the job.
  3. For phased loads, verify that the new phase contains only item/location combinations that are not already present for the same week range. Overlaps must be deleted in the target or source tables before proceeding.
Inventory Phased Loads
Different sets of item/locations can be loaded over different runs of the history load job (also referred to as phased loading of data). For full weekly snapshots, you may simply reset C_HIST_LOAD_STATUS and load the additional item/locations. For incremental history files, you must first erase the data in W_RTL_INV_IT_LC_DY_INC_FS table which has the incremental positions of the already-loaded item locations. Not erasing this table will result in the new load failing, as it attempts to use the old and new incremental data at the same time.
For each additional load phase:
  1. Confirm the phase contains a new distinct item/location set for the week range being loaded.
  2. Reset MAX_COMPLETED_DATE and HIST_LOAD_STATUS only for the enabled inventory history rows for that phase.
  3. Set HIST_LOAD_LAST_DATE to the final week-ending date in the phase.
  4. Run the inventory history load from the earliest week in the phase to the final week.
After the final phase load, include a complete current inventory snapshot in the next nightly batch for all item/location combinations that should exist in current inventory. Additional inventory history phases after the first do not update W_RTL_INV_IT_LC_G with current positions. The current position table must be refreshed by a complete current inventory snapshot in the next nightly batch. If current inventory contains positions that should become zero, include zero-balance rows in the nightly snapshot so the current-position table is adjusted.
Price History Load
Certain applications, such as Lifecycle Pricing Optimization, require price history to perform their calculations. Price history is similar to inventory in that it is a positional, but it can be loaded in a more compressed manner due to the extremely high data volumes involved. The required approach for price history is as follows:
  1. Update C_HIST_LOAD_STATUS for the PRICE records in the table, specifying the last date of history load, just as you did for inventory. For whatever value you put in the HIST_LOAD_LAST_DATE column, ensure that you load price data up to and including that date. There is logic in the history load to refresh the W_RTL_PRICE_IT_LC_G table; that logic only runs on the final day of historical processing. But, if you don’t load files all the way up to that date, it will never run and you may have incorrect data as a result. If you are loading history after your nightly batches already started, then you must set this date to be the last week-ending date before your first daily/weekly batch. No other date value can be used in this case.
  2. Update C_ODI_PARAM parameters based on your implementation plans:
    1. Set parameter PRICE_LAST_HIST_LOAD_DT to equal the final date of history processing. It should match the value used on C_HIST_LOAD_STATUS for HIST_LOAD_LAST_DATE. This parameter sets a threshold after which time only the nightly batch job may be used to load price data. The history load program will not be allowed to load data past this date.
    2. If you are loading prices for LPO applications specifically, then update parameter RI_LAST_MKDN_HIST_IND to have a value of Y. This will populate some required fields for LPO markdown and promotion price history.
  3. Create an initial, full snapshot of price data in PRICE.csv for the first day of history to establish starting positions for all item/locations that already have prices in the source system for that starting date. All initial price records for the historically-active item/locations must come with a type code of 0 to establish the full price of the item/location. If the price of the item/location on that starting date is in a different status like markdown (8) then provide the original full price as a type-0 record one day before that, and then provide the actual price as a different type in the day after that. This establishes both the original full price and current price of all historical item/locations which will come into the database at the start of history.
  4. Create additional PRICE data (added to the same file or using additional files) containing just price changes and new item/location prices with the appropriate price change type codes and effective day dates for those changes. Prices that do not change will not have any additional records after the initial starting positions. Load each file one at a time using the history processes in chronological order. Refer to Data File Generation for complete details on how to build this file.
  5. The history procedure will iterate over the provided files day by day, starting from the first day of history, up to the last historical load date specified in C_HIST_LOAD_STATUS for the pricing fact. For each date, the procedure checks the staging data for effective price change records and loads them, then moves on to the next date.
The overall process to perform price history loads is similar to the inventory load steps, just using different POM jobs. It uses the PRICE.csv file and the HIST_CSV_PRICE_LOAD_ADHOC process (the price load only has one load process instead of two like sales/inventory). Just like inventory, you must load the data sequentially; you cannot back-post price changes to earlier dates than what you have already loaded.
Just like inventory, the REJECT_DATA_CLEANUP_ADHOC process may be used when records are rejected during the load. Price loads cannot continue until you review and clear the rejections.
  "flowName":"Adhoc",
  "requestParameters":"jobParams.REJECT_DATA_CLEANUP_JOB=PRICE"
If HIST_CSV_PRICE_LOAD_ADHOC fails with a unique constraint error while inserting to the price facts, verify the following:
  1. Check whether the same item/location/date already exists in the target price fact tables. If it does, erase the overlapping data in the target table and restart the failed job.
  2. Check the staging (FS) data for duplicate item/location/date rows. The primary key is only item/location/date, you cannot have multiple prices for the same date. If duplicates exist in the staging table, correct the input or staged data, reset HIST_LOAD_STATUS for the TMP table record to INPROGRESS, then rerun the job.
  3. For phased loads, verify that the new phase contains only item/location combinations that are not already present for the same date range. Overlaps must be deleted in the target or source tables before proceeding.
Price Phased Loads
Different sets of item/locations can be loaded over different runs of the history load job (also referred to as phased loading of data). For pricing specifically, you must maintain a parameter HIST_LOAD_PHASEto represent which load cycle you are in, using values such as PHASE1 for the first load phase, PHASE2 for the second load phase, and so on. Use HIST_LOAD_PHASE only for additional phases having a distinct set of item/location combinations. Each phase must have a unique phase value and must not overlap item/location combinations already loaded in earlier phases. The phase parameter controls the set of item/locations which are used for calculated fields over time and for the seeding inserts to quarterly partitions in the base fact table.
  1. Confirm the phase contains a new distinct item/location set for the date range being loaded.
  2. Reset MAX_COMPLETED_DATE and HIST_LOAD_STATUS only for the enabled price history rows for that phase.
  3. Set HIST_LOAD_LAST_DATE to the final date in the data for that phase.
  4. Run the price history load from the earliest date in the phase to the final date.
Price History and Long-Running Loads
Large price history loads can take many hours because the job processes the data by date and may update multiple fact and aggregate tables. Price data is often the largest single dataset to work with due to the number of item/location combinations a retailer carries price information for. To reduce operational risk:
  1. Split very large history extracts into smaller sequential files, such as one to three months per file for large customers.
  2. Keep the files in strict date order and run only the number of history flows needed for the uploaded files.
  3. Avoid running reporting queries against price history tables while the price history job is processing.
  4. Confirm statistics have been collected for the price tables before and after the price loads, use jobs such as REFRESH_RADM_JOB.
  5. Monitor C_HIST_LOAD_STATUS and the RI_LOG_MSG table to determine which date and table are currently processing and how long each day is taking to load.
  6. If POM shows the job as failed, killed, or timed out, verify whether database sessions are still running before cleaning status rows or rerunning. Rerunning while the database session is still active can create duplicate data or incorrect status updates. Very large operations may not immediately end the session in the database when the POM job fails or is killed.
Open an SR when a specific date/table step is not progressing for an extended time, when the same SQL step repeatedly takes much longer than surrounding dates, or when the load requires database-level performance intervention.
Price Seeding and Current Positions
If you will not be loading a complete history file, or you want to skip history and run price seeding or nightly cycles, then you must be aware of the nightly job behavior as it relates to history. The nightly batch job W_RTL_PRICE_IT_LC_DY_F_JOB has a validation rule that looks for history data and fails the batch if it is not found. It is looking specifically in the table W_RTL_PRICE_IT_LC_G, because this table must be populated when the price history job runs for the last date (the value in HIST_LOAD_LAST_DATE). The reason for this validation is that the system calculates many additional fields like LAST_MKDN_DT that need to include your historical price activity. If you run the nightly batch jobs without populating W_RTL_PRICE_IT_LC_G, all calculated fields will start as null or having only the current night’s price data. If you are not planning to load complete price history up to the value on HIST_LOAD_LAST_DATE, then you may disable this validation rule from C_ODI_PARAM_VW in the Manage System Configurations screen. Look for the RI_CHK_PRICE_G_EMPTY_IND parameter and update the value to N. This will allow W_RTL_PRICE_IT_LC_DY_F_JOB to complete even if no history has been loaded and the W_RTL_PRICE_IT_LC_G table is empty.
If W_RTL_PRICE_IT_LC_DY_F does contain history but W_RTL_PRICE_IT_LC_G is empty, leading to batch failures, review these steps:
  1. Verify that HIST_LOAD_LAST_DATE matches a date that has actually been staged and processed by history load programs.
  2. If the history load data stopped 1+ days short of the final history date, load or stage data for the missing final dates and rerun the price history load so the final-date logic runs to populate W_RTL_PRICE_IT_LC_G first.
  3. If the value of HIST_LOAD_LAST_DATE was too far in the future and that is the reason the W_RTL_PRICE_IT_LC_G table was never populated by the history load, then you will need to update HIST_LOAD_LAST_DATE to move it backwards to match the date of data currently in the staging table, and then use the history load process to apply it. If this approach is taken during an active nightly batch, you will need to skip the failed nightly price job for this run after the history load is done, as the history job would have populated both G and F tables with the staged data already.
  4. If the history data is not required to calculate fields on W_RTL_PRICE_IT_LC_G, you may update RI_CHK_PRICE_G_EMPTY_IND=N to acknowledge that history-derived price fields can start from nightly data instead of using historical data.
Reloading Inventory and Price History
If you need to reload new inventory or price data from the beginning, you must first erase the associated fact tables and clean up the configurations. Use the Data Cleanup Utility described in the AIF Operations Guide to truncate all inventory or price fact tables. You should use the subject area cleanup for this purpose, passing in a value of Inventory Position or Price as the subject area name. This utility, when run specifically for inventory and price subject areas, will truncate the tables, reset the columns in C_HIST_LOAD_STATUS, and cleanup metadata relating to the partitions to prepare it for a fresh load of data. It will not truncate TMP tables, as those will be truncated automatically when the history load programs are next executed.
Make sure you check C_HIST_LOAD_STATUS before starting a new history load as you may want to enable different tables or change the HIST_LOAD_LAST_DATE values to align with your new data. Verify that the MAX_COMPLETED_DATE and HIST_LOAD_STATUS columns are null for all rows you will be reprocessing.
If you are loading additional data on top of existing data (without cleanup) then you must follow the specific guidance in the prior sections relating to phased history load approaches. Inventory allows for loading multiple phases of data for distinct sets of item/locations by just resetting C_HIST_LOAD_STATUS. Price data supports phased loads but has an additional requirement where you need to update the C_ODI_PARAMparameter HIST_LOAD_PHASE to a different value to indicate a new load is being performed that should not conflict with the existing data. The default value when you do your first history load is PHASE1, so update it to PHASE2for your second load, PHASE3 for your third load, and so on. Each history load phase must have a distinct set of item/locations that do not already have data in the price fact. The unique phase identifier will ensure the price fact quarterly seeding logic only applies to the item/locations in that phase.
History Load Restart and Recovery Rules
C_HIST_LOAD_STATUS is both a configuration table and a restart-control table. Do not treat it as only a one-time setup table. If you will be resuming a history load, recovering from an error, or loading additional data without performing cleanup, then you need to select the correct approach for the task or you will run into unexpected issues. The history jobs update MAX_COMPLETED_DATE and HIST_LOAD_STATUS as each enabled history table completes for each date or week, but when starting additional runs or restarting an in-progress run, they will also check the current state of those columns to identify which step should be run next.
Use the following rules to guide your load activities:
Scenario Corrective Actions Common Mistakes to Avoid
A run failed during a STG or TMP load step, before target fact rows were inserted for the date/week. Fix the cause of the failure, which may involve deleting records from the FS staging tables, cleanup rejected records if needed, then rerun the failed POM process. Do not erase all history data and start over from scratch when the issue is only with some rejected or bad records which have not been inserted yet. The data can be cleaned up in-place and the job resumed.
A run inserted some target fact rows and then failed later, such as for an aggregate (A) table. If the target table already contains data for the dates/weeks you are loading, delete that data and restart the job. If the incoming data is incorrect but was loaded into some tables already, delete the data in the completed tables for those item/location/weeks instead so the aggregate table insert can complete. Do not skip the issue to move onto later dates/weeks as the conflict in the data will remain and cause future problems in other programs. Do not reset C_HIST_LOAD_STATUS without also purging already loaded data via cleanup utilities.
Data must be reloaded from the beginning, such as when customer has provided new files for the entire history timeframe. Use the documented cleanup utility for the subject areas, verify the C_HIST_LOAD_STATUS rows are reset, and then reload from the earliest date/week. Do not manually delete rows from individual tables as you will miss cleaning up system configurations such as partition setup and the reload of data will fail.
Data must be loaded in a new phase for new item/location combinations. Reset C_HIST_LOAD_STATUS only for the new phase, ensure the input contains only combinations that are not already loaded for the same dates/weeks, and follow the phase-specific guidance. Do not use a new phase to reload the same item/location/date or item/location/week data. Do not start the next phase of data without verifying there is no overlap between the item/locations in the target tables and the incoming files.
Cost History Load
Retail Insights includes separate positional facts for base cost and net cost information. Cost history is similar to pricing in that it is a positional fact and can be loaded in a more compressed manner due to the extremely high data volumes involved. The required approach for cost history is as follows:
  1. Update C_HIST_LOAD_STATUS for the BCOST and NCOST records in the table, specifying the last date of history load. For whatever value you put in the HIST_LOAD_LAST_DATE column, ensure that you load cost data up to and including that date. There is logic in the history load to insert to the W_RTL_BCOST_IT_LC_G and W_RTL_NCOST_IT_LC_G tables; that logic only runs on the final day of historical processing. But, if you don’t load files all the way up to that date, it will never run and you may have incorrect data as a result. If you are loading history after your nightly batches already started, then you must set this date to be the last week-ending date before your first daily/weekly batch. No other date value can be used in this case.
  2. Create an initial, full snapshot of cost data in COST.csv for the first day of history to establish starting positions for any item/locations that would have had costs in the source system on or before that starting date. Create the rest of the COST data (added to the same file or using additional files) containing just cost changes and new item/location costs with the appropriate effective day dates for those changes. Costs that do not change will not have any additional records after the initial starting positions.
  3. Load each file one at a time using the history processes in chronological order. The history procedure will iterate over the provided files day by day, starting from the first day of history, up to the last historical load date specified in C_HIST_LOAD_STATUS for the cost facts. For each date, the procedure checks the staging data for effective cost change records and loads them, then moves on to the next date. The procedure will also perform partitioning and seeding activities once per fiscal quarter to maintain the positional fact architecture of each loaded table.
The overall process to perform cost history loads is similar to the pricing load steps, just using different POM jobs. It uses the COST.csv file and the HIST_COST_LOAD_ADHOC process. Just like pricing, you must load the data sequentially; you cannot back-post cost changes to earlier dates than what you have already loaded and you cannot load dates out of order.
The REJECT_DATA_CLEANUP_ADHOC process may be used when records are rejected during the load. Cost loads cannot continue until you review and clear the rejections. Use parameter values of NCOST or BCOST depending on which table has the rejections. In POM, just add one of these parameters to the job inside this process, then run the process. For Postman or Curl, an example payload for NCOST would be:
  "cycleName":"Adhoc",
  "flowName":"Adhoc",
  "requestParameters":"jobParams.REJECT_DATA_CLEANUP_JOB=NCOST"
If HIST_COST_LOAD_ADHOC fails with a unique constraint error while inserting to the cost facts, verify the following:
  2. Check the staging (FS) data for duplicate item/location/date rows. The primary key is only item/location/date, you cannot have multiple costs for the same date. If duplicates exist in the staging table, correct the input or staged data, reset HIST_LOAD_STATUS for the TMP table record to INPROGRESS, then rerun the job.
Cost History Performance and Long-Running Loads
Large cost history loads can take many hours because the job processes the data by date and may update multiple fact tables. Cost data is often a very large dataset to work with due to the number of item/location combinations a retailer carries cost information for. To reduce operational risk:
  3. Avoid running reporting queries against cost history tables while the cost history job is processing.
  4. Confirm statistics have been collected for the cost tables before and after the cost loads, use jobs such as REFRESH_RADM_JOB.
Purchase Order Loads
Purchase Order data does not support loading of historical records, as all usage of PO data is for forward-looking calculations, such as open on-order amounts. However, it is common to need some test data to be loaded prior to nightly batches so that you can validate the purchase order calculations in your Planning solutions during implementation. When loading PO data, make sure you develop the files following the guidance in the data files generation section of this document and in the RAP interfaces guide.
  1. Create the files ORDER_HEAD.csv and ORDER_DETAIL.csv containing a full snapshot of purchase order data for a single date. The DAY_DT value on every record in ORDER_DETAIL.csv must be the same and represent the current business date in RAP at the time the file will be loaded. The load will fail for any other value of DAY_DT besides the current business date, and it will fail if multiple dates are present in the file.
  2. Upload the data files and their context files to Object Storage using the RAP_DATA_HIST.zip file.
  4. Execute the SEED_CSV_W_RTL_PO_ONORD_IT_LC_DY_F_PROCESS_ADHOC batch process to load the data. Example Postman message body:
      "cycleName":"Adhoc", "flowName":"Adhoc",
      "processName":"SEED_CSV_W_RTL_PO_ONORD_IT_LC_DY_F_PROCESS_ADHOC"
Purchase Order data functions similar to inventory in that it is a positional fact interface and cannot be loaded or reloaded multiple times for the same dates. If you load some data for a given business date and need to change or erase it, you must truncate the tables using support utilities and then load the new data. You also cannot load the data out of order. Once you load data for one date, you may only load new files for future dates after that point. The data warehouse target tables for this data are W_RTL_PO_DETAILS_D (for the ORER_HEAD.csv file) and W_RTL_PO_ONORD_IT_LC_DY_F (for the ORDER_DETAIL.csv file).
Prior to starting nightly loads of PO data, you must also choose your configuration option for the parameter PO_FULL_LOAD_IND in the C_ODI_PARAM_VW configuration table in Manage System Configurations. By default, this parameter is set to N, which means that the nightly interface expects to get all delta/incremental updates to your existing PO data each night. This delta includes zero balance records for when a PO is received in the source and moves to zero units on order. If tracking and sending deltas is not possible, you may change this parameter to Y, which indicates that your nightly file will be a full snapshot of open order records instead. The system will automatically zero out any purchase order lines that are not included in your nightly file, which allows you to extract only the non-zero lines in your source data.
You must also choose the configuration option for the parameter PDS_EXPORT_DAILY_ONORD, which determines whether the EOW_DATE used in the export data is allowed to contain non-end-of-week (EOW) dates, or if the system must convert it to a week-ending date in all cases. When set to a value of Y, it means daily dates are allowed in the EOW_DATE field on the export, if there is a daily date in the OTB_EOW_DATE column of ORDER_HEAD.csv. When set to a value of N, it means the system automatically converts the input dates from ORDER_HEAD.csv to be week-ending dates in all cases. For a base implementation of MFP with no customizations, you may want this setting to be N to force the export dates to be EOW dates even if the input file has non-EOW dates from the source. If you are altering RPAS to have a different base calendar intersection, then you may want to change this to Y instead to allow daily dates.
Other History Loads
While sales and inventory are the most common facts to load history for, you may also want to load history for other areas such as receipts and transfers. Separate ad hoc history load processes are available for the following fact areas:
  • HIST_CSV_ADJUSTMENTS_LOAD_ADHOC
  • HIST_CSV_INVRECEIPTS_LOAD_ADHOC
  • HIST_CSV_MARKDOWN_LOAD_ADHOC
  • HIST_CSV_INVRTV_LOAD_ADHOC
  • HIST_CSV_TRANSFER_LOAD_ADHOC
  • HIST_CSV_DEAL_INCOME_LOAD_ADHOC
  • HIST_CSV_ICMARGIN_LOAD_ADHOC
  • HIST_CSV_INVRECLASS_LOAD_ADHOC
  • HIST_STG_CSV_SALES_WF_LOAD_ADHOC
  • HIST_SALES_WF_LOAD_ADHOC
All of these interfaces deal with transactional data (not positional) so you may use them at any time to load history files in each area.
These processes are intended to support history data for downstream applications such as AI Foundation and Planning, so the tables populated by each process by default should satisfy the data needs of those applications. Jobs not needed by those apps are not included in these processes.
Some data files used by AIF and Planning applications do not have a history load process, because the data is only used from the current business date forwards. For Purchase Order data (ORDER_DETAIL.csv), refer to the section below on Seed Positional Facts if you need to load the file before starting your nightly batch processing. For other areas like transfers/allocations used by Inventory Planning Optimization, those jobs are only included in the nightly batch schedule and do not require any history to be loaded.
Modifying Staged Data
If you find problems in the data you’ve staged in the RAP database (specific to RI/AIF input interfaces) you have the option to directly update those tables from APEX, thus allowing you to reprocess the records without uploading new files through FTS. You have the privileges to insert, delete, or update records in tables where data is staged before being loaded into the core data model, such as W_RTL_INV_IT_LC_DY_FTS for inventory data.
Directly updating the staging table data can be useful for quickly debugging load failures and correcting minor issues. For example, you are attempting to load PRODUCT.csv for the first time and you discover some required fields are missing data for some rows. You may directly update the W_PRODUCT_DTS table to put values in those fields and rerun the POM job, allowing you to progress with your dataload and find any additional issues before generating a new file. Similarly, you may have loaded an inventory receipts file, but discovered after staging the file that data was written to the wrong column (INVRC_QTY contains the AMT values and vice versa). You can update the fields and continue to load it to the target tables to verify it, and then correct your source data from the next run forwards only.
These privileges extend only to staging tables, such as table names ending in FTS, DTS, FS, or DS. You cannot modify internal tables holding the final fact or dimension data. You cannot modify configuration tables as they must be updated from the Control & Tactical Center. The privileges do not apply to objects in the RDX or PDS database schemas.
Reloading Dimensions
It is common to reload dimensions at various points throughout the history load, or even in-sync with every history batch run. Ensure that your core dimensions, such as the product and location hierarchies, are up-to-date and aligned with the historical data being processed. To reload dimensions, you may follow the same process as described in the Initial Dimension Load steps, ensuring that the current business load date in the system is on or before the date in history when the dimensions will be required. For example, if you are loading history files in a monthly cadence, ensure that new product and location data required for the next month has been loaded no later than the first day of that month, so it is effective for all dates in the history data files.
It is also very important to understand that history load procedures are unable to handle reclassifications that have occurred in source systems when you are loading history files. For example, if you are using current dimension files from the source system to process historical data, and the customer has reclassified products so they are no longer correct for the historical time periods, then your next history load may place sales or inventory under the new classifications, not the ones that were relevant in history. For this reason, reclassifications should be avoided if at all possible during history load activities, unless you can maintain historical dimension snapshots that will accurately reflect historical data needs.
Once sales and inventory history have been processed, you will need to perform seeding of the positional facts you wish to use. Seeding a fact means to load a full snapshot of the data for all active item/locations, thus establishing a baseline position for every possible record before nightly batches start loading incremental updates to those values. Seeding of positional facts should only occur once history data is complete and daily batch processing is ready to begin. Seed loads should also be done for a week-ending date, so that you do not have a partial week of daily data in the system when you start daily batches.
Instead of doing separate seed loads, you also have the option of just providing full snapshots of all positional data in your first nightly batch run. This will make the first nightly batch take a long time to complete (potentially 8+ hours) but it allows you to skip all of the steps documented below. This method of seeding the positional facts is generally the preferred approach for implementers, but if you want to perform manual seeding as a separate activity, review the rest of this section. If you are also implementing RMFCS, you can leverage Retail Data Extractor (RDE) programs for the initial seed load as part of your first nightly batch run, following the steps in that chapter instead.
If you did not previously disable the optional inventory features in C_ODI_PARAM (parameters RI_INVAGE_REQ_IND, RA_CLR_LEVEL, RI_PRES_STOCK_IND, RI_BOH_SEEDING_IND, RI_MOVE_TO_CLR_IND, and RI_MULTI_CURRENCY_IND) then you should review these settings now and set all parameters to N if the functionality is not required. Once this is done, follow the steps below to perform positional seeding:
  1. Create the files containing your initial full snapshots of positional data. It may be one or more of the following:
    • PRICE.csv
    • COST.csv (used for both BCOST and NCOST data interfaces)
    • INVENTORY.csv
    • ORDER_DETAIL.csv (ORDER_HEAD.csv may already be loaded using dimension process, but it can also be done now, as it is required to load this file)
    • W_RTL_INVU_IT_LC_DY_FS.dat
  2. Upload the files to Object Storage using the RAP_DATA_HIST.zip file.
  3. Execute the RESET_BUSINESS_DATE_ADHOC process to set the load date to be the next week-ending date after the final date in your history load.
    "flowName":"Adhoc",
    "processName":"RESET_BUSINESS_DATE_ADHOC",
    "requestParameters":"jobParams.RESET_BUSINESS_DATE_JOB=disJobType=ODI_JOB_RUN||name=PLP_RETAILRESETBUSINESSDATEGENERAL||context=DEVELOPMENT||type=SCN||logLevel=5||params=RA_BI.RI_ADHOC_BUSINESS_DT:2017-12-31"
  4. Execute the ad hoc seeding batch processes depending on which files have been provided. Sample Postman messages:
    "flowName":"Adhoc",
    "processName":"SEED_CSV_W_RTL_PRICE_IT_LC_DY_F_PROCESS_ADHOC"
    "cycleName": "Adhoc",
    "flowName":"Adhoc",
    "processName":"SEED_CSV_W_RTL_NCOST_IT_LC_DY_F_PROCESS_ADHOC"
    "flowName":"Adhoc",
    "processName":"SEED_CSV_W_RTL_BCOST_IT_LC_DY_F_PROCESS_ADHOC"
    "flowName":"Adhoc",
    "processName":"SEED_CSV_W_RTL_INV_IT_LC_DY_F_PROCESS_ADHOC"
    "flowName":"Adhoc",
    "processName":"SEED_CSV_W_RTL_INVU_IT_LC_DY_F_PROCESS_ADHOC"
    "flowName":"Adhoc",
Once all initial seeding is complete and data has been validated, you are ready to perform a regular batch run. Provide the data files expected for a full batch, such as RAP_DATA.zip or RI_RMS_DATA.zip for foundation data, RI_MFP_DATA.zip for externally-sourced planning data (for RI reporting and AI Foundation forecasting), and any AI Foundation Cloud Services files using the ORASE_WEEKLY.zip files. If you are sourcing daily data from RMFCS then you need to ensure that the RDE batch flow is configured to run nightly along with the RAP batch schedule. Batch dependencies between RDE and RI should be checked and enabled, if they are not already turned on.
From this point on, the nightly batch takes care of advancing the business date and loading all files, assuming that you want the first load of nightly data to occur the day after seeding. The following diagram summarizes a potential set of dates and activities using the history and seeding steps described in this chapter:
Diagram of History and Seeding Steps
The sequential nature of this flow of events must be followed for positional facts (for example, inventory) but not for transactional facts (such as sales). Transactional data supports posting for dates other than what the current system date is, so you can choose to load sales history at any point in this process.
Run Nightly Batches
As soon as initial seeding is performed (or instead of initial seeding), you need to start nightly batch runs. If you are using the nightly batch to seed positional facts, ensure your first ZIP file upload for the batch has those full snapshots included. Once those full snapshots are loaded through seeding or the first full batch, then you can send incremental files rather than full snapshots.
Nightly batch schedules can be configured in parallel with the history load processes using a combination of the Customer Modules Management (in Retail Home) and the POM administration screens. It is not recommended to configure the nightly jobs manually in POM, as there are over 500 batch programs; choosing which to enable can be a time-intensive and error-prone activity. Customer Modules Management greatly simplifies this process and preserves dependencies and required process flows. Batch Orchestration describes the batch orchestration process and how you can configure batch schedules for nightly execution.
Once you move to nightly batches, you may also want to switch dimension interfaces from Full to Incremental loading of data. Several interfaces, such as the Product dimension, can be loaded incrementally, sending only the changed records every day instead of a full snapshot. These options use the IS_INCREMENTAL flag in the C_ODI_PARAM_VW table and can be accessed from the Control & Tactical Center. If you are unsure of which flags you want to change, refer to the Retail Insights Implementation Guide for detailed descriptions of all parameters.
At this time, incremental product and location loads are supported when using RDE for integration or when using legacy DAT files. CSV files should be provided as full snapshots.
As part of nightly batch uploads, also ensure that the parameter file RA_SRC_CURR_PARAM_G.dat is included in each ZIP package, and that it is being automatically updated with the current business date for that set of files. This file is used for business date validation so incorrect files are not processed. This file will help Oracle Support identify the current business date of a particular set of files if they need to intervene in the batch run or retrieve files from the archives for past dates. Refer to the System Parameters File section for file format details.
In summary, here are the main steps that must be completed to move from history loads to nightly batches:
  1. All files must be bundled into a supported ZIP package like RAP_DATA.zip for the nightly uploads, and this process should be automated to occur every night.
  2. Include the system parameter file RA_SRC_CURR_PARAM_G.dat in each nightly upload ZIP and automate the setting of the vdate parameter in that file (not applicable if RDE jobs are used).
  3. Sync POM schedules with the Customer Module configuration using the Sync with MDF button in the Batch Administration screen, restart the POM schedules to reflect the changes, and then review the enabled/disabled jobs to ensure the necessary data will be processed in the batch.
  4. Move the data warehouse ETL business date up to the date one day before the current nightly load (using RESET_BUSINESS_DATE_ADHOC). The nightly load takes care of advancing the date from this point forward.
  5. Close and re-open the batch schedules in POM as needed to align the POM business date with the date used in the data (all POM schedules should be open for the current business date before running the nightly batch).
  6. Schedule the start time from the Scheduler Administration screen > RI schedule > Nightly tab. Enable it and set a start time. Restart your schedule again to pick up the new start time.
Sending Data to AI Foundation Applications
All AI Foundation applications leverage a common batch infrastructure to initialize the core dataset, followed by ad hoc, application-specific programs to generate additional data as needed. Before loading any data into an AI Foundation application, it is necessary to complete initial dimension loads into the data warehouse using AIF DATA jobs and validate that core structures (calendar, products, locations) match what you expect to see. Once you are comfortable with the data that has been loaded in, leverage the following jobs to move data into one or more AI Foundation applications.
Table 3-6 Extracts for AI Foundation
POM Process Name Usage Details
INPUT_FILES_ADHOC_PROCESS
Receive inbound zip files intended for AI Foundation, archive and extract the files. This process looks for the ORASE_WEEKLY_ADHOC.zip file. This ZIP file is not used for core foundation data; it has specific application purposes as listed in the RAP Interfaces Guide.
RSE_MASTER_ADHOC_PROCESS
Foundation data movement from the data warehouse to AI Foundation applications, including core hierarchies and dimensional data. Accepts many different parameters to run specific steps in the load process.
<app>_MASTER_ADHOC_PROCESS
Each AI Foundation application, such as SPO or IPO, has a master job for extracting and loading data that is required for that application, in addition to the RSE_MASTER processes. AI Foundation application jobs may look for a combination of data from the data warehouse (AIF DATA) tables and input files in ORASE_WEEKLY_ADHOC.zip.
Because AI Foundation Cloud Services ad hoc procedures have been exposed using only one job in POM, they are not triggered like AIF DATA procedures. AI Foundation application programs accept a number of single-character codes representing different steps in the data loading process. These codes can be provided directly in POM by editing the Parameters of the job in the Batch Monitoring screen, then executing the job through the user interface.
AI Foundation Standalone Batch Jobs Actions Menu
For example, this string of parameters will move all dimension data from the data warehouse to AI Foundation applications:
Parameters for Moving Dimension Data from RI to AI Foundation
Additional parameters are available when moving periods of historical data, such as inventory and sales:
Parameters for Moving Periods of Historical Data
A typical workflow for moving core foundation data from the data warehouse into AI Foundation applications is:
  1. Load the core foundation files (like CALENDAR.csv, PRODUCT.csv, and ORGANIZATION.csv) using the AIF DATA ad hoc jobs.
  2. Use the RSE_MASTER_ADHOC_PROCESS in the AIF APPS schedule to move those datasets to AI Foundation applications, providing specific flag values to only run the needed steps. The standard set of first-time flags are -pldg, which loads the core hierarchies required by all the applications.
  3. Load some of your history files for Sales using the AIF DATA jobs to validate the inputs. For example, load 1-3 months of sales for all products or a year of sales for only one department.
  4. Load the same range of sales to AI Foundation applications using the sales load and aggregation steps in RSE_MASTER_ADHOC_JOB with optional from/to date parameters. The flags to use for this are -xwa, which loads the transaction table RSE_SLS_TXN as well as all sales aggregates which are shared across AIF applications.
  5. Repeat the previous two steps as needed, until all sales data is loaded into both AIF Data and AIF Applications.
    Performing the process iteratively provides you early opportunities to find issues in the data before you’ve loaded everything, but it is not required. You can load all the data into AI Foundation at one time.
Follow the same general flow for the other application-specific, ad hoc flows into the AI Foundation applications. For a complete list of parameters in each program, refer to the AI Foundation Operations Guide.
When loading hierarchies, it is possible to have data issues on the first run due to missing or incomplete records from the customer. You may get an error like the following:
Error occurred in RSE_DDL_UTIL.create_local_index_stmt - Error while creating index: CREATE UNIQUEINDEX TMP$STG$RSE_LOC_SRC_XREF_2 ON TMP$STG$RSE_LOC_SRC_XREF ( HIER_TYPE_ID,LOC_EXT_ID,LEAF_NODE_FLG,APP_SOURCE_ID) ORA-01452: cannot CREATE UNIQUE INDEX; duplicate keys found
The INDEX create statement tells you the name of the table and the columns that were attempting to be indexed. Querying that table is what is required to see what is duplicated or invalid in the source data. Because these tables are created dynamically when the job is run, you will need to first grant access to it using a procedure like below in IW:
begin RSE_SUPPORT_UTIL.grant_temp_table(p_prefix => 'STG$RSE_LOC_SRC_XREF'); end;
The value passed into the procedure should be everything after the TMP$ in the table name (not the index name). The procedure also supports two other optional parameters to be used instead of or in addition to the prefix:
  • p_suffix – Provide the ending suffix of a temporary table, usually a number like 00001101, to grant access to all tables with that suffix
  • p_purge_flg - Purge flag (Y/N) which indicates to drop temporary tables for a given run
Once this is executed for a given prefix, a query like this can retrieve the data causing the failure:
SELECT * FROM RASE01.TMP$STG$RSE_LOC_SRC_XREF WHERE ( HIER_TYPE_ID,LOC_EXT_ID,LEAF_NODE_FLG,APP_SOURCE_ID )    IN ( SELECT
        HIER_TYPE_ID,LOC_EXT_ID,LEAF_NODE_FLG,APP_SOURCE_ID          FROM
        RASE01.TMP$STG$RSE_LOC_SRC_XREF         GROUP BY
        HIER_TYPE_ID,LOC_EXT_ID,LEAF_NODE_FLG,APP_SOURCE_ID        HAVING count(*)  > 1      )ORDER BY HIER_TYPE_ID,LOC_EXT_ID,LEAF_NODE_FLG,APP_SOURCE_ID ;
For location hierarchy data the source of the issue will most commonly come from the W_INT_ORG_DH table. For product hierarchy, it could be W_PROD_CAT_DH. These are the hierarchy tables populated in the data warehouse by your foundation data loads.
Sending Data to Planning Applications
If a Planning application is being implemented, then additional AIF DATA schedule jobs should be executed as part of the initial loads and nightly batch runs. These jobs are available through ad hoc calls, and the nightly jobs are included in the AIF DATA nightly schedule. Review the list below for more details on the core Planning extracts available.
The tables populated by these jobs are being replaced with database views. These jobs will remain in the batch schedule and be fully functional, but the base templates of the planning solutions will begin moving away from the tables based on availability of a specific replacement view. The database views will use the same name as the tables they replace, appended with a ‘V’ at the end of the name. For example, W_PDS_PRODUCT_D is replaced by W_PDS_PRODUCT_DV. In this release, you should continue to run the table-based programs listed in this section in addition to the dimension view job.
Process Overview
Table 3-7 Extracts for Planning
POM Job Name Usage Details
PDS_DIMENSION_VIEW_JOB Activates the dimension database views for direct integration between the data warehouse and the planning data store for the current batch run. The views will not contain any data when queried until this job is executed, as it is responsible for creating new RUN_ID values that Planning integration programs need to confirm data availability.
W_PDS_PRODUCT_D_JOB
Exports a full snapshot of Product master data and associated hierarchy levels, including flex fields for alternates.
W_PDS_ORGANIZATION_D_JOB
Exports a full snapshot of Location master data (for stores and virtual warehouses only) and associated hierarchy levels, including flex fields for alternates.
W_PDS_CALENDAR_D_JOB
Exports a full snapshot of Calendar data at the day level and associated hierarchy levels, for both Fiscal and Gregorian calendars. Includes flex fields for alternates.
Note: While the AIF DATA job exports the entire calendar, PDS will only import 5 years around the RPAS_TODAY date (current year +/- 2 years).
W_PDS_EXCH_RATE_G_JOB
Exports a full snapshot of exchange rates. You may only have a single type of rates (for example, Corporate) with a single set of conversions between any two rates. Multiple types or multiple sets of rates for the same codes will cause a failure during import to RPAS.
W_PDS_PRODUCT_ATTR_D_JOB
Exports a full snapshot of item-attribute relationships. This is inclusive of both diffs and UDAs. Only list-of-values (LOV) type UDAs which are marked as single-value LOVs are included; other UDA types are filtered out.
W_PDS_DIFF_D_JOB
Exports a full snapshot of Differentiators such as Color and Size.
W_PDS_DIFF_GRP_D_JOB
Exports a full snapshot of differentiator groups (most commonly size groups used by SPO and AP).
W_PDS_UDA_D_JOB
Exports a full snapshot of User-Defined Attributes.
W_PDS_BRAND_D_JOB
Exports a full snapshot of Brand data (regardless of whether they are currently linked to any items).
W_PDS_SUPPLIER_D_JOB
Exports a full snapshot of Supplier data (regardless of whether they are currently linked to any items).
W_PDS_CUSTSEG_D_JOB
Exports a full snapshot of Customer Segments data (regardless of whether they are currently linked to any customers).
W_PDS_REPL_ATTR_IT_LC_D_JOB
Exports a full snapshot of Replenishment Item/Location Attribute data (equivalent to REPL_ITEM_LOC from RMFCS).
W_PDS_DEALINC_IT_LC_WK_A_JOB
Incremental extract of deal income data (transaction codes 6 and 7 from RMFCS) posted in the current business week.
W_PDS_PO_ONORD_IT_LC_WK_A_JOB
Full snapshot extract of future on-order amounts for the current business week, based on the expected OTB date.
W_PDS_PO_ONORD_IT_LC_DY_F_JOB
Full snapshot extract of currently active purchase order details for Inventory Planning Optimization. Converts pack item data to separate order lines when provided, while also excluding the pack component lines to avoid duplicate values.
W_PDS_INV_IT_LC_WK_A_JOB
Full snapshot extract of inventory positions for the current business week. Inventory is always posted to PDS on the current week, there are no back-posted records. Includes pack item inventory (when available) by removing the pack component quantities that belong to pack items and inserting additional rows for the pack items.
W_PDS_SLS_IT_LC_WK_A_JOB
Incremental extract of sales transactions posted in the current business week (includes back-posted transactions to prior transaction dates). Optionally includes warehouse shipments as additional gross sales for demand forecasting.
W_PDS_INVTSF_IT_LC_WK_A_JOB
Incremental extract of inventory transfers posted in the current business week (transaction codes 30, 31, 32, 33, 37, 38 from RMFCS).
W_PDS_INVRC_IT_LC_WK_A_JOB
Incremental extract of inventory receipts posted in the current business week. Only includes purchase order receipts (transaction code 20 from RMFCS).
W_PDS_INVRTV_IT_LC_WK_A_JOB
Incremental extract of returns to vendor posted in the current business week (transaction code 24 from RMFCS).
W_PDS_INVADJ_IT_LC_WK_A_JOB
Incremental extract of inventory adjustments posted in the current business week (transaction codes 22 and 23 from RMFCS).
W_PDS_INVU_IT_LC_WK_A_JOB Full snapshot extract of unavailable/unsellable inventory positions for the current business week. Inventory positions are always posted to PDS on the current week. There are no back-posted records.
W_PDS_SLSWF_IT_LC_WK_A_JOB
Incremental extract of wholesale and franchise transactions posted in the current business week (transaction codes 82, 83, 84, 85, 86, 88 from RMFCS).
W_PDS_MKDN_IT_LC_WK_A_JOB
Incremental extract of markdowns posted in the current business week (transaction codes 11, 12, 13, 14, 15, 16, 17, 18 from RMFCS).
W_PDS_ALC_IT_LC_DY_F_JOB
Full snapshot extract of currently active allocations for use in Inventory Planning Optimization.
W_PDS_TSF_IT_LC_DY_F_JOB
Full snapshot extract of currently active transfers for use in Inventory Planning Optimization.
W_PDS_INV_IT_LC_WK_A_INITIAL_JOB
Initial history extract for inventory position data based on the timeframe established in C_SOURCE_CDC.
W_PDS_INVU_IT_LC_WK_A_INITIAL_JOB Initial history extract for unavailable inventory position data based on the timeframe established in C_SOURCE_CDC.
W_PDS_FLEXFACT1_F_JOB
Exports flexible fact data from the data warehouse that can be at any configurable level of merchandise/location hierarchies and week level of the calendar. Can be used to extend PDS with additional measures. Flex Fact 1 is also used by LPO to display custom measures.
W_PDS_FLEXFACT2_F_JOB
W_PDS_FLEXFACT3_F_JOB
W_PDS_FLEXFACT4_F_JOB
W_PDS_ORG_ATTR_STR_D_JOB
Exports a full snapshot of custom flex location attributes and other location attribute types to PDS, for string-type attributes only.
W_PDS_ORG_ATTR_NBR_D_JOB
Exports a full snapshot of custom flex location attributes to PDS, for number-type attributes only.
W_PDS_ORG_ATTR_DT_D_JOB
Exports a full snapshot of custom flex location attributes to PDS, for date-type attributes only.
W_PDS_PRODUCT_ATTR_STR_D_JOB
Exports a full snapshot of custom flex product attributes to PDS, for string-type attributes only.
W_PDS_PRODUCT_ATTR_NBR_D_JOB
Exports a full snapshot of custom flex product attributes to PDS, for number-type attributes only.
W_PDS_PRODUCT_ATTR_DT_D_JOB
Exports a full snapshot of custom flex product attributes to PDS, for date-type attributes only.
W_PDS_PROD_ORG_ATTR_STR_D_JOB
Exports a full snapshot of custom flex product/location attributes to PDS, for string-type attributes only.
W_PDS_PROD_ORG_ATTR_NBR_D_JOB
Exports a full snapshot of custom flex product/location attributes to PDS, for number-type attributes only.
W_PDS_PROD_ORG_ATTR_DT_D_JOB
Exports a full snapshot of custom flex product/location attributes to PDS, for date-type attributes only.
The PDS jobs are linked with several ad hoc processes in POM, providing you with the ability to extract specific datasets on-demand as you progress with history and initial data loads. The table below summarizes the ad hoc processes, which can be called using the standard methods such as cURL or Postman.
Table 3-8 AIF DATA Ad Hoc Processes for Planning
LOAD_PDS_DIMENSION_PROCESS_ADHOC
Groups all of the dimension (D/G table) extracts for PDS into one process for ad hoc execution. Disable individual jobs in POM to run only some of them. Includes PDS_DIMENSION_VIEW_JOB for populating integration views for all dimensions.
LOAD_PDS_FACT_PROCESS_ADHOC
Groups all of the fact (F/A table) extracts for PDS into one process for ad hoc execution. Disable individual jobs in POM to run only some of them.
LOAD_PDS_FACT_INITIAL_PROCESS_ADHOC
History extract process for inventory positions, run only to pull a full snapshot of inventory from the data warehouse for one or multiple weeks of data. You must set the start and end dates for extraction in the C_SOURCE_CDC table before running this process. The dates must be week-ending dates aligning with the first and last week to export.
C_LOAD_DATES_CLEANUP_ADHOC
Purge the job records from C_LOAD_DATES and C_LOAD_DATES_DETAILS, which is necessary when you are running the same jobs multiple times per business date.
Most of the PDS fact jobs leverage the configuration table C_SOURCE_CDC to track the data that has been extracted in each run. On the first run of an incremental job in LOAD_PDS_FACT_PROCESS_ADHOC, the job extracts all available data in a single run. From that point forwards, the extract incrementally loads only the data that has been added or modified since the last extract, based on W_UPDATE_DT columns in the source tables. There are some exceptions to this incremental process: Inventory, On Order, and Allocation/Transfer Detail interfaces. The normal incremental jobs for these interfaces will always extract the latest day’s data only, because they are positional facts that send the full snapshot of current positions to PDS each time they run.
To move inventory history prior to the current day, you must use the initial inventory extract to PDS (LOAD_PDS_FACT_INITIAL_PROCESS_ADHOC). It requires manually entering the start/end dates to extract, so you must update C_SOURCE_CDC from the Control & Tactical Center for the inventory table record. LAST_MIN_DATE is the start of the history you wish to send, and LAST_MAX_DATE is the final date of history. For example, if you loaded one year of inventory, you might set LAST_MIN_DATE to 04-JUN-22 and LAST_MAX_DATE to 10-JUN-23. Make sure that the timestamps on the values entered are 00:00:00 when saved to the database, otherwise the comparison between these values and your input data may not align.
For all other jobs, the extract dates are written automatically to C_SOURCE_CDC alongside the extract table name after each execution and can be overwritten as needed when doing multiple loads or re-running for the same time period. If you run the same process more than once, use C_LOAD_DATES_CLEANUP_ADHOC to reset the run statuses before the next run, then edit C_SOURCE_CDC to change the minimum and maximum dates that you are pulling data for. Review the table below for a summary of the configuration tables involved in PDS extracts.
Table 3-9 Planning Integration Configuration Tables
Table Usage
C_SOURCE_CDC
Configuration and tracking table that shows the interfaces supported for data warehouse to Planning integration and the currently processed date ranges.
C_LOAD_DATES
Tracks the execution of jobs and the most recent run status of each job. Prevents running the same job repeatedly if it was already successful, unless you first erase the records from this table.
Tracks the progress of a job’s individual steps when a job supports task-level restartability. Prevents re-running of a successful step on restarting a job from POM unless you first erase the records from this table.
RAP_INTF_CFG
Configuration and tracking table for integration ETL programs between all RAP modules. Contains their most recent status, run ID, and data retention policy.
RAP_INTF_RUN_STATUS
RAP integration run history and statuses. Also used to capture START_TIMESTAMP and END_TIMESTAMP associated with fact data in the integration database views.
RAP_LOG_MSG
RAP integration logging table, specific contents will vary depending on the program and logging level.
Integration tables used to move data from the data warehouse to PDS are designed for temporary data retention and will generally maintain only the current day or week of data based on the most recent job executions. The data retention policy for every interface is found on RAP_INTF_CFG and is enforced using a weekly maintenance job called PURGE_OLD_RDX_EXPORTS_JOB. All data past its retention period will be dropped when this job runs. Accumulating excess data in integration tables would increase storage costs to the customer and potentially impact the performance of accessing these tables over time, therefore it is not advised to disable this job or change the data retention policies.
Some integration interfaces do not require data movement and are not part of this infrastructure. In these cases, the Planning batch programs will directly source data from the data warehouse.
Table 3-10 Planning Integration Views
View Usage
W_PDS_CUSTOM_HIER_DV PDS export view that exposes custom hierarchies from the data warehouse. No data is physically moved for this interface, and no job exists to update it. PDS will read directly from the view.
W_PDS_CUSTOM_HIER_MAP_FV PDS export view that exposes custom hierarchy mappings to product/location/calendar hierarchies from the data warehouse. No data is physically moved for this interface, and no job exists to update it. PDS will read directly from the view.
W_PDS_IT_LC_DV PDS export view of item-location ranging information and other item-location attributes in the data warehouse. No data is physically moved for this interface, and no job exists to update it. PDS will read directly from the view.
After the planning data has been extracted from the data warehouse to PDS staging tables (W_PDS_*), and the PDS_DIMENSION_VIEW_JOB has been executed to populate dimension views, the Planning applications use the same programs to extract both full and incremental data for each interface. You can run the dimension and fact loads for planning from the Online Administration (OAT) tasks, or use the RPASCE schedule in POM. Refer to the relevant implementation guides for MFP, AP, or IPO for details on these processes.
Usage Examples
The following examples show how to leverage the PDS extract processes to move data from the data warehouse tables to the PDS staging tables, where the data can be picked up by the Planning applications.
Scenario 1: Initial Dimension Extract
  1. Perform the initial loads into the data warehouse as described in the section Initialize Dimensions.
  2. Enable all jobs in the ad hoc process LOAD_PDS_DIMENSION_PROCESS_ADHOC and execute it.
  3. Verify that data has been moved successfully to the target tables, such as W_PDS_CALENDAR_D, W_PDS_PRODUCT_D, and W_PDS_ORGANIZATION_D.
Scenario 2: Initial Sales Extract
  1. Perform the initial sales loads into the data warehouse as described in the section Sales History Load.
  2. Enable the job W_PDS_SLS_IT_LC_WK_A_JOB in the ad hoc process LOAD_PDS_FACT_PROCESS_ADHOC and execute the process.
  3. Verify that data has been moved successfully to the target tables W_PDS_SLS_IT_LC_WK_A and W_PDS_GRS_SLS_IT_LC_WK_A.
  4. Repeat the same steps for any other transactional history loads, such as adjustments, transfers, and RTVs (using the appropriate PDS job as described in the prior section).
Scenario 3: Initial Inventory Extract
  1. Perform the initial inventory loads into the data warehouse as described in the section Inventory Position History Load.
  2. Open the C_SOURCE_CDC table in Manage System Configurations and locate the row for W_RTL_INV_IT_LC_WK_A. Edit the values in the LAST_MIN_DATE and LAST_MAX_DATE columns to fully encompass your range of historical dates in the inventory history.
  3. Enable the job W_PDS_INV_IT_LC_WK_A_INITIAL_JOB in the ad hoc process LOAD_PDS_FACT_INITIAL_PROCESS_ADHOC and execute the process.
  4. If the job fails with error code “ORA-01403: no data found,” it generally means that the dates in C_SOURCE_CDC are not set or do not align with your historical data. Update the dates and re-run the job.
  5. Verify that data has been moved successfully to the target table W_PDS_INV_IT_LC_WK_A.
Scenario 4: Updated Data Extracts
  1. Load additional history data as required for the project. For example, you may have started with one month of data for testing and are now going to load an additional 2 years of data.
  2. If the C_LOAD_DATES_CLEANUP_ADHOC process was not run at the start of your current data load, run it now to ensure there are no previous run statuses from past PDS export runs that will interfere with new runs.
  3. Run LOAD_PDS_DIMENSION_PROCESS_ADHOC to ensure the dimensions for PDS are in sync with the new history data being loaded.
  4. Review C_SOURCE_CDC and alter the minimum/maximum dates on each table, if required. If you want to re-push your entire history for a fact, including the previously loaded data, then you will need to adjust the dates before running the extracts.
  5. Run LOAD_PDS_FACT_PROCESS_ADHOC for all the facts, such as sales and receipts, that have had new history loaded in the data warehouse.
  6. Run LOAD_PDS_FACT_INITIAL_PROCESS_ADHOC to pull the desired range of inventory periods.
  7. Verify the target tables contain the expected data before starting the import into Planning applications.
Configure Planning Hierarchy Formats
The export of product and organization hierarchies from the data warehouse to Planning (PDS) can be configured to change format options for certain identifiers and labels. To change the hierarchy format options, you must update the associated parameter in the C_ODI_PARAM table from the list below. After updating these parameters, the next time the W_PDS_PRODUCT_D_JOB or W_PDS_ORGANIZATION_D_JOB jobs are executed, the data will reflect the configuration changes.
Scenario Name Param Name Configuration Guidance
GLOBAL PDS_PROD_INCLUDE_HIER_ID Control whether identifiers are included in the PDS product hierarchy labels (above item level) or not. When set to a value of N, only the hierarchy level descriptions are included in the labels. When set to a value of Y, the hierarchy IDs are concatenated in front of the descriptions on W_PDS_PRODUCT_D.
GLOBAL PDS_PROD_INCLUDE_ITEM_ID Control whether item identifiers are included in the PDS product labels or not. When set to a value of N, only the product descriptions are included in the labels. When changed to a value of Y, the item IDs are concatenated in front of the descriptions on W_PDS_PRODUCT_D.
GLOBAL PDS_PROD_INCLUDE_NS_ITEMS Control whether the PDS product export should include non-sellable items in W_PDS_PRODUCT_D or not. When changed to a value of Y, the export will include non-sellable items. Default = N
GLOBAL ITEM_PARENT_DIFF_SEPARATOR
Set the field separator used when constructing the ITEM_PARENT_DIFF level of the product hierarchy export to PDS. This character will be used to concatenate the item ID and differentiator ID.
Default = _
GLOBAL ITEM_PARENT_DIFF_DESC_SEPARATOR
Set the field separator used when constructing the ITEM_PARENT_DIFF_DESC level of the product hierarchy export to PDS. This character will be used to concatenate the parent item description and differentiator description.
Default = _
GLOBAL PDS_ORG_INCLUDE_HIER_ID Control whether identifiers are included in the PDS organization hierarchy labels (above location level) or not. When set to a value of N, only the hierarchy level descriptions are included in the labels. When set to a value of Y, the hierarchy IDs are concatenated in front of the descriptions on W_PDS_ORGANIZATION_D.
GLOBAL PDS_ORG_INCLUDE_LOC_ID Control whether location identifiers are included in the PDS location labels or not. When set to a value of N, only the location descriptions are included in the labels. When changed to a value of Y, the location IDs are concatenated in front of the descriptions on W_PDS_ORGANIZATION_D.
Sending Daily Data to Planning
All fact interfaces from the Analytics and Planning data warehouse to the Planning applications use week-level aggregated data by default. Some interfaces support changing the data level from weekly to daily, which may be required for specific customizations or extensions that are not part of the base solutions. To change an interface to send daily data instead of weekly data, you must update the associated parameter in the C_ODI_PARAM table from the list below.
GLOBAL
PDS_EXPORT_DAILY_SLS
Set to Y if you want daily data to be sent from the data warehouse to W_PDS_SLS_IT_LC_WK_A. The gross sales table W_PDS_GRS_SLS_IT_LC_WK_A is not affected and remains at week level.
GLOBAL
PDS_EXPORT_DAILY_INV
Set to Y if you want daily data to be sent from the data warehouse to W_PDS_INV_IT_LC_WK_A.
GLOBAL
Set to Y if you want daily data to be sent from the data warehouse to W_PDS_PO_ONORD_IT_LC_WK_A.
GLOBAL
PDS_EXPORT_DAILY_SLSWF
Set to Y if you want daily data to be sent from the data warehouse to W_PDS_SLSWF_IT_LC_WK_A.
GLOBAL
PDS_EXPORT_DAILY_INVRC
Set to Y if you want daily data to be sent from the data warehouse to W_PDS_INVRC_IT_LC_WK_A.
GLOBAL
PDS_EXPORT_DAILY_INVTSF
Set to Y if you want daily data to be sent from the data warehouse to W_PDS_INVTSF_IT_LC_WK_A.
GLOBAL
PDS_EXPORT_DAILY_INVADJ
Set to Y if you want daily data to be sent from the data warehouse to W_PDS_INVADJ_IT_LC_WK_A.
GLOBAL
PDS_EXPORT_DAILY_INVRTV
Set to Y if you want daily data to be sent from the data warehouse to W_PDS_INVRTV_IT_LC_WK_A.
GLOBAL
PDS_EXPORT_DAILY_INVRECLASS
Set to Y if you want daily data to be sent from the data warehouse to W_PDS_INVRECLASS_IT_LC_WK_A.
GLOBAL
PDS_EXPORT_DAILY_MKDN
Set to Y if you want daily data to be sent from the data warehouse to W_PDS_MKDN_IT_LC_WK_A.
GLOBAL
PDS_EXPORT_DAILY_DEALINC
Set to Y if you want daily data to be sent from the data warehouse to W_PDS_DEALINC_IT_LC_WK_A.
GLOBAL
PDS_EXPORT_DAILY_ICM
Set to Y if you want daily data to be sent from the data warehouse to W_PDS_ICM_IT_LC_WK_A.
When an interface is configured for daily data, it changes the source tables used in the data warehouse. For example, weekly sales data comes from W_RTL_SLS_IT_LC_WK_A. When using daily interfaces, the sales data will come from W_RTL_SLS_IT_LC_DY_A instead. It is necessary to populate these tables as part of your historical data loads before changing any configurations in C_ODI_PARAM. The table below provides the list of daily data tables used by these configurations.
Interface Name Source Tables
Sales
W_RTL_SLS_IT_LC_DY_A, W_RTL_SLSPK_IT_LC_DY_F
Inventory
Purchase Order
Sales Wholesale
W_RTL_SLSWF_IT_LC_DY_F
Receipts
W_RTL_INVRC_IT_LC_DY_F
Transfers
W_RTL_INVTSF_IT_LC_DY_F
Adjustments
W_RTL_INVADJ_IT_LC_DY_F
RTVs
W_RTL_INVRTV_IT_LC_DY_F
Reclass
W_RTL_INVRECLASS_IT_LC_DY_F
Markdown
W_RTL_MKDN_IT_LC_DY_F
Deal Income
W_RTL_DEALINC_IT_LC_DY_F
IC Margin
W_RTL_ICM_IT_LC_DY_F
The inventory and purchase order (PO) interfaces use same source table for both daily and weekly extracts. Because inventory and PO data is positional, it means that every time the batch program is run, it always sends the current date’s full snapshot of data. What changes between the daily and weekly configurations is the value written to EOW_DATE. When the interface is configured for daily data, the EOW_DATE will always reflect the current business date instead of only the week-ending date.
In addition to the configuration parameters in C_ODI_PARAM, you are also expected to change the batch jobs in the AIF DATA schedule in POM to run daily. If the jobs are set to run every day instead of only on week-ending dates, they will incrementally send only the new daily data that has been added or modified since the previous day’s run, with the daily dates written on EOW_DATE instead of the week-ending dates. It is assumed that you have already altered your RPAS configuration to use a base intersection of day level; otherwise, having daily values on EOW_DATE will result in failures when running the MFP or AP batch processes.
Another difference between daily and weekly extracts is the logic used to calculate currency columns. In the weekly extracts, the amounts are pre-converted to primary currency on the source tables and then extracted as-is. For the daily extracts, the day level tables in the data warehouse do not have pre-converted values on them, so the currency conversion is done at runtime by taking the local currency amount (for example, SLS_AMT_LCL) and dividing by the exchange rate (LOC_EXCHANGE_RATE). This conversion should result in the same value as you would find on the week-level table columns (for example, SLS_AMT). Aside from the currency conversion, the base calculations used are the same across the daily and weekly extracts.
Customized Planning Integrations
Some implementations require additional custom data exports into Planning applications which supplement or entirely replace the standard integrations available between AIF and RPAS applications. The PL/SQL package RAF_INTF_SUPPORT_UTIL is available in Innovation Workbench (IW) to support this type of integration requirement. The process to publish data from IW to any existing interface will be similar to the example described here. For this example, the interface will be RDF_FCST_PARAM_CAL_EXP.
To review the interface configuration details for this interface, the following query can be executed:
SELECT * FROM rap_intf_cfg WHERE intf_name = 'RDF_FCST_PARM_CAL_EXP';
The PUBLISH_APP_CODE and CUSTOMER_PUBLISHABLE_FLG values are important to note from the result of this query. First, to publish data to an interface, the publishable flag must be Y for any interface that IW will be populating. If there is a need to publish data for an interface not configured for custom extensions, an SR is required that requests that the following update be made, which will allow publishing data for that interface:
UPDATE rap_intf_cfg
   SET customer_publishable_flg='Y'
COMMIT;
Once the above has been done, the implementer can write code in IW that will publish data to this interface, so that the subscribing application modules can consume it. A sample of how to do this follows:
DECLARE
   --The following is used to capture the ID for a published interface dataset
   v_run_id    NUMBER;
   -- The following is used to allow isolated writing to the interface
   v_partition_name    VARCHAR2(30);
BEGIN
   rap_intf_support_util.prep_intf_run('PDS', 'RDF_FCST_PARM_CAL_EXP', v_run_id, v_partition_name);
   -- Use of Append ensures efficiency, and requires PARTITION ( partition_name )
-- syntax, to ensure the ability to concurrently write to the table
   EXECUTE IMMEDIATE 'INSERT /*+ append */ INTO RDF_FCST_PARM_CAL_EXP partition ( '||v_partition_name|| ') ....  ';
   --NOTE: the .... is to be replaced with the actual list of columns and an appropriate SELECT statement to provide the values to insert into the table.
   --Of importance, it should be noted that the run_id column must be populated with the value that was returned into the v_run_id variable above.
   --After the data has been populated into the above table, it can be made available for retrieval by consuming application modules by the following:
   --Note, the 'PDS' value that is shown below, is fixed according to what was obtained from the query of RAP_INTF_CFG.
   rap_intf_support_util.publish_data('PDS', v_run_id, 'RDF_FCST_PARM_CAL_EXP', 'Ready');
END;
Once the above steps have been completed, the data will be ready to be consumed by the application modules that use this interface.
If an attempt is made to call any of the routines inside RAP_INTF_SUPPORT_UTIL for an interface where the CUSTOMER_PUBLISHABLE_FLG is not set to Y, then an error will be provided indicating that "No Interfaces for [ <values they provided to the procedure> ] are allowed/available to be published from custom code." If this occurs, follow the instructions described above to submit an SR asking for permission to publish data to that interface.
Generating Forecasts for MFP and AP
Before you can complete an MFP or AP implementation, you must set up and run forecasting within AI Foundation Cloud Services and then export the results from AIF to Planning. Access the Forecast Engine from within the AIF user interface and complete the steps outlined in the AI Foundation Implementation Guide section on Forecast Configuration for MFP and AP.
If the run type is active, you will only be able to view the parameters. To edit the parameters, the run type must be inactive.
The “Channel” level in MFP is often referred to as “Area” level in RI and AI Foundation, so be sure to select the correct levels which align to your hierarchy.
Generating Forecasts for Inventory Planning Optimization Cloud Service-Demand Forecasting
Demand and forecasts must be generated first in AI Foundation as part of your Demand Forecasting implementation. The forecasting levels and methods used will vary depending on your implementation needs. For example, your IPOCS-Demand Forecasting forecasts may be at an item/location/week level of granularity instead of higher levels like MFP or AP requires. You will also use other forecasting methods such as Sales & Promo instead of the MFP default method (Auto ES).
IPOCS-Demand Forecasting directly integrates the demand and forecast parameters between AI Foundation Cloud Services and PDS tables using the RAP data exchange layer (RDX) as needed. Outputs from the forecasting engine will be written to tables prefixed with RSE_FCST_*. Outputs from IPOCS-Demand Forecasting back into the data exchange layer will be in tables prefixed with RDF_APPR_FCST_*. For more details on importing the forecasts after they are generated, refer to the IPO Demand Forecasting Implementation Guide. Detailed explanations of the AIF implementation process may be found in the AI Foundation Implementation Guide sections on “Forecast Configuration for IPO-DF and AIF” and "Workflow for IPO-DF Implementation".
Loading Plans to RI
If you are implementing a Planning module and need to generate plan-influenced forecasts (such as the AP in-season forecast) then you will need to first integrate your plans into RI (which acts as the singular data warehouse for this data both when the plans come from Oracle Retail solutions and when they come from outside of Oracle).
If you are pushing the plans from MFP or AP directly, then you will enable a set of POM jobs to copy plan outputs directly to RI tables. You may also use an ad hoc process to move the plan data on-demand during the implementation.
Table 3-11 Plan Extracts from MFP and AP
W_RTL_PLAN1_PROD1_LC1_T1_FS_SDE_JOB
Extract the MFP plan output from the MFP_PLAN1_EXP table in the RDX schema.
W_RTL_PLAN2_PROD2_LC2_T2_FS_SDE_JOB
Extract the MFP plan output from the MFP_PLAN2_EXP table in the RDX schema.
W_RTL_PLAN3_PROD3_LC3_T3_FS_SDE_JOB
Extract the MFP plan output from the MFP_PLAN3_EXP table in the RDX schema.
W_RTL_PLAN4_PROD4_LC4_T4_FS_SDE_JOB
Extract the MFP plan output from the MFP_PLAN4_EXP table in the RDX schema.
W_RTL_PLAN5_PROD5_LC5_T5_FS_SDE_JOB
Extract the AP plan output from the AP_PLAN1_EXPor AP_PLAN2_EXP table in the RDX schema. Update configuration RI_PLAN5_SOURCE in C_ODI_PARAM to change the source table used.
W_RTL_PLAN6_PROD6_LC6_T6_FS_SDE_JOB
Extract the MFP plan output from the MFP_PLAN6_EXP table in the RDX schema.
In all of the jobs above, the target table name is in the job name (such as W_RTL_PLAN2_PROD2_LC2_T2_FS as the target for the PLAN2 extract). Once the data is moved to the staging layer in RI, the source-agnostic fact load jobs will import the data (W_RTL_PLAN2_PROD2_LC2_T2_FS is loaded to W_RTL_PLAN2_PROD2_LC2_T2_F, and so on). The fact tables in RI are then available for AI Foundation jobs to import them as needed for forecasting usage.
The plan tables in RI have configurable levels based on your Planning implementation. The default levels are aligned to the standard outputs of MFP and AP if you do not customize or extend them. If you have modified the planning solution to operate at different levels, then you must also reconfigure the RI interfaces to match. This includes the use of flexible alternate hierarchy levels (for example, the PRODUCT_ALT.csv interface) which require custom configuration changes to the PLAN interfaces before you can bring that data back to RI and AIF. These configurations are in C_ODI_PARAM_VW, accessed from the Control & Tactical Center in AI Foundation. For complete details on the plan configurations in RI, refer to the Retail Insights Implementation Guide.
Loading Forecasts to RI
If you are implementing IPOCS-Demand Forecasting and RI, then you may want to integrate your approved forecast with RI for reporting. The same RI interfaces are used both for IPOCS-Demand Forecasting forecasts and external, non-Oracle forecasts.
If you are pushing the forecast from IPOCS-Demand Forecasting, use a set of POM jobs to copy forecast outputs directly to RI tables. You may also use an ad hoc process to move the forecast data on-demand during the implementation. The process names for the two interfaces are LOAD_PLANFC1_DATA_ADHOC and LOAD_PLANFC2_DATA_ADHOC. These processes should be scheduled to run automatically outside of batch, as this is the preferred way to integrate forecast data (because the volume can be large and you do not want it to impact the nightly batch cycle times).
You must also map the desired forecast run type to the RI application code from the AI Foundation user interface. Once this is done, the integration jobs can detect data to extract. Only one run type can be mapped to RI at this time; use a SKU/store/week run type, unless you have reconfigured the RI interfaces for some other intersection.
Table 3-12 Forecast Extracts from AIF and IPOCS-Demand Forecasting
W_RTL_PLANFC_PROD1_LC1_T1_FS_SDE_JOB
Extracts the baseline forecast from the AI Foundation table RSE_FCST_DEMAND_DTL_CAL_EXP in the RDX schema.
W_RTL_PLANFC_PROD2_LC2_T2_FS_SDE_JOB
Extracts the final, approved forecast from the AI Foundation view RSE_RDF_APPR_FCST_VW, which contains only the approved forecast export from IPOCS-Demand Forecasting. Requires a run type mapped to the RI app code.
In all of the jobs above, the target table name is in the job name (such as W_RTL_PLANFC_PROD1_LC1_T1_FS as the target for the PLANFC1 extract). Once the data is moved to the staging layer in RI, the source-agnostic fact load jobs will import the data (W_RTL_PLANFC_PROD1_LC1_T1_FS is loaded to W_RTL_PLANFC_PROD1_LC1_T1_F, and so on).
The forecast tables in RI have configurable levels based on your implementation. The default levels are aligned to the standard outputs of AI Foundation and IPOCS-Demand Forecasting (item/location/week) if you do not customize or extend them. If you have modified the IPOCS-Demand Forecasting solution to operate at different levels, then you must also reconfigure the RI interfaces to match. These configurations are in C_ODI_PARAM_VW, accessed from the Control & Tactical Center in AI Foundation. For complete details on the forecast configurations in RI, refer to the Retail Insights Implementation Guide.
Loading Aggregate History Data
If you are only looking to implement a Planning solution or certain basic modules of AI Foundation and you cannot provide transaction-level history data, then you have the option to load pre-aggregated historical fact data into RAP, bypassing the usual transaction-level interfaces. The custom fact aggregates allow for up to 4 different intersections of measure data at levels at or above item/location/date. The fact columns are generic and accept various numeric measure data across all typical functional areas (sales, receipts, inventory, transfers, and so on) in the same interface. The non-numeric fields on each interface are only for integration to PDS; they won’t be used by AI Foundation.
The aggregate fact interface files and their associated data warehouse tables are listed below. Refer to the RAP Interfaces Guide in My Oracle Support for complete file specifications.
Filename Staging Table Target Table
W_RTL_FACT1_PROD1_LC1_T1_FS.dat
W_RTL_FACT2_PROD2_LC2_T2_FS.dat
W_RTL_FACT3_PROD3_LC3_T3_FS.dat
W_RTL_FACT4_PROD4_LC4_T4_FS.dat
You must configure the data intersections for these tables before you can use them, as each table can only have one intersection defined. The parameters are in the C_ODI_PARAM_VW table in the Control & Tactical Center Manage System Configurations screen. The parameters for each interface are listed below.
Parameter Name Default Value
RI_FACT1_ATTR_LEVEL
ALL
RI_FACT1_CAL_LEVEL
DAY
RI_FACT1_ORG_LEVEL
LOCATION
RI_FACT1_PROD_LEVEL
ITEM
RI_FACT1_SUPP_LEVEL
ALL
RI_FACT2_ATTR_LEVEL
ALL
RI_FACT2_CAL_LEVEL
DAY
RI_FACT2_ORG_LEVEL
LOCATION
RI_FACT2_PROD_LEVEL
ITEM
RI_FACT2_SUPP_LEVEL
ALL
RI_FACT3_ATTR_LEVEL
ALL
RI_FACT3_CAL_LEVEL
DAY
RI_FACT3_ORG_LEVEL
LOCATION
RI_FACT3_PROD_LEVEL
ITEM
RI_FACT3_SUPP_LEVEL
ALL
RI_FACT4_ATTR_LEVEL
ALL
RI_FACT4_CAL_LEVEL
DAY
RI_FACT4_ORG_LEVEL
LOCATION
RI_FACT4_PROD_LEVEL
ITEM
RI_FACT4_SUPP_LEVEL
ALL
In the current release, the ATTR and SUPP parameters should remain as ALL; other options are not supported when integrating the data throughout the platform. You can configure the PROD, ORG, and CAL levels for each interface to match the intersection of data being loaded there. Valid parameter values for each type are listed below.
Product (PROD) Organization (ORG) Calendar (CAL)
CMP
COMPANY
YEAR
DIV
CHAIN
HALFYEAR
GRP
AREA
QUARTER
DEPT
REGION
PERIOD
CLS
DISTRICT
WEEK
SBC
LOCATION
DAY
ITEM
Before using the interfaces, you must also partition them using either day- or week-level partitioning (depending on the data intersections specified above). Partitioning is controlled using two tables accessible from the Control & Tactical Center: C_MODULE_ARTIFACT and C_MODULE_EXACT_TABLE. There is also an APEX function that will take care of the configurations for you and is the recommended way to alter the calendar level of a flexible fact interface.
For the function call, specify your target table name along with a value of DAY or WEEK in the process call below. If you already ran this once, but are changing the level to a different value, then run it again for the new value (for example, changing from DAY to WEEK, or WEEK to DAY). When changing the value, existing partitions will be dropped and all data purged in order to reconfigure the interface, so backup any data which needs to be preserved.
BEGIN
RI_SUPPORT_UTIL.CONFIGURE_CAL_LEVEL_FOR_TABLE(p_table_name => 'W_RTL_FACT1_PROD1_LC1_T1_F', p_cal_level => 'DAY');
END;
After the interfaces are configured, you must prepare the data files for upload following these guidelines:
  • All key columns on the interface must be populated, even if you have specified ALL as the data level. You should use a default value of -1 to populate these fields. This includes the fields PROD_DH_NUM, PROD_DH_ATTR, ORG_DH_NUM, SUPPLIER_NUM, and CAL_DATE.
  • The calendar (CAL_DATE) field must always be a date. If loading the data above day level, use the end-of-period date. The format must match the date mask specified on the context (CTX) file.
  • The PLANNING_TYPE_CODE field was originally used to specify whether the planning domain was COST or RETAIL, but this makes no functional difference in the datafile at this time and can be set to any value for your own reference.
  • The VERSION_NUM field is for future use, it can be defaulted to a value of 0.
  • The DATASOURCE_NUM_ID field must be provided with a hard-coded value of 1, similar to all other interface specifications that contain this column.
  • The INTEGRATION_ID field must be provided with a unique value that identifies the record, such as a concatenation of all primary key values.
  • The data file should be formatted based on the options specified in the associated context (CTX) file, such as choosing to use pipes or commas for delimiters.
To load the files into the data warehouse, use the standalone process in the AIF DATA schedule named HIST_AGGR_FACT_LOAD_ADHOC. Make sure you enable and run all jobs related to your target table (such as W_RTL_FACT1_PROD1_LC1_T1_F). The sequence of jobs to be executed for one table is like this:
  1. VARIABLE_REFRESH_JOB
  2. ETL_REFRESH_RI_JOB
  3. W_RTL_FACT1_PROD1_LC1_T1_FS_COPY_JOB
  4. W_RTL_FACT1_PROD1_LC1_T1_FS_STG_JOB
  5. W_FACT1_PROD1_LC1_T1_F_VALIDATOR_JOB
  6. W_RTL_FACT1_PROD1_LC1_T1_TMP_JOB
  7. W_RTL_FACT1_PROD1_LC1_T1_F_JOB
  8. RABE_TO_RTLWSP_GRANTS_JOB
To push the data downstream to Planning applications, use the standalone processes named LOAD_PDS_FACT1_AGGR_PROCESS_ADHOC through LOAD_PDS_FACT4_AGGR_PROCESS_ADHOC. The planning loads will populate RDX schema tables, such as W_PDS_FACT1_PROD1_LC1_T1_F, which can then be used for customizations and extensions in PDS (in the GA solutions this data would not be used).
After data is loaded into the core data warehouse tables, you will also need to configure and load the AI Foundation application tables before the data is accessible to any AIF modules. Because the intersections for the data are flexible and the populated columns are unknown until the data is loaded, you will need to instruct the system on how to use your aggregate data.
The measure metadata will be stored in the AIF table RSE_MD_CDA. This table is loaded programmatically using an ad hoc job in the RSP schedule named RSE_AGGREGATE_METADATA_LOAD_ADHOC_JOB. The program will detect the columns with data and add entries for each measure with a generic name assigned. Once the program is complete, you can modify the UI display name to be something meaningful to end-users from the Control & Tactical Center.
The measures themselves will first be loaded into RSE_PR_LC_CAL_CDA, which is the staging area in AIF to prepare the measures for the applications. After the metadata is configured, you may run another ad hoc job in the RSP schedule named RSE_AGGREGATE_ACTUALS_LOAD_ADHOC_JOB. This will populate the columns in RSE_PR_LC_CAL_CDA based on their metadata.
Lastly, you must map the measure data into the application tables that require access to aggregate facts. This is performed using the configuration table RSE_MD_FACT_COLUMN_MAP, which is accessible for inserts and updates in the Control & Tactical Center. Possible configuration options supported by the AIF applications will be listed in their respective implementation guides, but a sample set of values is provide below for a sales and inventory measure mapping, which will be the most common use cases:
SOURCE_TABLE SOURCE_COLUMN TARGET_TABLE TARGET_COLUMN
SLSRG_QTY
RSE_SLS_PR_LC_WK
SLS_QTY
BOH_QTY
RSE_INV_PR_LC_WK_A
INV_QTY_BOH
Separate POM jobs are included in the RSP schedule to move the data from the CDA tables to their final target tables. The jobs will come in pairs and have job names ending in AGGR_MEAS_SETUP_ADHOC_JOB followed by AGGR_MEAS_PROCESS_ADHOC_JOB. For example, to load the sales table in the sample mapping, use RSE_SLS_PR_LC_WK_AGGR_MEAS_SETUP_ADHOC_JOB and RSE_SLS_PR_LC_WK_AGGR_MEAS_PROCESS_ADHOC_JOB. For additional details on the individual AIF application usage of these mappings and jobs, refer to the AIF Implementation Guide.
If you need in-season forecasts, then you must plan to configure MFP or AP plan exports to RI as part of your planning implementation. You must populate the same columns on the plan exports that you are using on the FACT1-4 interfaces for actuals. When doing in-season forecasts with aggregated data, it expects the same column in a PLAN and FACT table at the same intersection so that it can load the associated plan measure for the actuals and do a plan-influenced forecast run. For example, if you are populating the SLS_QTY column on the FACT1 interface, then you must also send an SLS_QTY value on the PLAN1 interface or else it won’t be used in the plan-influenced forecast.
Migrate Data Between Environments
The process of moving all your data from one cloud environment to another is referred to as a “lift-and-shift” process. It is common to perform all of the dataload activities in this chapter in one environment, then have the final dataset copied into another environment (instead of reloading it all from the beginning). This activity is performed by Oracle and can be requested using a Service Request. The lift-and-shift process can take several days to complete, depending on data volumes and how many other Oracle applications may be involved. It is expected that you will raise SRs to schedule the activity at least 2-3 weeks in advance of the target date.
When requesting the activity, you may specify if you need to migrate the entire database (both data and structures) or only the data. The first time doing this process must be a full migration of data and structures to synchronize the source and target environments. It is currently recommended to begin your implementation in the Production environment to avoid needing a lift-and-shift in order to go live. Around the time of your go-live date, you can request a lift-and-shift be done into your non-production environments to synchronize the data for future use.
The product versions between the source and target must be aligned. It is the project team’s responsibility to plan for appropriate upgrades and lift-and-shift activities such that this will be true.
