IDCS or OCI IAM Scope
The authentication scope is a code associated with the specific environment you are planning to interact with. It has a static prefix based on the application, appended with an environment-specific code and index.
Base format: rgbu:rsp:psraf-<ENV><ENVINDEX>
Where <ENV>
is replaced with one of the codes in (PRD
, STG
) and <ENVINDEX>
is set to 1, unless you have multiple staging environments, and then the index can be 2 or greater.
To determine this information, look at the URL for your environment, such as:
https://rap.retail.eu-frankfurt-1.ocs.oraclecloud.com/rgbu-rap-hmcd-stg1-rsp/orase/faces/Home
In the tenant string, you can see the code stg1
. This can be added to your scope string (ensuring it
is in uppercase characters only).
IDCS_SCOPE
= rgbu:rsp:psraf-STG1
