D Appendix: Extensibility
As described in Implementation Considerations, apart from configuring the AP application through the plug-ins, AP also supports extensibility of the GA configuration (template version) for customers. This appendix describes the rules and restrictions enforced to extend the AP GA configuration, so as to preserve the customizations in future patches and upgrades.
AP also provides a mechanism for implementers to extend the AP Batch process and allows custom rule groups to be executed during the batch.
Supported Customization of the AP Configuration
The following sections list the customizations that are allowed to the AP configuration. All the names of the custom realized measure, rule set, rule group, rule, workbook, and worksheet should begin with the prefix c_ or C_.
Rules for Customizing the Hierachy
The following hierarchy customizations are allowed to the AP configuration:
Clients are allowed to add a new hierarchy or new dimension into the existing hierarchy. No dimension can be added to the calendar hierarchy that is below day. No change can be made to the AP internal hierarchies.
Clients are allowed to change the label of existing hierarchies or dimensions.
All the dimension and roll-up order in the product, RHS product, location, and RHS location hierarchy must be preserved in the custom configuration.
Rules for Adding Measures
The following rules apply when adding measures to the AP configuration:
Clients are allowed to add new custom measures into the custom solution and reference them as an external measure in the existing AP solution. No new measures should be added to the existing AP GA solution.
Clients can also add a new custom metric as a major component in the extensible solutions. It is strongly recommended not to mix custom metrics with the AP metrics.
Custom measures should follow the naming convention and should begin with a C_ or c_ prefix.
Currently, only the GA measures listed in the following tables can be used in custom rules and custom workbooks.
Table D-1 Extensible GA Measures for AP Cloud Service
| GA Measure | Label |
DRDVUnElapB |
UnElapsed |
DRDVElapB |
Elapsed |
DRDVElapI |
Elapsed Index |
ISWPSLS1R |
Wp Sales Reg + Promo R |
ISWPSLS1U |
Wp Sales Reg + Promo U |
ISWPSLS1C |
Wp Sales Reg + Promo C |
ISWPRCPTR |
Wp Receipts R |
ISWPRCPTU |
Wp Receipts U |
ISWPRCPTC |
Wp Receipts C |
ISWPEOPR |
Wp EOP R |
ISWPEOPU |
Wp EOP U |
ISWPEOPC |
Wp EOP C |
ISWPGMR |
Wp GM R |
ISWPNGMR |
Wp Net GM R |
Rules for Adding Custom Rules
The following rules apply when adding custom rules to the AP configuration:
Custom rule sets, rule groups, and rule names should begin with the C_ or c_ prefix.
Custom rule groups should not include any GA rules.
Custom rules can use the published extensible GA measures listed in the tables above. However, the custom rules cannot modify the value of the GA measure. Hence the extensible GA measure cannot appear on the LHS of a custom rule.
Rules for Workbooks and Worksheets Extensibility
The following rules apply when adding custom rules to the AP workbooks and worksheets extensibility:
New custom workbook and worksheets names should begin with the C_ or c_ prefix.
Apart from the custom solution, custom workbooks can also be added to the extensible AP GA solutions.
Rules for Adding Custom Styles
The following rules apply when adding new styles:
Existing styles cannot be modified.
New custom styles can be added with the C_ or c_ prefix.
New custom styles can be only used against new custom measures.
Rules for Adding Custom Real-Time Alerts into Existing Workbooks
Perform the following steps when adding custom real-time alerts into existing workbooks:
These steps have to be performed using RPAS Configuration Tools. Copying, pasting, or direct editing of xml files is prohibited.
To add custom real-time alert into existing workbooks, all measures related to the custom real-time alert need to be added to the workbook.
Create a style for the custom real-time alert in the configuration.
Create a custom real-time alert in an AP workbook using the measures and style created from the previous steps.
If a real-time alert defined in the custom solution will be used in a GA workbook, the real-time alert measure should be imported as an external measure in the corresponding GA solution.
The AP plug-in will preserve a custom real-time alert during regeneration.
Adding a Custom Solution
A custom solution is a separate solution within the AP Configuration. It can be used to accommodate custom workbooks, rules, and alerts to do custom reporting, custom logic, and threshold alerts by using GA measures based on the extensible GA measures in Table D-1. In addition, measures and alerts defined in the custom solution can be plugged into existing workbooks in the GA solution based on the contexts defined. Clients are allowed to create their own custom solutions by following the rules described above. To use a GA measure in custom workbooks, the GA measure should be imported as an external measure into the custom solution.
Validating the Customized Configuration
The script, ra_config_validation.ksh, is provided
to allow the customer or implementer to validate that the customizations
conform to the rules outlined above.
This script can be run on Windows with the AP Cloud Service Starter Kit.
For example, if the custom configuration is in C:\Oracle\configurations\ascs
and the updated batch_control files are copied to C:\Oracle\configurations\batch_control_cust, then the script can be called from a Cygwin zsh shell:
$RPAS_HOME/bin/ra_config_validation.ksh -c
/cygdrive/c/Oracle/configurations/ascs/ascs.xml -b
/cygdrive/c/Oracle/configurations/batch_control_custNote:
If there are no changes to the batch control files, there is no need to use the -b option.
Successful Run of the Validation Script
If all the validations pass, it will output the following message:
Example of Message for Successful Run of the Validation Script
09:04:47 : INFORMATION : ra_config_validation.ksh[0] - ra_config_validation.ksh completed. 09:04:47 : INFORMATION : ra_config_validation.ksh[0] - Program completed successfully. 09:04:47 : INFORMATION : ra_config_validation.ksh[0] - Exiting script with code: 0
Unsuccessful Run of the Validation Script
If all the validations do not pass, it will output the following message:
The bold line shows where the details of the validation failure are in the log. (In the actual log, this line is not bold.)
Example of Message for Unsuccessful Run of the Validation Script
09:15:12 : INFORMATION : ra_config_validation.ksh[0] - For details of validation, look in '/cygdrive/d/retek/logs/2017-07-18/ra_config_validation.091506.1/ra_ config_validation.log'.
09:15:12 : INFORMATION : ra_config_validation.ksh[0] - _call executing command 'execplug-inTask.sh
ASCS:com.retek.labs.ascs.plug-in.installer.ASCSConfigurationValidation
/cygdrive/c/Oracle/configurations/GA/ascs/ascs.xml
ascs'
09:15:17 : INFORMATION : ra_config_validation.ksh[0] - _call of command
'execplug-inTask.sh
ASCS:com.retek.labs.ASCS.plug-in.installer.ASCSConfigurationValidation
ascs' complete
09:15:17 : ERROR : ra_config_validation.ksh[0] - Nonzero exit status code.
09:15:17 : INFORMATION : ra_config_validation.ksh[0] - Exiting script with code:
9Hiding Components of the GA Configuration
As part of extensibility, AP provides a mechanism wherein the implementer
can hide certain components of the GA configuration by editing a property
file. The property file is a simple text file named extend_app.properties and is located inside the plug-in directory of the configuration.
For example, ascs\plug-ins\extend_app.properties. The format of the file is shown as: Stage|Component|Action|Value
For example, Customization | Worksheet | Hide | MT_TB01_WS01
Each line consists of four fields separated by the | character. The value field can contain a comma separated list of values. Any line that begins with a # character is considered a comment line and is ignored. A sample file is included in the plug-ins directory of the GA configuration for reference.
The only action that can be performed on the GA configuration components is Hide.
The names of the Taskflow entities can be found in the taskflow.xml file located in the configuration directory.
The various GA configuration components that can be hidden are listed in the following table:
| Component | Description |
Activity |
Perform the action (for example, Hide) on the specified Taskflow activity. The value field is the taskflow activity name. |
Task |
Perform the action (for example, Hide) on the specified Taskflow task. The value field is the taskflow task name. |
Step |
Perform the action (for example, Hide) on the specified Taskflow step. The value field is the taskflow step name. |
Worksheet |
Perform the action (for example, Hide) on the specified worksheet. The value field is the worksheet name. |
Realtime Alert |
Perform the action (for example, Hide) on the specified Real Time Alert. The value field is the real time alert name. |
Customizing the AP Batch Process
This section describes how to customize the AP GA batch process to meet the business needs of the retailer. Details on the AP GA batch process are described in the Oracle Retail Assortment Planning Cloud Service Administration Guide. The Configured Batch tasks have the following tasks related to batch control:
Retrieve Batch Control File - allows the current batch control files to be retrieved for inspection and modification.
Update Batch Control File - after inspecting the current batch control files, the implementer can edit the batch control files to customize the batch process.
Details on the preceding two tasks are described in the Oracle Retail Assortment Planning Cloud Service Administration Guide.
The AP Batch process is based on the RPAS CE Batch Framework, which makes use of a set of control files.Table D-2 lists the AP Batch control files that can be customized.
Table D-2 Customizable AP Batch Control Files
| Control File | Description |
batch_exec_list.txt |
This is the controller and entry point for all the other services, specifying groups of services to be run in a specific order. |
batch_calc_list.txt |
This control file groups all the calc services that need to run using mace. |
batch_refresh_list.txt |
This control file groups all Workbook refresh rule groups. |
batch_rebuild_list.txt |
This control file groups all Workbook segments that need to be rebuilt in batch. |
batch_loadmeas_list.txt |
This control file groups measures that need to be loaded into the domain using the measure load service. |
batch_exportmeas_list.txt |
This control file groups measures that need to be exported out of the domain using the export measure service. |
batch_xform_list.txt |
This control file handles the transform file service to perform file transformations to support simple integration capabilities. |
batch_oat_list.txt |
This file lists the configured batch tasks that appear in the OAT drop down list. |
The individual control files, including batch_exec_list.txt, can be overridden to customize the batch flow. Each control file uses a set name to control a set of actions. If the override control file uses the same set name as used in GA, the batch task using that set name will use the entries from the override control file. During patches and upgrades, the override control files will be preserved. More details on customizing the batch control files are described in the Oracle Retail Predictive Application Server Cloud Edition Implementation Guide.
The following table describes the behavior of the customized OAT tasks if the customer uploaded their override control files and they differ from the GA task:
E - Set Name Exists
NE - Set Name Does Not Exist
| GA Base Task | GA OAT Task | Customer Base Task | Customer OAT Task | Behavior |
E |
E |
E |
E (New Label) |
Shows new label in the customer OAT. |
E |
E |
E |
NE |
Since the custom OAT does not exist, it shows the GA label in the drop down. But since the GA set name is overridden in the custom batch, the custom set name will be executed. |
E |
E |
NE |
E (New Label) |
Shows the label in the customer OAT (New Label). |
E |
E |
NE |
NE |
Shows the label in the GA OAT. |
NE |
NE |
E |
E (New Label) |
E |
NE |
E |
E |
Hidden in the customer OAT (New Label). Since GA explicitly hides that task, it will not be visible even if the customer used it. |
Custom Hooks and Boolean Scalar Measures for Flow Control
There are two ways to customize the batch control files:
Custom Hooks
The custom hooks are an optional batch set executed by GA batch control files. The implementer can define the contents of these batch sets in the customized batch control files that can be uploaded. If these hooks are not defined, the batch process skips these hooks. If they are defined, its contents are executed.
AP also defines a list of Boolean Scalar Measures in the domain to control if certain GA defined batch sets can be skipped or not. The following tables list the Custom Hooks and Boolean Scalar Measures.
Custom Hooks
The following table describes the Custom Hooks available in the batch process.
Table D-3 Custom Hooks in the Batch Process
| Hook | Description |
hook_postbuild_pre |
This hook is added at the beginning of the postbuild batch which runs after the initial domain build. |
hook_postbuild_post |
This hook is added at the end of the postbuild batch which runs after the initial domain build. |
hook_postpatch |
This hook is added at the end of the service patch process which runs after the service patch. |
hook_batch_daily_pre |
This hook is added before the daily batch process. |
hook_batch_daily_post |
This hook is added at the end of daily batch process before the dashboard build. |
hook_batch_weekly_pre |
This hook is added before the weekly batch process. |
hook_batch_weekly_post |
This hook is added at the end of the weekly batch process before the workbook refresh and segment build. |
If the customer is using the JOS/POM flow schedule to schedule jobs in AP, then the following hooks can be used. The AP JOS/POM job flow is connected to use the same set names similar to the hooks shown in the following table without hook_* in it and in turn calls each of the corresponding hooks. So the customer can easily customize their AP batch flow based on their needs by simply changing the hooks or adding additional steps to the existing pre-configured hooks.
The naming convention followed is _RDX that is used for any integration step using RDX. _OBS is used for any steps using Object Storage. _D is for jobs that needs to run daily. _W is for jobs to be scheduled only once in weekly.
hook_AP_PRE_EXP_RDX_D |
This hook is for the calling steps using the Daily Export Interfaces to RDX as soon as the batch starts. |
hook_AP_PRE_EXP_OBS_D |
This hook is for the calling steps using the Daily Export Interfaces to Object Storage as soon as the batch starts. |
hook_AP_PRE_EXP_RDX_W |
This hook is for calling steps using the Weekly Export Interfaces to RDX as soon as the batch starts. |
hook_AP_PRE_EXP_OBS_W |
This hook is for the calling steps using the Weekly Export Interfaces to Object Storage as soon as the batch starts. |
hook_AP_COM_HIER_IMP_RDX_D |
This hook is for the calling steps using any Daily Import of common hierarchies from RDX. |
hook_AP_COM_HIER_IMP_OBS_D |
This hook is for the calling steps using any Daily Import of common hierarchies from Object Storage. |
hook_AP_COM_HIER_IMP_RDX_W |
This hook is for the calling steps using any Weekly Import of common hierarchies from RDX. |
hook_AP_COM_HIER_IMP_OBS_W |
This hook is for the calling steps using any Weekly Import of common hierarchies from Object Storage. |
hook_AP_COM_DATA_IMP_RDX_D |
This hook is for the calling steps using any Daily Import of common data interfaces from RDX. |
hook_AP_COM_DATA_IMP_OBS_D |
This hook is for the calling steps using any Daily Import of common data interfaces from Object Storage. |
hook_AP_COM_DATA_IMP_RDX_W |
This hook is for the calling steps using any Weekly Import of common data interfaces from RDX. |
hook_AP_COM_DATA_IMP_OBS_W |
This hook is for the calling steps using any Weekly Import of common data interfaces from Object Storage. |
hook_AP_HIER_IMP_RDX_D |
This hook is for the calling steps using any Daily Import of application-specific hierarchies from RDX. |
hook_AP_HIER_IMP_OBS_D |
This hook is for the calling steps using any Daily Import of application-specific hierarchies from Object Storage. |
hook_AP_HIER_IMP_RDX_W |
This hook is for the calling steps using any Weekly Import of application-specific hierarchies from RDX. |
hook_AP_HIER_IMP_OBS_W |
This hook is for the calling steps using any Weekly Import of application-specific hierarchies from Object Storage. |
hook_AP_PRE_DATA_IMP_RDX_D |
This hook is for the calling steps using any Daily Import of application-specific data interfaces from RDX. |
hook_AP_PRE_DATA_IMP_OBS_D |
This hook is for the calling steps using any Daily Import of application-specific data interfaces from Object Storage. |
hook_AP_PRE_DATA_IMP_RDX_W |
This hook is for the calling steps using any Weekly Import of application-specific data interfaces from RDX. |
hook_AP_PRE_DATA_IMP_OBS_W |
This hook is for the calling steps using any Weekly Import of application-specific data interfaces from Object Storage. |
hook_AP_BATCH_AGG_D |
This hook is for the calling steps doing any regular daily batch aggregation after hierarchy and data loads. |
hook_AP_BATCH_AGG_W |
This hook is for the calling steps doing any regular weekly batch aggregation after hierarchy and data loads. |
hook_AP_POST_DATA_IMP_RDX_D |
This hook is for the calling steps using any Daily Import of application-specific data interfaces from RDX after the calc steps. |
hook_AP_POST_DATA_IMP_OBS_D |
This hook is for the calling steps using any Daily Import of application-specific data interfaces from Object Storage after the calc steps. |
hook_AP_POST_DATA_IMP_RDX_W |
This hook is for the calling steps using any Weekly Import of application-specific data interfaces from RDX after the calc steps. |
hook_AP_POST_DATA_IMP_OBS_W |
This hook is for the calling steps using any Weekly Import of application-specific data interfaces from Object Storage after the calc steps. |
hook_AP_POST_EXP_RDX_D |
This hook is for the calling steps using any Daily Exports to RDX after the batch aggs. |
hook_AP_POST_EXP_OBS_D |
This hook is for the calling steps using any Daily Exports to Object Storage after the batch aggs. |
hook_AP_POST_EXP_RDX_W |
This hook is for the calling steps using any Weekly Exports to RDX after the batch aggs. |
hook_AP_POST_EXP_OBS_W |
This hook is for the calling steps using any Weekly Exports to Object Storage after the batch aggs. |
hook_AP_WB_BUILD_D |
This hook is for the calling steps specific to workbook refresh or build in the daily cycle. |
hook_AP_WB_BUILD_W |
This hook is for the calling steps specific to workbook refresh or build in the weekly cycle. |
The following table describes the Boolean Scalar measures.
Table D-4 Boolean Scalar Measures
| Boolean Scalar Measure | Description |
drdvrmsb |
This measure is defaulted to true. Set it to true if AP is integrated with RMF CS. |
drdvbdib |
This measure is defaulted to false. Set it to true enable RAP integration for hierarchy and transaction data. |
drdvexpdb |
This measure is defaulted to true. If set to false, it will skip exporting the standard exports in the daily batch. |
drdvexpwb |
This measure is defaulted to true. If set to false, it will skip exporting the standard exports in the weekly batch. |
AP Batch Control File Customization Guidelines
Follow these guidelines for AP Batch Control File customization:
The file batch_oat_list.txt is the only batch control file in which customers can overwrite the GA set names (such as exec, calc).
For all other batch control files, avoid overwriting the GA set names. GA batch control files have provided various hooks for the batch process. For additional custom steps, try to put them into the hooks.
The GA batch control files have provided a mechanism to skip certain GA steps using the Boolean scalar measure that can be set in the domain. For example, drdvexpwb will allow the skip of standard exports in the weekly batch. To skip the GA steps, use this mechanism instead of overwriting GA set names.
For the GA hierarchy that is unused in your implementation such as the currency hierarchy, provide an empty hierarchy file. For unused GA measures, there is no need to provide the data file. RPAS CE is able to skip it if no files were provided.
For ease of maintenance, all custom batch set names or step names should be prefixed with c_.
Example
Following is an example of the custom batch_exec_list.txt, batch_calc_list.txt, batch_ loadmeas_list.txt, and batch_exportmeas_list.txt files.
In this example, the following modification were added to batch_weekly process:
New Custom Hierarchy and measure data are loaded before the weekly batch.
Additional batch calc and exports after the weekly batch.
Batch Control Samples
The following sections show samples of the batch control processes.
hook_batch_weekly_post |calc |c_calc_vndr
hook_batch_weekly_post |exportmeasure |c_exp_vndr
batch_exec_list.txt
# Load a custom hierarchy, measure before weekly batch hook_batch_weekly_pre |hierload |suph~0~N hook_batch_weekly_pre |measload |c_load_vndr # Run Batch calc and new custom exports after end of weekly batch hook_batch_weekly_post |calc |c_calc_vndr hook_batch_weekly_post |exportmeasure |c_exp_vndr
batch_calc_list.txt
# Run newly added custom calc rule group in batch c_calc_vndr | G | GROUP | c_batch_agg_vndr
batch_loadmeas.txt
# Load custom measure c_load_vndr | M |c_drtyvndrfndr
batch_exportmeas.txt
# Export custom measure c_exp_vndr|O|vendo_plan.csv.dat c_exp_vndr|X|storsclsweek c_exp_vndr|F|c_exportmask c_exp_vndr|M|c_mpcpvndrplan
Custom Batch Control Validation
The extensible/custom batch control files need to follow the guidelines previously listed so as to future proof the retailer. That means the retailer should receive software updates without breaking the existing customizations. To ensure that the batch control file guidelines are adhered to, a batch control validation module has been added.
The as_config_validation script has an optional parameter -b <parent directory of batch control files> which will validate the batch control files.
Batch control validation rules:
Apart from the batch_oat_list, none of the set names in the other batch control files can be overridden. That is, GA set names cannot be used in custom batch control files.
None of the custom batch control files can call the GA set names.
The batch_calc_list can only specify custom rule group names. It cannot specify expressions and GA rule group names.
The batch_loadmeas_list can specify measures newly added custom measures.
The batch_exportmeas_list can specify custom measures or published GA measures.
All custom set names should have a prefix of c_.
Note that the batch control validation is called automatically during a domain build or patch. It is also called when the batch control files are uploaded using the Upload Batch Control files from OAT.
Customizing the AP Dashboard
The AP Dashboard gets the data from the regular dashboard workbook template like any other workbook segments to define the measures used in metric tiles that are shown in the dashboard.
The AP Dashboard also can be customized to extend using the same extensibility rules for regular workbooks for adding new measures into that dashboard workbook (pl_db). The customer can then update the AP Dashboard json file to include the newly added custom measures to show as tiles in the AP Dashboard.
AP uses a pre-range mask to filter items that need to be shown in the dashboard. Those are evaluated in the batch rule group AD_Dash_Agg1 and the measure used for that pre-range is DSDVRnkSrcB. Calculation for that measure can be updated to control what items to bring into the dashboard. Also, if any new metric tiles need to be added, those can be added to the pl_db dashboard workbook as custom measures and that can be brought into the dashboard.
Following are the steps for customizing the AP Dashboard:
Update the AP Configuration to include the required new custom measures and rules to include those measures in the existing dashboard template (pl_db) in the AP Configuration within the regular extensibility framework. Patch the domain with the new updated configuration.
Download the AP dashboard json file (DashboardSettings.json) from the Starter Kit or directly from the customer-provisioned environment by running the Online Administration Tool task Configured Batch Tasks -> Manage JSON Files -> Retrieve JSON files to Object Storage, which will download the JSON file into the Object Storage location at outgoing/dashboardSettings.json.
Open the dashboard json file using the RPAS Configuration Tools -> Utilities -> Deployment Tool and selecting the Open option under dashBoardSettings.json.
It should open the dashboard json file in edit mode. The customer can then edit the dashboard to add the newly added measures into their required profiles. They can also add new profiles or change profiles, but can only use the measures available in the dashboard workbook. For more information on working with the json file using RPAS Configuration Tools, see the Oracle Retail Predictive Application Server Cloud Edition Configuration Tools User Guide.
Once the json file is updated, it can be uploaded into the AP environment after zipping the file, uploading the file to the Object Storage location, and running the Online Administration Tool task Configured Batch Tasks -> Manage JSON Files > Update JSON files from FTP. Successful completion of the task will copy the file to the required location under the application domain.
After uploading, rebuild the dashboard to view the updated dashboard.
The entire process can be validated in the Virtual machine, before trying to upload the completed json file into the customer environment.
