Preface
This document describes the Oracle Retail Assortment Planning Cloud Service user interface. It provides step-by-step instructions to complete most tasks that can be performed through the user interface.
Documentation Accessibility
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
Access to Oracle Support
Oracle customers that have purchased support have access to electronic support through My Oracle Support. For information, visit http://www.oracle.com/pls/topic/lookup?ctx=acc&id=info or visit http://www.oracle.com/pls/topic/lookup?ctx=acc&id=trs if you are hearing impaired.
Related Documents
For more information, see the following documents in the Oracle Retail Assortment Planning Cloud Service Release 22.2.401.0 documentation set:
Oracle Retail Assortment Planning Cloud Service Release Notes
Oracle Retail Assortment Planning Cloud Service User Guide
Oracle Retail Assortment Planning Cloud Service Starter Kit Guide
Oracle Retail Assortment Planning Cloud Service Implementation Guide
Also, see the Oracle Retail Predictive Application Server Cloud Edition documentation set.
Improved Process for Oracle Retail Documentation Corrections
To more quickly address critical corrections to Oracle Retail documentation content, Oracle Retail documentation may be republished whenever a critical correction is needed. For critical corrections, the republication of an Oracle Retail document may at times not be attached to a numbered software release; instead, the Oracle Retail document will simply be replaced on the Oracle Help Center (docs.oracle.com) Web site, or, in the case of Data Models, or, in the case of Data Models, to the applicable My Oracle Support Documentation container where they reside.
Oracle Retail documentation is available on the Oracle Help Center (docs.oracle.com) at the following URL:
https://docs.oracle.com/en/industries/retail/index.html
An updated version of the applicable Oracle Retail document is indicated by Oracle part number, as well as print date (month and year). An updated version uses the same part number, with a higher-numbered suffix. For example, part number E123456-02 is an updated version of a document with part number E123456-01.
If a more recent version of a document is available, that version supersedes all previous versions.
Oracle Retail Documentation on the Oracle Help Center (docs.oracle.com)
Oracle Retail product documentation is available on the following web site:
(Data Model documents can be obtained through My Oracle Support.)
Conventions
The following text conventions are used in this document:
| Convention | Meaning |
boldface |
Boldface type indicates graphical user interface elements associated with an action, or terms defined in text or the glossary. |
italic |
Italic type indicates book titles, emphasis, or placeholder variables for which you supply particular values. |
Monospace type indicates commands within a paragraph, URLs, code in examples, text that appears on the screen, or text that you enter. |
