3 RAP Integration
Planning Solutions built on Planning Data Schema (PDS) can be integrated with AI Foundation (AIF) and Retail Insights (RI) with in Retail Analytics and Planning (RAP) using RAP integration which in turn can get the foundation data from RMFCS or any other systems integrated to RAP. All three solutions (AIF, RI, PDS) within RAP can share data using RAP Data Exchange (RDX) using RAP interfaces.
Planning Solutions, such as APCS, configured and built in PDS using the RPASCE Configuration allows configurable solutions if they are not using template to use their custom hierarchy and fact names. Planning Solutions, such as APCS, allow configuring of interfaces using interface.cfg which controls the mapping of dimensions and facts to columns in the RAP interface staging tables. For more details about configuring interfaces using interfaces.cfg in RAP integration, see the Oracle Retail Predictive Application Server Cloud Edition Implementation Guide. The APCS template version has a pre-configured interface.cfg which contains the mapping of interfaces.
This figure shows the RAP integration.
The above diagram shows the high-level RAP Architecture. The customer can upload their main input files as RAP Inbound Data using Object Storage and from their Planning Applications deployed in PDS can get the same using RDX. For more details about the RAP Inbound Interfaces, see the Oracle Retail Analytics and Planning Implementation Guide. Any supplemental data that is specific to planning can be directly loaded into PDS as PDS Flat Files. This section shows the details about the interfaces used by PDS in RAP using RDX.
Following is the pre-defined grouping of interfaces available in the APCS template version within RAP integration.
Pre-defined imports from RAP integration to APCS:
  • Import Foundation and Transactional data from Retail Insights (RI)
  • Import Forecasts from AI Foundation (AIF)
  • Import DT Parameters from AI Foundation (AIF)
  • Import Location Clusters from AI Foundation (AIF)
  • Import Customer Segments from AI Foundation (AIF)
  • Import Size Profiles from AI Foundation (AIF)
Pre-defined exports to RAP integration to APCS:
  • Export Assortment Periods for Location Clusters from AI Foundation (AIF)
  • Export Active Assortments to AI Foundation (AIF)
  • Export Assortment Plans to Retail Insights (RI)
Import Foundation and Transactional Data from Retail Insights
RMFCS can send Foundation and Transactional data to RAP integration using Retail Insights (RI) and other systems within RAP. The systems can share the data, even if RMFCS is not implemented for the customer. The customer can upload the foundation and data files in the file format needed by RI in RAP integration. That way, the same data can be published to all applications within RAP. It can be done by scheduling required job flows in Retail Insights to get the foundation data from RMFCS and loading it into the staging tables present in Retail Data Exchange (RDX) from where the configured interfaces in APCS can pull the required data into Facts in Planning Data Schema (PDS) where APCS is deployed.
The customer can also load foundation data directly into RAP using the file format specified for RAP integration and using the same staging process in RI to write the data into RDX staging tables from where Planning can pull the data using standard configured interfaces. Only mapped columns specific to GA interfaces are detailed in this guide. For more details about interface file formats and the jobs flow details, see the Oracle Retail Analytics and Planning Implementation Guide. Also refer to those guides to find more information about the available columns in each interface staging tables in RDX sourced from RI so that customers using extensibility on template or using custom configuration (non-template) can pull the required data from RDX.
The following table shows the list of interfaces in RAP to get the foundation and transactional data:
Interface Interface and Table Name Interface Type
Product Hierarchy
W_PDS_PRODUCT_D
Hierarchy Importer
Location Hierarchy
W_PDS_ORGANIZATION_D
Hierarchy Importer
Calendar Hierarchy
W_PDS_CALENDAR_D (VW_CLND_HIER)
Hierarchy Importer
Cluster Hierarchy
VW_CLRH_HIER (W_PDS_ORGANIZATION_D
Hierarchy Importer
Product Attribute Hierarchy
W_PDS_UDA_D
Hierarchy Importer
Sales Interface
W_PDS_SLS_IT_LC_WK_A
Data Importer
Inventory Interface
W_PDS_INV_IT_LC_WK_A
Data Importer
On Order Interface
W_PDS_PO_ONORD_IT_LC_WK_A
Data Importer
Receipts Interface
W_PDS_INVRC_IT_LC_WK_A
Data Importer
Inventory Transfers
W_PDS_INVTSF_IT_LC_WK_A
Data Importer
Markdowns Interface
W_PDS_MKDN_IT_LC_WK_A
Data Importer
Wholesale/Franchise
W_PDS_SLSWF_IT_LC_WK_A
Data Importer
Product Attributes
W_PDS_PRODUCT_ATTR_D
Data Importer
Location Data
VW_LOC_DATA
Data Importer
Product Data
VW_PROD_DATA
Data Importer
UDA Data
VW_UDA_DATA
Data Importer
Location Attributes Hierarchy VW_SATR_HIER Hierarchy Importer
Customer Segment Hierarchy W_PDS_CUSTSEG_D Hierarchy Importer
Location Attributes W_PDS_ORG_ATTR_STR_D
Data Importer
The following table shows the mapping of dimensions to columns for Hierarchy Importer interfaces from external interface tables:
Hierarchy Dimension External Interface Table External Mapped Column
prod
sku
W_PDS_PRODUCT_D
ITEM
prod
sku_label
W_PDS_PRODUCT_D
ITEM_DESC
prod
skup
W_PDS_PRODUCT_D
ITEM_PARENT_DIFF
prod
skup_label
W_PDS_PRODUCT_D
ITEM_PARENT_DIFF_DESC
prod
skug
W_PDS_PRODUCT_D
ITEM_PARENT
prod
skug_label
W_PDS_PRODUCT_D
ITEM_PARENT_DESC
prod
scls
W_PDS_PRODUCT_D
CLASS_ID
prod
scls_label
W_PDS_PRODUCT_D
DEPT
prod
clss
W_PDS_PRODUCT_D
GROUP_NO
prod
class_label
W_PDS_PRODUCT_D
DIVISION
prod
dept
W_PDS_PRODUCT_D
COMPANY
prod
dept_label
W_PDS_PRODUCT_D
CO_NAME
prod
pgrp
W_PDS_PRODUCT_D
GROUP_NO
prod
pgrp_label
W_PDS_PRODUCT_D
GROUP_NAME
prod
dvsn
W_PDS_PRODUCT_D
DIVISION
prod
dvsn_label
W_PDS_PRODUCT_D
DIV_NAME
prod
cmpp
W_PDS_PRODUCT_D
COMPANY
prod
cmpp_label
W_PDS_PRODUCT_D
CO_NAME
prod
vndr
W_PDS_PRODUCT_D
SUPPLIER
prod
vndr_label
W_PDS_PRODUCT_D
SUP_NAME
prod
brnd
W_PDS_PRODUCT_D
BRAND_NAME
prod
brnd_label
W_PDS_PRODUCT_D
BRAND_DESCRIPTION
prod
sta1
W_PDS_PRODUCT_D
NA
prod
sta1_label
W_PDS_PRODUCT_D
Unassigned
loc
stor
LOCATION
loc
stor_label
LOC_NAME
loc
dstr
DISTRICT
loc
dstr_label
DISTRICT_NAME
loc
regn
REGION
loc
regn_label
REGION_NAME
loc
chnl
AREA
loc
chnl_label
AREA_NAME
loc
chan
CHAIN
loc
chan_label
CHAIN_NAME
loc
comp
COMPANY
loc
comp_label
CO_NAME
loc
phwh
PHYSICAL_WH
loc
phwh_label
PHYSICAL_WH_NAME
loc
loct
LOC_TYPE
loc
loct_label
LOC_TYPE_NAME
loc
strc
LOCATION
loc
strc_label
LOCATION_NAME
loc
chnc
PLANNING_CHANNEL_ID
loc
chnc_label
PLANNING_CHANNEL_NAME
loc
ccty
PLANNING_COUNTRY_ID
loc
ccty_label
PLANNING_COUNTRY_NAME
clnd
day
W_PDS_CALENDAR_D
DAY
clnd
day_label
W_PDS_CALENDAR_D
DAY_LABEL
clnd
week
W_PDS_CALENDAR_D
WEEK
clnd
week_label
W_PDS_CALENDAR_D
WEEK_LABEL
clnd
mnth
W_PDS_CALENDAR_D
MNTH
clnd
mnth_label
W_PDS_CALENDAR_D
MNTH_LABEL
clnd
qrtr
W_PDS_CALENDAR_D
QRTR
clnd
qrtr_label
W_PDS_CALENDAR_D
QRTR_LABEL
clnd
half
W_PDS_CALENDAR_D
HALF
clnd
half_label
W_PDS_CALENDAR_D
HALF_LABEL
clnd
year
W_PDS_CALENDAR_D
YEAR
clnd
year_label
W_PDS_CALENDAR_D
YEAR_LABEL
clnd
woyr
W_PDS_CALENDAR_D
WOYR
clnd
woyr_label
W_PDS_CALENDAR_D
WOYR_LABEL
clnd
stdb
W_PDS_CALENDAR_D
STDB
clnd
stdb_label
W_PDS_CALENDAR_D
STDB_LABEL
clnd
hldy
W_PDS_CALENDAR_D
NA
clnd
hldy_label
W_PDS_CALENDAR_D
Unassigned
clnd
evnt
W_PDS_CALENDAR_D
NA
clnd
evnt_label
W_PDS_CALENDAR_D
Unassigned
clnd
bypd
W_PDS_CALENDAR_D
NA
clnd
bypd_label
W_PDS_CALENDAR_D
Unassigned
clrh
clus
VW_CLRH_HIER
CLUS_ID
clrh
clus_label
VW_CLRH_HIER
CLUS_DESC
patr
patv
W_PDS_UDA_D
(VW_PATR_HIER)
PROD_ATTR_VALUE
patr
patv_label
W_PDS_UDA_D
(VW_PATR_HIER)
PROD_ATTR_VALUE_DESC
patr
patt
W_PDS_UDA_D
(VW_PATR_HIER)
PROD_ATTR
patr
patt_label
W_PDS_UDA_D
(VW_PATR_HIER)
PROD_ATTR_DESC
satr satt VW_SATR_HIER ATTR_ID
satr satt_label VW_SATR_HIER ATTR_DESC
satr satv VW_SATR_HIER ATTR_VALUE
satr satv_label VW_SATR_HIER ATTR_VALUE_DESC
csgh csvd W_PDS_CUSTSEG_D CUSTSEG_ID
csgh csvd_label W_PDS_CUSTSEG_D CUSTSEG_NAME
csgh csgd W_PDS_CUSTSEG_D CUSTSEG_ID
csgh csgd_label W_PDS_CUSTSEG_D CUSTSEG_NAME
Note: For Calendar Hierarchy (clnd), RMFCS is not sending the labels. Internally, VW_CLND_HIER is defined in PDS against the interface W_PDS_CALENDAR_D table to derive the labels and also default the calendar import to PDS to have two past years, one current year, and two future years based on the current business date. The Administrator can update the same using the Online Administration Tool Tasks under System Admin Tasks -> List/Set/Unset PDS Integration variables and can update the CLND_PAST_YEARS and CLND_FUTURE_YEARS variables. By default, both are set to 2. The customer can also update the start fiscal month by setting the CLND_START_MONTH variable. By default, it is set to 2 to have the fiscal start month label be generated as February.
Note: For Cluster Hierarchy (clrh), there is no direct interface table. Internally, VW_CLRH_HIER is defined in PDS against the interface W_PDS_ORGANIZATION_D table to get the locations as cluster ids.
Note: The VW_PATR_HIER view is an internal view in PDS against the base RDX tables W_PDS_UDA_D, W_PDS_DIFF_D, W_PDS_SUPPLIER_D, and W_PDS_BRAND_D by concatenating all of them as product attributes. It also concatenates the product attribute name with the product attribute values using ‘_’ to make the product attribute values unique. The Product Attribute name for Supplier (W_PDS_SUPPLIER_D) is used as ‘supp’ and Brand (W_PDS_BRAND_D) is used as ‘brnd’. Only Product attributes with UDA_TYPE_CODE as ‘LV’ from W_PDS_UDA_D are included in the view.
Note: For the Location Attribute Hierarchy (SATR), there is no direct interface table. Internally, VW_SATR_HIER is defined in PDS against the interface W_PDS_ORG_ATTR_STR_D table to get the distinct location attributes.
Note: For all APCS hierarchies that are not integrated using RAP integration, the customer needs to explicitly provide those files.
The following table shows the mapping of fact names/measures names to columns for the Data Importer interfaces from the external interface tables in RDX:
Fact Name External Interface Table External Mapped Column External Mapping Condition
drtyeop1c
REGULAR_INVENTORY_COST
CLEAR_IND = 'N'
drtyeop1r
REGULAR_INVENTORY_RETAIL
CLEAR_IND = 'N'
drtyeop1u
REGULAR_INVENTORY_UNITS
CLEAR_IND = 'N'
drtyeop2c
CLEAR_IND = 'Y'
drtyeop2r
CLEAR_IND = 'Y'
drtyeop2u
CLEAR_IND = 'Y'
drtynslsclrc
NET_SALES_CLR_COST
drtynslsclrr
NET_SALES_CLR_RETAIL
drtynslsclru
NET_SALES_CLR_UNITS
drtynslsproc
NET_SALES_PRO_COST
drtynslspror
NET_SALES_PRO_RETAIL
drtynslsprou
NET_SALES_PRO_UNITS
drtynslsregc
NET_SALES_REG_COST
drtynslsregr
NET_SALES_REG_RETAIL
drtynslsregu
NET_SALES_REG_UNITS
drtyrtnclrc
RETURNS_CLR_COST
drtyrtnclrr
RETURNS_CLR_RETAIL
drtyrtnclru
RETURNS_CLR_UNITS
drtyrtnproc
RETURNS_PRO_COST
drtyrtnpror
RETURNS_PRO_RETAIL
drtyrtnprou
RETURNS_PRO_UNITS
drtyrtnregc
RETURNS_REG_COST
drtyrtnregr
RETURNS_REG_RETAIL
drtyrtnregu
RETURNS_REG_UNITS
drtyooc
ON_ORDER_COST
drtyoor
ON_ORDER_RETAIL
drtyoou
ON_ORDER_UNITS
drtyporcptc
PO_RECEIPT_COST
drtyporcptr
PO_RECEIPT_RETAIL
drtyporcptu
PO_RECEIPT_UNITS
drtytraninbc
TSF_IN_COST
TSF_TYPE = 'B'
drtytraninbr
TSF_IN_RETAIL
TSF_TYPE = 'B'
drtytraninbu
TSF_IN_UNITS
TSF_TYPE = 'B'
drtytraninic
TSF_IN_COST
TSF_TYPE = 'I'
drtytraninir
TSF_IN_RETAIL
TSF_TYPE = 'I'
drtytraniniu
TSF_IN_UNITS
TSF_TYPE = 'I'
drtytraninr
TSF_IN_RETAIL
TSF_TYPE = 'N'
drtytraninc
TSF_IN_COST
TSF_TYPE = 'N'
drtytraninu
TSF_IN_UNITS
TSF_TYPE = 'N'
drtytranoutbc
TSF_OUT_COST
TSF_TYPE = 'B'
drtytranoutbr
TSF_OUT_RETAIL
TSF_TYPE = 'B'
drtytranoutbu
TSF_OUT_UNITS
TSF_TYPE = 'B'
drtytranoutic
TSF_OUT_COST
TSF_TYPE = 'I'
drtytranoutir
TSF_OUT_RETAIL
TSF_TYPE = 'I'
drtytranoutiu
TSF_OUT_UNITS
TSF_TYPE = 'I'
drtytranoutr
TSF_OUT_RETAIL
TSF_TYPE = 'N'
drtytranoutu
TSF_OUT_UNITS
TSF_TYPE = 'N'
drtytranoutc
TSF_OUT_COST
TSF_TYPE = 'N'
drtyicmkur
INTERCOMPANY_MARKUP
drtyicmkdr
INTERCOMPANY_MARKDOWN
drtywfslsu
FRANCHISE_SALES_UNITS
drtywfslsc
FRANCHISE_SALES_COST
drtywfslsr
FRANCHISE_SALES_RETAIL
drtywfrtnu
FRANCHISE_RETURNS_UNITS
drtywfrtnr
FRANCHISE_RETURNS_COST
drtywfrtnc
FRANCHISE_RETURNS_RETAIL
addvlocopnd
VW_LOC_DATA
STORE_OPEN_DATE
addvlocendd
VW_LOC_DATA
STORE_CLOSE_DATE
addvlocrefd
VW_LOC_DATA
REMODEL_DATE
drdvprdatt
(VW_PATV_DATA)
PROD_ATTR_VALUE
drdvppatvt
VW_PATV_DATA
PATV_VALUE
drtyudab
VW_UDS_DATA
True for PROD_ATTR
drtypclsst
VW_PROD_DATA
CLASS_DISPLAY_ID
drtypsclst
VW_PROD_DATA
SUBCLASS_DISPLAY_ID
drdvskuimgt
VW_PROD_DATA
PRODUCT_IMAGE_NAME
drdvskuimgl
VW_PROD_DATA
PRODUCT_IMAGE_ADDR
drdvslsprcr
VW_PROD_DATA
INITIAL_ITEM_RETAIL
drdvslsprcc
VW_PROD_DATA
INITIAL_ITEM_COST
addvlocatt W_PDS_ORG_ATTR_STR_D ATTR_VALUE
Note: For Location specific data, the same W_PDS_ORGANIZATION_D hierarchy table used for the location hierarchy is used. The view VW_LOC_DATA is defined in PDS to point to the same set of data and used as data importer interface. Similarly, VW_PROD_DATA is defined against W_PDS_PRODUCT_D to load any required data as measures such as Image details, RMF CS Unique Class, and Sub-Class Ids.
VW_PATR_DATA is defined against W_PDS_PRODUCT_ATTR_D for UDA_TYPE in ‘LV’ and also gets attribute values for the DIFF*, SUPPLIER, AND BRAND_NAME from the W_PDS_PRODUCT_D table at the item level. It also concatenates the product attribute values with product attribute names using ‘_’ and uses ‘supp’ and ‘brnd’ as product attribute names for Supplier and Brand.
The VW_PATV_DATA internal view defined against the Product Attribute Hierarchy table contains product attribute values without concatenation of product attribute names and it uses similar tables as in VW_PATR_HIER. The VW_UDA_DATA is defined against W_PDS_UDA_D to only contain distinct UDA to uniquely identify the UDAs defined in RMFCS.
Note: If the customer wants to use position filtering to filter a few products only in APCS in a multi-app environment, they can use the extensibility in GA, to set the Position Filter Measure property for product in Hierarchies to the measure DRDVAPFltSkuB and then can use any flex field for the product in W_PDS_PRODUCT_D to mark those items as ‘Y’ and interface that data to APCS_DRDVAPFltSkuB by changing the interface.cfg mapping for VW_PROD_DATA using extensibility guidelines.
Note: Pack Items are filtered by default for AP during the product hierarchy import from RAP using the Pack Item Filter Value measure set to N. This shared filter measure, PCKFLGVAL, can be managed in the Planning Admin workbook. In a multi-app scenario, if other applications need to bring in pack items, this can be changed to % to bring in both pack and non-pack items.
Forecasts can be generated from AI Foundation (AIF) and imported to APCS using RAP integration. AI Foundation can generate different levels of forecasts as needed by different levels of plans. It generates both Pre-Season forecasts (using the Auto-ES Forecast method) and In-Season Forecasts (using the Bayesian Forecast Method). AI Foundation directly gets the actuals through RAP integration. Job flows in AI Foundation need to be scheduled to generate the forecast and import the same to APCS. For more details, see the Oracle Retail Analytics and Planning Integration Implementation Guide.
In order to get forecasts from AI Foundation, during implementation, some initial setups need to be done in the AI Foundation platform. For more details, see the Oracle Retail Analytics and Planning Integration Implementation Guide.
The AI Foundation default Location Hierarchy does not contain the Planning Channel. Customers need to use the Alternate Hierarchy setup which uses the Planning Channel as an alternate hierarchy and create forecasts at the Planning Channel level as needed by MFP GA. For more details about creating forecasts at the Planning Channel level, see the AI Foundation documentation set.
The following table shows the interface table column details from AI Foundation in RDX used for the interface.
Interface Name: RSE_FCST_DEMAND_EXP
Table Column Data Type Comments
RUN_ID
Number(10)
The export Run ID as obtained from the RAP_INTF_UTIL.
CAL_HIER_LEVEL
Varchar2(30)
The calendar level data is for Fiscal Year, Fiscal Quarter, Fiscal Period, Fiscal Week, and Fiscal Day.
LOC_HIER_LEVEL
Varchar2(30)
The location hierarchy level data is for COMPANY, CHAIN, AREA, REGION, DISTRICT, LOCATION, and CHANNEL.
PROD_HIER_LEVEL
Varchar2(30)
The product hierarchy level the data is for CMP, DIV, GRP, DEPT, CLS, SBC, STYLE, STYLE_COLOR, and ITEM.
FCST_DATE_FROM
Date
The start date which the forecast is for.
LOC_EXT_KEY
Varchar2(80)
The external id of the location. It will use the integration ids as provided to RI (preferably the RMS id, and not an integration id such as AREA~123).
PROD_EXT_KEY
Varchar2(80)
The external id of the product hierarchy. It will use the integration ids as provided to RI (preferably the RMS id, and not an integration id such as CLS~123~456~789).
CUSTSEG_EXT_KEY
Varchar2(80)
The external id of the customer segment. It will be NULL if not applicable.
FCST_TYPE
Varchar2(20)
The type of forecast. PI, NPI (PI=Plan Influenced, PI = Non Plan Influenced)
REG_SLS_QTY
Number(38,20)
Regular Sales Units
REG_SLS_AMT
Number(38,20)
Regular Sales Amount
PR_SLS_QTY
Number(38,20)
Promo Sales Units
PR_SLS_AMT
Number(38,20)
Promo Sales Amount
CLR_SLS_QTY
Number(38,20)
Clearance Sales Units
CLR_SLS_AMT
Number(38,20)
Clearance Sales Amount
REG_PR_SLS_QTY
Number(38,20)
Regular and Promo Sales Units
REG_PR_SLS_AMT
Number(38,20)
Regular and Promo Sales Amount
SLS_QTY
Number(38,20)
Total Sales Units
SLS_AMT
Number(38,20)
Total Sales Amount
RET_QTY
Number(38,20)
Return Units
RET_AMT
Number(38,20)
Return Amount
The same Interface table contains the forecast data for different levels of plans differentiated by _LEVEL columns within the interface. The single interface run pulls data for different levels of forecasts which are pre-configured. Customers using non-template versions, if using different levels of plans, can use the supported levels in AI Foundation to generate forecasts. The following sections provide the default levels of forecasts exported for the APCS template version and their mappings.
Item Level Forecasts Mapping
The following table shows the mapping for pre-season and in-season Item Level Forecasts.
Table Column Mapping for Pre-Season (MPP) Mapping for In-Season (MPI)
CAL_HIER_LEVEL
Fiscal Week
Fiscal Week
LOC_HIER_LEVEL
LOCATION
LOCATION
PROD_HIER_LEVEL
ITEM
ITEM
FCST_DATE_FROM
WEEK
WEEK
LOC_EXT_KEY
STOR
STOR
PROD_EXT_KEY
SKU
SKU
CUSTSEG_EXT_KEY
NULL
NULL
FCST_TYPE
NPI
PI
REG_PR_SLS_QTY
FCTYFCPMU
FCTYFCIMU
REG_PR_SLS_AMT
FCTYFCPMR
FCTYFCIMR
Sub-Class Level Forecasts Mapping
The following table shows the mapping for pre-season Sub-Class Level Forecasts.
Table Column Mapping for Pre-Season (MTP)
CAL_HIER_LEVEL
Fiscal Week
LOC_HIER_LEVEL
LOCATION
PROD_HIER_LEVEL
SBC
FCST_DATE_FROM
WEEK
LOC_EXT_KEY
STOR
PROD_EXT_KEY
SCLS
CUSTSEG_EXT_KEY
NULL
FCST_TYPE
NPI
REG_PR_SLS_QTY
FCDVSlS1U
REG_PR_SLS_AMT
FCDVSLS1R
APCS uses Demand Transference (DT) from AI Foundation to suggest and optimize the assortments. DT is based on Item attributes, Attribute Weights, Functional Fit for Attributes, Assortment Elasticity, and Rate of Sale of Items. Item Attributes and Rate of Sale of item are available from RI interfaces. Other DT parameters such as Attribute Weights, Functional Fit for Attributes, and Assortment Elasticity are interfaced from AI Foundation through RAP integration. The APCS template version gets the DT parameters from RAP at the Sub-Class/Channel level, so it needs to be defined in AI Foundation at that level.
In order to get DT parameters from AI Foundation, during implementation, some initial setups need to be done in the AI Foundation platform. AI Foundation needs a customer segment to be defined for DT interfaces. AI Foundation can use multiple customer segments, so those customer segments need to be loaded as the CSGH hierarchy, in order for AP to interface DT parameters. AP is not directly using customer segments in planning workbooks, but the user can choose the Customer Segment to use for a Sub-Class in the Planning Admin workbook. Only those selected Customer Segments DT Parameters for the Sub-Class will be used in the AP workbooks. For more details, see the Oracle Retail Analytics and Planning Integration Implementation Guide.
The following table shows the interface table column details from AI Foundation in RDX used for the interface and the corresponding mapping of columns in APCS. Only mapped columns are used by the APCS template version. If RAP integration is enabled and if Enable RSE DT Integration is set to true, then this interface will run as part of the weekly batch.
Interface Name: RSE_ASSORT_ELASTICITY_EXP
Table Column Data Type Comments Dimension / Measure / Value Mapping
RUN_ID
Number(10)
LOC_HIER_LEVEL
Varchar2(30)
The location hierarchy level data is for COMPANY, CHAIN, AREA, REGION, DISTRICT, LOCATION, and CHANNEL_COUNTRY.
CHANNEL_COUNTRY
PROD_HIER_LEVEL
Varchar2(30)
SBC
LOC_EXT_KEY
Varchar2(80)
The external id of the location. It will use the integration ids as provided to RI.
CHNC
PROD_EXT_KEY
Varchar2(80)
SCLS
CUSTSEG_EXT_KEY
Varchar2(80)
CSGD
ASSORT_ELASTICITY
Number(38,20)
The assortment elasticity which DT has calculated.
DRTYASSRTELASV
EFFECTIVE_DT_FROM
Date
The date when this data was activated.
Interface Name: RSE_ASSORT_ATTR_WGT_EXP
RUN_ID
Number(10)
LOC_HIER_LEVEL
Varchar2(30)
CHANNEL_COUNTRY
PROD_HIER_LEVEL
Varchar2(30)
The product hierarchy level the data is for CMP, DIV, GRP, DEPT, CLS, SBC, STYLE, STYLE_COLOR, and SKU.
SBC
LOC_EXT_KEY
Varchar2(80)
CHNL
PROD_EXT_KEY
Varchar2(80)
SCLS
CUSTSEG_EXT_KEY
Varchar2(80)
CSGD
PROD_ATTR_GRP_EXT_KEY
Varchar2(80)
The external ID for the product attribute.
PATT
ATTR_WGT
Number(38,20)
The attribute weight.
DRTYATTRWGTV
FUNC_ATTR_FLG
Varchar2(1)
Y/N Flag indicating this is a functional attribute. A functional attribute is one which fits a specific purpose and cannot be substituted by other products with other values for this attribute.
DRTYFUNCFITB
Location Clusters can be defined in AI Foundation and can be interfaced to APCS. The APCS template version also supports defining Location Clusters within the application. AI Foundation allows defining clusters at different levels across the product hierarchy but the APCS template version allows interfacing clusters defined at the department level. Location Clusters are defined for a date range and those date ranges can be defined as Assortment Periods in APCS and the same can be exported to AI Foundation to define the Location Clusters. For more details, see Export Assortment Periods for Location Clustering to AI Foundation.
In order to get location clusters from AI Foundation, during implementation, some initial setups need to be done in the AI Foundation platform. For more details, see the Oracle Retail Analytics and Planning Integration Implementation Guide.
The following table shows the interface table column details from AI Foundation in RDX used for the interface and the corresponding mapping of columns in APCS. Only mapped columns are used by the APCS template version. If RAP integration is enabled and if Enable RSE Cluster Integration is set to true, then this interface will run as part of the weekly batch.
Interface Name: RSE_LOC_CLUSTER_EXP
RUN_ID
Number(10)
LOC_HIER_LEVEL
Varchar2(30)
The location hierarchy level data is for COMPANY, CHAIN, AREA, REGION, DISTRICT, and LOCATION.
LOCATION
PROD_HIER_LEVEL
Varchar2(30)
DEPT
LOC_EXT_KEY
Varchar2(80)
STOR
PROD_EXT_KEY
Varchar2(80)
DEPT
EFF_START_DT
Date
The starting date which the cluster is effective.
WEEK, DRDVSRTD
EFF_END_DT
Date
The ending date for which the cluster is effective.
DRDVENDD
CLUSTER_ID
Number(10)
The identifier for the cluster.
DRDVSTRCLUST
CLUSTER_LABEL
Varchar2(50)
A descriptive name/label for the cluster.
DRDVSTRCLUSL
Size Profiles can be defined in AI Foundation and can be interfaced to APCS. The APCS template version uses Size Profiles defined from AIF or can use the size profiles set at the Admin level within the application. The APCS template version imports size profiles from AIF at the sub-class level. It is used to define Buy Quantity by Size and Receipts by Sizes while planning them.
In order to get Size Profiles from AI Foundation, during implementation, some initial setups need to be done in the AI Foundation platform. For more details, see the Oracle Retail Analytics and Planning Integration Implementation Guide.
The following table shows the interface table column details from AI Foundation in RDX used for the interface and the corresponding mapping of columns in APCS. Only mapped columns are used by the APCS template version. For complete details of all available columns, see the Oracle Retail Analytics and Planning Integration Implementation Guide. If RAP integration is enabled and Enable RSE Size Profile Integration is set to true, then this interface will run as part of the weekly batch. If integration is enabled, it will use the same interface table data to also load the Size Hierarchy file (SIZH) using the internal view VW_SIZH_HIER and then also load the Size Profile.
Interface Name: RSE_SIZE_PROFILE_EXP
RUN_ID
Number(10)
LOC_LEVEL_NAME
Varchar2(255)
LOCATION
PROD_LEVEL_NAME
Varchar2(255)
The product hierarchy level the data is for CMP, DIV, GRP, DEPT, CLS, SBC, STYLE, and STYLE_COLOR.
SBC
LOC_EXT_KEY
Varchar2(80)
STOR
PROD_EXT_KEY
Varchar2(80)
SCLS
SIZE_EXT_ID
Number(10)
Size External Identifier
SIZD
SIZE_PCT_UNITS
Number(10,5)
Size Profile Percentage
DRDVSIZE
USED_BY_AIP
Varchar2(1)
Flag to indicate that record is for AIP Y
PRFP
SIZE_LABEL
Varchar2(255)
Size Label
SIZD_LABEL
SIZE_GROUP_ID
Varchar2(255)
Size Group Identifier
SRNG
SIZE_GROUP_LABEL
Varchar2(255)
Size Group Label
SRNG_LABEL
For Size Hierarchy (sizh), the internal view (VW_SIZE_HIER) is defined against the AIF RSE_SIZE_PROFILE_EXP table to get the unique sizes (SIZE_EXT_ID, SIZE_LABEL) and size ranges (SIZE_GROUP_ID and SIZE_GROUP_LABEL) which are marked to be used AP (USED_BY_AIP flag as ‘Y’).
SIZE_EXT_LABEL, also available as part of this view, can be used instead of SIZE_LABEL to get extended labels for sizes from AIF.
In the APCS template version, the customer can define the Assortment periods at pre-defined product levels (DEPT). Assortment Periods are date ranges to plan the assortments; it can vary for different product levels. The customer can export the defined Assortment Periods by enabling the Boolean measure Export Period for Clustering at the Assortment Period level.
In order to import and use this data from AI Foundation, during implementation, some initial setups need to be done in the AI Foundation platform. For more details, see the Oracle Retail Analytics and Planning Integration Implementation Guide.
The following table shows the interface tables and column details from APCS in RDX used for the interface and the corresponding mapping of columns in APCS. Only mapped columns are used by the APCS template version. If RAP integration is enabled and if Enable RSE Cluster Integration is set to true, then this interface will run as part of the weekly batch.
Interface Name: AP_ASSORT_PERIOD_EXP
RUN_ID
Number(10)
PROD_LEVEL
Varchar2(80)
DEPT
PROD_KEY
Varchar2(80)
Product Identifier
DEPT
LOC_LEVEL
Varchar2(80)
COMPANY
LOC_KEY
Varchar2(80)
Location Identifier
COMP
ASSORT_PERIOD_KEY
Varchar2(80)
Assortment Period Key
BPER
ASSORT_PERIOD_START_DATE
Date
Assortment Period Start Date
BCDVSRTD
ASSORT_PERIOD_END_DATE
Date
Assortment Period End Date
BCDVENDD
EXT_NAME
Varchar2(80)
External Cluster Name
BCDVCLUSTERT
CLUSTER_DESCR
Varchar2(255)
Cluster Description
BCDVPRDL
In the APCS template version, the customer can plan active assortments for an assortment period and those details can be exported to AI Foundation at the Item/Store level.
The following table shows the interface tables and column details from APCS in RDX used for the interface and the corresponding mapping of columns in APCS. Only mapped columns are used by the APCS template version. If RAP integration is enabled, then this interface will run as part of the weekly batch.
Interface Name: AP_ACTIVE_ASSORT_EXP
RUN_ID
Number(10)
PROD_KEY
Varchar2(80)
Product Identifier
SKU
LOC_KEY
Varchar2(80)
Location Identifier
STOR
PROD_LEVEL
Varchar2(80)
ITEM
LOC_LEVEL
Varchar2(80)
LOCATION
ACTIVE_START_DATE
Date
Active Assortment Start Date
BPDBSRTD
ACTIVE_END_DATE
Date
Active Assortment End Date
BPDBENDD
Approved plans from APCS can be exported to Retail Insights within RAP integration. The APCS template version allows creating and exporting plans at the week/store/item level for both OP and CP versions. Plans defined at the week/store/style-color level are evenly spread to the week/store/item level before this exports in the batch process. Plans for different versions can be exported to Retail Insights on a weekly basis. It exports all the approved plans for the un-elapsed periods. With the AP non-template version, customers can create a different level of plans and they can also configure various metrics. The interface staging table in Retail Sights contains more metrics columns and various flex columns. The customer can update and configure the interface.cfg mappings to export additional columns that can be used by Retail Insights.
For more details about the list of columns available in the Retail Insights Interface Staging table if the customer plans to use extensibility or use the non-template version to send additional data, see the Oracle Retail Insights Implementation Guide. This guide contains only the mapped columns for the APCS template version.
This plan export is for exporting both the OP and CP versions of approved Assortment Plans. VERSION_NUM 0 is used to export the OP version and 1 is used to export the CP version. The following table only shows the mapping for OP versions. The CP versions of mapping remain the same; the Version Number used is 1.
Interface Name: AP_PLAN1_EXP
Staging Table Column Description Dimension/Measure Mapping
PROD_KEY
Product Dimension
sku
LOC_KEY
Location Dimension
stor
CLND_KEY
Calendar Dimension
week
PROD_DH_ATTR
Attribute Dimension for RI
-1
SUPPLIER_NUM
Supplier Dimension for RI
-1
CAL_DATE
Last Day of Week
IEOPPWKED
VERSION_NUM
Version Number
0
PROD_LEVEL
Product Level
ITEM
LOC_LEVEL
Location Level
LOCATION
SLS_QTY
Op Sales Reg+Promo U
IEOPSLS1U
SLS_RTL_AMT
Op Sales Reg+Promo R
IEOPSLS1R
SLS_COST_AMT
Op Sales Reg+Promo C
IEOPSLS1C
EOH_COST_AMT
Op EOP C
IEOPEOPC
EOH_RTL_AMT
Op EOP R
IEOPEOPR
EOH_QTY
Op EOP U
IEOPEOPU
INVRC_COST_AMT
Op Receipts C
IEOPRCPTC
INVRC_RTL_AMT
Op Receipts R
IEOPRCPTR
INVRC_QTY
Op Receipts U
IEOPRCPTU
OTB_COST_AMT Wp OTB C IEWPOTBC
OTB_RTL_AMT Wp OTB R IEWPOTBR
OTB_QTY Wp OTB U IEWPOTBU
BUY_QTY Cp Buy Qty IECPBuyQtyU
Implementation Steps with RAP Integration
If RAP integration is enabled in the environment (that is, if the customer is going to get data from RMFCS using RDX integration), follow these steps for implementation. The steps assume that RPAS, RASL, UI, and RDX are already deployed:
  1. Run the Batch Process in RAP in Retail Insights (RI) to load the required initial data into the RDX staging tables.
  2. Upload any application-specific hierarchy files and data files that are not coming from RDX into Object Storage.
  3. Once the AP Cloud Service environment is provisioned, use the bootstrap Build Application task to build the application and use the batch task as set_rdx to just set the Enable RDX Boolean before the initial batch, or run post_hier to enable the RDX Boolean and load/import only the hierarchy files, or run postbuild_rdx to enable the RDX and to load/import initial hierarchy and data files and also run the initial batch. Batch step post_hier can also be run from OAT, to enable the RDX and load the available hierarchy files after building the domain. Use postbuild only if planning to load and use only the GA data set.
  4. Schedule the regular weekly flow in the RI, AIF, and Planning applications in JOS/POM to interface the initial data into the application to get data from both RDX and Object Storage.
    At least post_hier or postbuild_rdx should be run once with at least the calendar hierarchy file before trying to run the weekly batch using JOS/POM.
