Administration Process
The intent of this document is to guide an Assortment Planning Cloud Service (APCS) Administrator to perform the recurring administrative activities for the APCS application. This document outlines all administration activities required to support a live APCS application. In some cases, the detail will be explained in this document, and in other cases, the process will be covered here and details will be explained in the Oracle Retail Predictive Application Server Cloud Edition Administration Guide.
The APCS Administrative activities can broadly be classified into two categories. This document follows these categories and provide details for the tasks within them.
Regular Activities:
APCS Batch Task Administration
Build/Patch Application
Ad-hoc Activities:
User and Role Maintenance
Monitor Domain Performance
Regular Activities
Once an APCS solution is live, the Administrator is responsible for two key activities that occur on a regular basis. The first of these activities is managing the weekly/daily batch which loads and exports data required for the APCS users to create, manage, and share their assortment plans. Internally, it also does the calculations for necessary data aggregation.
The APCS Admin task offers a broad range of options to the Administrator to configure the batch run and maintenance. This document also provides a concise view to the Administrator on troubleshooting when the batch fails or diagnosing rejected records, importing/exporting of data files, reading logs, and modifying the scheduled batch to work around system maintenance or patch periods.
Patch uptake is another recurring task that an Administrator needs to be familiar with. This document walks through the process of taking a monthly patch and the specifics the Administrator needs to take care of.
Ad-hoc Activities
The Administrator generally comes across certain jobs on an as-needed basis. For example, the need occasionally arises to do the following:
Add a new user who just joined the team/organization and needs to use the APCS application.
Remove an existing user who has left the organization and needs to be removed from the APCS environment.
Manage a user's access when the role changes within the organization.
This document describes the necessary actions to achieve this kind of request.
The Administrator can leverage the standard Online Administration Tools (OAT) tasks on an ad-hoc basis without scheduling the task daily or weekly. Ad-hoc administrative activities include properly managing the reclassification of product so that planners can continue their work without interruption, monitoring domain related information to maintain system performance, loading a hierarchy from OAT, and so on, are several jobs the Administrator needs to perform intermittently.
For more details about the standard Administrative Tasks applicable to all Planning Solutions, see the Oracle Retail Predictive Application Server Cloud Edition Administration Guide.
