AIF Integration using a Web Service
Customers can use AIF to calculate the Optimized History, Option Counts and Sales Potential that are used by AP during the Assortment Fit Process. The Optimized History/Option Count and Sale Potential can be interfaced to AP.
Before using the web service calls in AP, AP needs to export the Assortment Group that is the combination of unique Assortment Periods and Location Clusters. It runs as part of the daily batch and AIF also needs additional setups during implementation to run those Option Forecasts in the nightly batch. For more details, see the Oracle Retail Analytics and Planning Integration Implementation Guide.
Generated Option Forecasts/Optimized Sales/Sales Potential from AIF can be interfaced using the custom menu planning actions, directly into relevant workspaces that are pre-configured to get the data through internal web service calls using the standard RPAS web service framework.
The RPAS web service framework uses the configured serviceConfig.json file, which can be used to map the RPAS dimensions/measures that are used in workbook templates against the keys present in web service requests and responses for web services created within RAP; the same web service can be triggered using the custom menu from those templates. For more details about the mapping of serviceConfig.json, see the Service Config Definitions section in the Deployment Tool chapter in the Oracle Retail Predictive Application Server Cloud Edition Configuration Tools User Guide.
On successful connection using a web service call, an Admin task with the name <service_name> from workbook <workbook_name> will be available in OAT. It shows the calls triggered from the template with the details of contents in the web service request and response in JSON format. Sample request and response triggered from the custom menu are provided in the examples below. The same OAT log can be used to debug any issues during the transfer of data using web service calls if the response has any errors due to any issues.
Following are the details of the two configured web services with AIF for the AP GA configuration.
WebService for Optimized History/Option Count
AIF Service Name: /app/rgbuaifpyapwebservice/optioncountinference
AP Service Name: AIFService1
Service Version: dis
The following tables shows the key fields present in the web service request and response, and the corresponding mapped measures in AP GA.
Web Service Request Input Key Mappings
Key/Parameter | Data Type | GA Intersection | Description | Mapped Measure |
asrtReqId | VARCHAR2(250) | Dept/Assort Period | Assortment Request Id | aft1asrtidt |
asrtLabel | VARCHAR2(250) | Dept/Assort Period | Assortment Label | aft1asrtidl |
asrtProdId | VARCHAR2(80) | Dept/Assort Period |
Assortment Parent Product Dimension. Department Position Id will be used in AP. |
aft1prodkeyt |
asrtPeriod | VARCHAR2(80) | Dept/Assort Period | Assort Period Dimension Id used in AP | aft1asrtlblt |
asrtGroupId | VARCHAR2(80) | Dept/Assort Period | Assortment Group Id | aft1prdt |
attrTypeIdList | VARCHAR2(80) | Dept/Assort Period | List of Eligible Product Attribute Type Id's | aft1prdattt |
prodList | Dept/Assort Period | Collection for List of Product/Store Cluster | aft1clusidb | |
prodId | VARCHAR2(80) | Subclass/Assort Period/Store Cluster | Product Id | bwdbprodkeyt |
storClusId | VARCHAR2(80) | Subclass/Assort Period/Store Cluster | Store Cluster Id | bwdbclusidt |
keyStorId | VARCHAR2(80) | Subclass/Assort Period/Store Cluster | One Sample Key Store Id with in Store Cluster against which to receive the data. | afdbclusidt |
tgtSls | NUMBER(20,4) | Subclass/Assort Period/Store Cluster | Target Sales Units | afdbtgtslsu |
fcstSls | NUMBER(20,4) | Subclass/Assort Period/Store Cluster | Forecasted Sales Units | afdbfcstslsu |
histSls | NUMBER(20,4) | Subclass/Assort Period/Store Cluster | Historical Sales Units | afdbhistslsu |
attrSlsThr | NUMBER(20,4) | Subclass/Assort Period/Store Cluster | Optional Historic Sales Threshold % for Attributes Values to Recommend. | afdbattrslsthrp |
Web Service Response Output Key Mappings
asrtStgyRecOptHeader | Dept/Assort Period | Collection for the Main Request Response Header | ||
responseCode | VARCHAR2(80) | Dept/Assort Period |
Ex: 200 - For Successful Processing of Data |
aft1respcodet |
responseCodeMessage | VARCHAR2(255) | Dept/Assort Period | Detailed Response Message for Request | aft1respcodel |
asrtStgyRecOptDetail | Dept/Assort Period | Collection for the Main Request Response Details | ||
asrtReqId | VARCHAR2(80) | Dept/Assort Period | Same asrtReqId provided in the input request | aft2asrtidt |
asrtProdId | VARCHAR2(80) | Dept/Assort Period | Same asrtProdId provided in the input request | dept |
asrtPeriod | VARCHAR2(80) | Dept/Assort Period | Same asrtPeriod provided in the input request | bper |
asrtGroupId | VARCHAR2(80) | Dept/Assort Period | Assortment Group Unique Id to link Prod/Assort Period/Store Clusters | aft2prdt |
prodCnt | NUMBER(10,0) | Dept/Assort Period | Number of SubClass/Store Clusters in the request for the Dept. | afdvprdct |
prodList | Subclass/Assort Period/Store Cluster | Collection for List of Products/Store Cluster | ||
prodId | VARCHAR2(80) | Subclass/Assort Period/Store Cluster | Same product Id provided in the input request | scls |
storClusId | VARCHAR2(80) | Subclass/Assort Period/Store Cluster | Same Store Cluster Id provided in the input request | bwdbclusidt |
storId | VARCHAR2(80) | Subclass/Assort Period/Store Cluster | One Store Id with in the Store Cluster | stor |
optTtlSls | NUMBER(20,4) | Subclass/Assort Period/Store Cluster | Optimized Total Sales | aft1optslsu |
optTtlCnt | NUMBER(20,4) | Subclass/Assort Period/Store Cluster | Optimized Sales Option Count | aft1recoptnct |
tgtTtlCnt | NUMBER(20,4) | Subclass/Assort Period/Store Cluster | Target Sales Option Count | aft1tgtttlct |
histTtlCnt | NUMBER(20,4) | Subclass/Assort Period/Store Cluster | Actual Sales Option Count | aft1histttlct |
fcstTtlCnt | NUMBER(20,4) | Subclass/Assort Period/Store Cluster | Forecast Sales Option Count | aft1fcstttlct |
statusCode | VARCHAR2(255) | Subclass/Assort Period/Store Cluster | Status Code to capture any errors at detail level. | aft1statcodet |
statusMessage | VARCHAR2(255) | Subclass/Assort Period/Store Cluster | Status Message to capture any errors at detail level. | aft1statcodel |
attrTypeList | Subclass/Assort Period/Store Cluster | |||
attrTypeId | VARCHAR2(80) | Subclass/Assort Period/Store Cluster/Attribute Type | Collection for Attribute Types | patt |
attrTypeWgt | NUMBER(20,4) | Subclass/Assort Period/Store Cluster/Attribute Type | Attribute Type Weight calculated in Science for Recommending this Attribute | aft1attrtypev |
attrList | Subclass/Assort Period/Store Cluster/Attribute Type | Collection for Attribute Value List | ||
attrValue | VARCHAR2(80) | Subclass/Assort Period/Store Cluster/Attribute Value | Attribute Value Name | aft1attridl |
attrId | VARCHAR2(80) | Subclass/Assort Period/Store Cluster/Attribute Value | Attribute Name and "_" and Attribute Value Name. Unique Id used in Planning for Attribute Values. | patv |
optAttrSls | NUMBER(20,4) | Subclass/Assort Period/Store Cluster/Attribute Value | Optimized Attribute Value Sales Units | aft1optattrslsu |
optAttrMix | NUMBER(20,4) | Subclass/Assort Period/Store Cluster/Attribute Value | Recommended Attribute Value Mix Percentage | aft1optattrmixv |
Sample Web Service Request Call
{ "asrtStgyRecOptHeader": { "requestID": "103_ap03_20230507192443", "rspVersion": "v1", "timeout": 4.0 }, "asrtReqId": "103_ap03_20230507192443", "asrtLabel": "SPRING SUMMER 2023", "asrtProdId": "103", "asrtPeriod": "ap03", "asrtGroupId": "103_ap03_20230507", "attrTypeIdList": [ "brnd", "color", "fabric" ], "prodList": [ { "prodId": "1030101", "storClusId": "us_1_52058", "keyStorId": "1175", "tgtSls": 0, "fcstSls": 33592, "histSls": 76028, "attrSlsThr": 0.0 }, { "prodId": "1030202", "storClusId": "us_1_52058", "keyStorId": "1175", "tgtSls": 0, "fcstSls": 14977, "histSls": 29254, "attrSlsThr": 0.0 } ] }
Sample Web Service Response Call
{ "AsrtStgyRecOptDetail": { "asrtGroupId": "103_ap03_20230507", "asrtPeriod": "ap03", "asrtProdId": "103", "asrtReqId": "103_ap03_20230507192443", "prodCnt": 2, "prodList": [ { "attrTypeList": [ { "attrList": [ { "attrId": "color_pink", "attrValue": "pink", "optAttrMix": 0.1364, "optAttrSls": 212637.0 }, { "attrId": "color_purple", "attrValue": "purple", "optAttrMix": 0.0909, "optAttrSls": 7542.0 }, { "attrId": "color_off_white", "attrValue": "off_white", "optAttrMix": 0.0227, "optAttrSls": 30006.0 } ], "attrTypeId": "color", "attrTypeWgt": 0.0168 }, { "attrList": [ { "attrId": "fabric_wool", "attrValue": "wool", "optAttrMix": 0.1364, "optAttrSls": 74618.0 }, { "attrId": "fabric_polyester", "attrValue": "polyester", "optAttrMix": 0.0682, "optAttrSls": 113571.0 }, { "attrId": "fabric_organiccotton", "attrValue": "organiccotton", "optAttrMix": 0.2045, "optAttrSls": 334509.0 } ], "attrTypeId": "fabric", "attrTypeWgt": 0.126 } ], "fcstTtlCnt": 0.6572, "histTtlCnt": 1.4874, "keyStorId": "1175", "optTtlCnt": 21.9848, "optTtlSls": 1123705, "prodId": "1030101", "statusCode": "", "statusMessage": "", "storClusId": "us_1_52058", "tgtTtlCnt": 0.0 }, { "attrTypeList": [ { "attrList": [ { "attrId": "color_white", "attrValue": "white", "optAttrMix": 0.075, "optAttrSls": 4875.0 }, { "attrId": "color_blue", "attrValue": "blue", "optAttrMix": 0.075, "optAttrSls": 39521.0 }, { "attrId": "color_maroon", "attrValue": "maroon", "optAttrMix": 0.025, "optAttrSls": 15163.0 } ], "attrTypeId": "color", "attrTypeWgt": 0.0338 }, { "attrList": [ { "attrId": "fabric_woolsilk", "attrValue": "woolsilk", "optAttrMix": 0.025, "optAttrSls": 15163.0 }, { "attrId": "fabric_polyester", "attrValue": "polyester", "optAttrMix": 0.025, "optAttrSls": 16810.0 }, { "attrId": "fabric_merinowool", "attrValue": "merinowool", "optAttrMix": 0.125, "optAttrSls": 46314.0 } ], "attrTypeId": "fabric", "attrTypeWgt": 0.0196 } ], "fcstTtlCnt": 1.4811, "histTtlCnt": 2.8931, "keyStorId": "1175", "optTtlCnt": 39.6602, "optTtlSls": 401023, "prodId": "1030202", "statusCode": "", "statusMessage": "", "storClusId": "us_1_52058", "tgtTtlCnt": 0.0 } ] }, "asrtStgyRecOptHeader": { "responseCode": "200", "responseCodeMessage": "Assortment Strategy - Key Attributes data returned Successfully" }
Web Service for Sales Potential
AIF Service Name: /app/rgbuaifpyapwebservice/salespotential
AP Service Name: AIFService2
asrtReqId | VARCHAR2(80) | Dept/Assort Period | Assortment Request Id | aft1asrtidt |
aft1prodkeyt |
itemLevel | VARCHAR2(80) | Dept/Assort Period | Item Level used in Input - STYL (Style), COLOR (Style-Color) or ITEM (SKU). AP GA will use COLOR for Style-Color | aft1asrtitemt |
storClusCnt | NUMBER(10,0) | Dept/Assort Period | Count of Store-Clusters with in product for this request. | aft1clusidi |
storClusList | VARCHAR2(80) | Dept/Assort Period | Collection for Store Cluster | afdbclusidb |
storClusId | VARCHAR2(80) | Dept/Assort Period/Store Cluster | Store Cluster Id | bwt2clusidt |
keyStorId | VARCHAR2(80) | Dept/Assort Period/Store Cluster | One Sample Key Store Id with in Store Cluster against which to receive the data. | aft2clusidt |
itemCnt | NUMBER(10,0) | Dept/Assort Period | Count of Items (Style-Color) with in the product for this request. | afdbstatusct |
itemList | Dept/Assort Period | afdbstatusb | ||
itemId | VARCHAR2(80) | Style-Color/Assort Period | Item Identifier | bwdvitemidt |
prodId | VARCHAR2(80) | Style-Color/Assort Period | Product Id | afdvprodkeyt |
NewItem | VARCHAR2(80) | Style-Color/Assort Period | Y/N. Flag to tell if item if item is new item. For New Items it's Y else N. | afdvphitmt |
attrList | VARCHAR2(80) | Style-Color/Assort Period | Attribute List at Style-Color level | afdbprdattrb |
attrTypeId | VARCHAR2(80) | Style-Color/Assort Period/Attribute Value | Attribute Type Identifier | afdvprdattl |
attrValueId | VARCHAR2(80) | Style-Color/Assort Period/Attribute Value | Attribute Value Identifier | afdvprdattt |
Web Service Request Output Key Mappings
asrtFitSlsPHeader | Dept/Assort Period | Collection for the Main Request Response Header | ||
aft2respcodet |
responseCodeMessage | VARCHAR2(255) | Dept/Assort Period | Detailed Response Message for Request | aft2respcodel |
asrtFitSlsPDetail | Dept/Assort Period | Collection for the Main Request Response Details | ||
prodList | Dept/Assort Period | Collection for List of Products/Store Cluster | ||
keyStorId | VARCHAR2(80) | Subclass/Assort Period/Store Cluster | One Store Id from the Store Cluster | stor |
avgROS | NUMBER(20,4) | Subclass/Assort Period/Store Cluster | Average Rate of Sales | aft2rosv |
statusCode | VARCHAR2(80) | Subclass/Assort Period/Store Cluster | Status Code | aft3statcodet |
statusMessage | VARCHAR2(255) | Subclass/Assort Period/Store Cluster | Status Message | aft3statcodel |
itemList | Style-Color/Assort Period/Store Cluster | Collection for Item List | ||
itemId | VARCHAR2(80) | Subclass/Assort Period/Store Cluster/Attribute Value | Same Item/Style-Color Id passed in Input | skup |
itemASlsP | NUMBER(20,4) | StyleColor/Assort Period/Store Cluster | Average Sales Potential calculated at Item/Style-Color Level | aft2itemaslspu |
itemMSlsP | NUMBER(20,4) | StyleColor/Assort Period/Store Cluster | Maximum Sales Potential calculated at Item/Style-Color Level | aft2itemmslspu |
statusCode | VARCHAR2(80) | StyleColor/Assort Period/Store Cluster | Status Code | aft2statcodet |
statusMessage | VARCHAR2(255) | StyleColor/Assort Period/Store Cluster | Status Message | aft2statcodel |
{ "asrtStgyRecOptHeader": { "requestID": "103_ap03_20230507025519", "rspVersion": "v1", "timeout": 4.0 }, "asrtReqId": "103_ap03_20230507025519", "asrtProdId": "103", "asrtPeriod": "ap03", "asrtGroupId": "103_ap03_20230507", "itemLevel": "COLOR", "attrTypeIdList": [ "brnd", "color", "fabric" ], "storClusCnt": 2, "itemCnt": 2, "storClusList": [ { "storClusId": "us_1_52056", "keyStorId": "1117" }, { "storClusId": "us_1_52058", "keyStorId": "1175" } ], "itemList": [ { "itemId": "1101279", "prodId": "1030201", "NewItem": "N", "attrList": [ { "attrTypeId": "brnd", "attrValueId": "PrivateLabel" }, { "attrTypeId": "color", "attrValueId": "red" }, { "attrTypeId": "fabric", "attrValueId": "wool" } ] }, { "itemId": "1101282", "prodId": "1030201", "NewItem": "N", "attrList": [ { "attrTypeId": "brnd", "attrValueId": "PrivateLabel" }, { "attrTypeId": "color", "attrValueId": "green" }, { "attrTypeId": "fabric", "attrValueId": "cotton" } ] } ] }
"itemASlsP": 400, "itemMSlsP": 500, “statusCode”: Null, “statusMessage”: Null }, { "itemId": "1101282", "itemASlsP": 500, "itemMSlsP": 600, “statusCode”: Null, “statusMessage”: Null } ], "keyStorId": "1117", "prodId": "1030201", “statusCode”: Null, “statusMessage”: Null, "storClusId": "us_1_52056" }, { "avgROS": 14000, "itemList": [ { "itemId": "1101279", "itemASlsP": 500, "itemMSlsP": 600, “statusCode”: Null, “statusMessage”: Null }, { "itemId": "1101282", "itemASlsP": 600, "itemMSlsP": 700, “statusCode”: Null, “statusMessage”: Null } ], "keyStorId": "1175", "prodId": "1030201", “statusCode”: Null, “statusMessage”: Null, "storClusId": "us_1_52058" } ] }, "AsrtFitSlsPHeader": { "responseCode": 200, "responseCodeMessage": "Assortment Fit - Sales Potential data returned Successfully" } }
