Export Assortment Plans to Retail Insights
Approved plans from APCS can be exported to Retail Insights within RAP integration. The APCS template version allows creating and exporting plans at the week/store/style-color level for both different versions. Plans for different versions can be exported to Retail Insights on a weekly basis. It exports all the approved plans for the unelapsed periods. With the AP non-template version, customers can create a different level of plans and they can also configure various metrics. The interface staging table in Retail Sights contains more metrics columns and various flex columns. The customer can update and configure the interface.cfg mappings to export additional columns that can be used by Retail Insights.
For more details about the list of columns available in the Retail Insights Interface Staging table if the customer plans to use extensibility or use the non-template version to send additional data, see the Oracle Retail Insights Implementation Guide. This guide contains only the mapped columns for the APCS template version.
This plan is one table for one level and uses the VERSION_NUM to differentiate different versions for the same level of data, such as WP and CP versions, for exporting both the OP and CP versions of the approved Assortment Plan.
Only AP_PLAN2_EXP is used by the AP template version to export plans at the Style-Color/Store/Week level. The AP_PLAN1_EXP table and interface is still available for non-template version customers if they want to customize and do exports at the Item/Store/Week level.
Interface Name: AP_PLAN2_EXP
  • Plan Level: Style-Color/Store/Week
  • Plan Version: AF CP
  • Plan Version Number: 2
  • Export Filter: APCS_APCPEXPORTB
Table Column Table Column Data Type Nullable Comments AP Fact Mapping
RUN_ID Interface Run Identifier Number(10) N The export Run ID as obtained from the RAP_INTF_UTIL
PROD_KEY Product Dimension VARCHAR2(80) N Dimension STYL from PROD APCS_APHDPSKUGT
LOC_KEY Location Dimension VARCHAR2(80) N Dimension STOR from LOC
CLND_KEY Calendar Dimension VARCHAR2(80) N Dimension WEEK from CLND
PROD_DH_ATTR Attribute Dimension for RI VARCHAR2(80) N Color Attribute APCS_APHDPCOLORT
SUPPLIER_NUM Supplier Dimension for RI VARCHAR2(80) N Defaulted to -1
CAL_DATE Last Day of Week Date N Last Date of CLND_KEY as Date APCS_APHDPWKED
VERSION_NUM Version Number Number(10) N Defaulted to 2
PROD_LEVEL Product Level VARCHAR2(80)   Defaulted to COLOR
LOC_LEVEL Location Level VARCHAR2(80)   Defaulted to LOCATION
FLEX1_CHAR_VALUE Style-Color Id VARCHAR2(80)   Dimension SKUP from PROD
SLS_QTY AF Cp Sales U NUMBER(20,4)     APCS_APCPSLSU
SLS_RTL_AMT AF Cp Sales R NUMBER(20,4)     APCS_APCPSLSR
SLS_COST_AMT AF Cp Sales C NUMBER(20,4)     APCS_APCPSLSC
ASRT_INTENT AF Cp Item Intent VARCHAR2(80)     APCS_APCPINTENTT
ASRT_STATUS AF Cp Item Status VARCHAR2(80)     APCS_APCPSTATUST
ASRT_FLAG AF Cp Option Assorted VARCHAR2(80)     APCS_APCPASRTSKUPB
ASRT_COUNT AF Cp Option Assorted Count NUMBER(18,4)     APCS_APCPASRTSKUPCT
PLAN_START_DATE AF Cp Week Start DATE     APCS_APCPSRTD
PLAN_END_DATE AF Cp Week End DATE     APCS_APCPENDD
  • Plan Version: AF WP
  • Plan Version Number: 3
  • Export Filter: APCS_APWPEXPORTB
VERSION_NUM Version Number Number(10) N Defaulted to 3
SLS_QTY AF Wp Sales U NUMBER(20,4)     APCS_APWPSLSU
SLS_RTL_AMT AF Wp Sales R NUMBER(20,4)     APCS_APWPSLSR
SLS_COST_AMT AF Wp Sales C NUMBER(20,4)     APCS_APWPSLSC
ASRT_INTENT AF Wp Item Intent VARCHAR2(80)     APCS_APWPINTENTT
ASRT_STATUS AF Wp Item Status VARCHAR2(80)     APCS_APWPSTATUST
ASRT_FLAG AF Wp Option Assorted VARCHAR2(80)     APCS_APWPASRTSKUPB
ASRT_COUNT AF Wp Option Assorted Count NUMBER(18,4)     APCS_APWPASRTSKUPCT
PLAN_START_DATE AF Wp Week Start DATE     APCS_APWPSRTD
PLAN_END_DATE AF Wp Week End DATE     APCS_APWPENDD
  • Plan Version: IF CP
  • Plan Version Number: 4
  • Export Filter: APCS_ISCPEXPORTB
VERSION_NUM Version Number Number(10) N Defaulted to 4
SLS_QTY IF Cp Sales U NUMBER(20,4)     APCS_ISCPSLS1U
SLS_RTL_AMT IF Cp Sales R NUMBER(20,4)     APCS_ISCPSLS1R
SLS_COST_AMT IF Cp Sales C NUMBER(20,4)     APCS_ISCPSLS1C
EOH_COST_AMT IF Cp EOP C NUMBER(20,4)     APCS_ISCPEOPC
EOH_RTL_AMT IF Cp EOP R NUMBER(20,4)     APCS_ISCPEOPR
EOH_QTY IF Cp EOP U NUMBER(20,4)     APCS_ISCPEOPU
INVRC_COST_AMT IF Cp Rcpt C NUMBER(20,4)     APCS_ISCPRCPTC
INVRC_RTL_AMT IF Cp Rcpt R NUMBER(20,4)     APCS_ISCPRCPTR
INVRC_QTY IF Cp Rcpt U NUMBER(20,4)     APCS_ISCPRCPTU
BUY_QTY IF Cp Buy Qty U NUMBER(20,4)     APCS_ISCPBuyQtyU
BUY_RTL_AMT IF Cp Buy Qty R NUMBER(20,4)     APCS_ISCPBuyQtyR
BUY_COST_AMT IF Cp Buy Qty C NUMBER(20,4)     APCS_ISCPBuyQtyC
PLAN_START_DATE IF Cp Week Start DATE     APCS_ISCPSRTD
PLAN_END_DATE IF Cp Week End DATE     APCS_ISCPENDD
  • Plan Version: IF WP
  • Plan Version Number: 5
  • Export Filter: APCS_ISWPEXPORTB
SLS_QTY IF Wp Sales U NUMBER(20,4)     APCS_ISWPSLS1U
SLS_RTL_AMT IF Wp Sales R NUMBER(20,4)     APCS_ISWPSLS1R
SLS_COST_AMT IF Wp Sales C NUMBER(20,4)     APCS_ISWPSLS1C
EOH_COST_AMT IF Wp EOP C NUMBER(20,4)     APCS_ISWPEOPC
EOH_RTL_AMT IF Wp EOP R NUMBER(20,4)     APCS_ISWPEOPR
EOH_QTY IF Wp EOP U NUMBER(20,4)     APCS_ISWPEOPU
INVRC_COST_AMT IF Wp Rcpt C NUMBER(20,4)     APCS_ISWPRCPTC
INVRC_RTL_AMT IF Wp Rcpt R NUMBER(20,4)     APCS_ISWPRCPTR
INVRC_QTY IF Wp Rcpt U NUMBER(20,4)     APCS_ISWPRCPTU
BUY_QTY IF Wp Buy Qty U NUMBER(20,4)     APCS_ISWPBuyQtyU
BUY_RTL_AMT IF Wp Buy Qty R NUMBER(20,4)     APCS_ISWPBuyQtyR
BUY_COST_AMT IF Wp Buy Qty C NUMBER(20,4)     APCS_ISWPBuyQtyC
PLAN_START_DATE IF Wp Week Start DATE     APCS_ISWPSRTD
PLAN_END_DATE IF Wp Week End DATE     APCS_ISWPENDD
  • Plan Version: Rec Opt
  • Plan Version Number: 6
  • Export Filter: APCS_ARDBEXPORTB
VERSION_NUM Version Number Number(10) N Defaulted to 5
SLS_QTY Rec Sales Potential U NUMBER(20,4)     APCS_ARDBSLSPOTU
SLS_RTL_AMT Rec Sales Potential R NUMBER(20,4)     APCS_ARDBSLSPOTR
SLS_COST_AMT Rec Sales Potential C NUMBER(20,4)     APCS_ARDBSLSPOTC
ASRT_FLAG Rec Option Assorted VARCHAR2(80)     APCS_ARDBASRTSK
