Review Admin Parameters View
In this view, you can review the Admin Receipt Parameters set in the Planning Administration View, which serves as the foundational settings for receipt planning. These parameters, including Lead Time, Order Frequency, Safety Stock, Minimum Order Quantity, and others, are auto-populated based on the standard values defined in the Planning Admin Section.
After review, you can return to the Define Item Flow view and adjust required parameters to meet specific business needs or product characteristics. This may occur at the style-color level or higher product aggregations. For example, a subclass with longer supplier lead times or higher safety stock requirements can be modified to reflect these nuances. This granular control allows for precise tailoring of receipt parameters, ensuring they align with the unique demands of different product categories.
By reviewing and updating these parameters, you can optimize receipt flows, minimize stockouts, and improve inventory efficiency, ultimately enhancing the overall planning accuracy and execution.
