4 Extension
RDS Extension Overview
RDS Architecture Basics
The defining feature of RDS is the data of each participating product resides in a single dedicated read-only schema, e.g., MFCS. Product data is made accessible to the customer in a dedicated companion, writeable schema using synonyms. All custom data objects are created in this companion, writeable schema. Management and retention of custom data objects is wholly the responsibility of the customer.
The product data in RDS is a replica of selected data residing in an operations system such as MFCS. RDS is not part of MFCS, but a repository of MFCS data. Moreover, the data exchange is one way from MFCS to RDS. Any data movement, directly or indirectly, from RDS to MFCS is orchestrated by the customer.
Although data from multiple products reside in RDS, there is only an informal guarantee that if there are no updates to a given set of data items, then eventually all accesses will return temporally consistent results. What this statement means is that after sufficient time has passed, RDS accurately reflects the state of the enterprise at some point in time in the recent past (recent could be measured in seconds, minutes, or hours). What qualifies as sufficient time depends on the temporal consistency of the separate subsystems that make up the enterprise, which depends metaphorically speaking on when each system closes its book. Temporal consistency also depends on the replication lag, which varies depending on system loading. This lag, however, is expected to be minimal under normal operating conditions. Temporal consistency may prove decidedly less relevant than semantic and data model differences between the products that reflect the specific problems each product was devised to solve.
Refer to your product data model to determine what data is available in RDS. Bear in mind, the data is a replica of inserts and updates as well as deletes. The point is, the data retention policy in RDS is effectively replicated from the operations system.
Environment Considerations
When embarking on the customization of a product, it is important to understand how the RDS implementation environment, which is a SaaS offering, differs from PaaS and on-premises. First of all, some or all product customization will be accomplished by making modifications to RDS (the product implementation guide will provide details on product customization). Those modifications are achieved using APEX.
APEX is a low code development environment. As a result it does not anticipate the need for (and does not provide) development life cycle tools. Application user interfaces are composed in an application builder. RESTful services are built in a similar fashion. In fact, one constructs most database objects using a UI rather than by executing code. One can, however, use the SQL Workshop to compose small amounts of PL/SQL (e.g., 100s to 1000s of lines of code). There is no access to SQL*Developer or SQL*Loader. In fact, most consoles are unavailable. It is an ideal environment for most business savvy users, but may be foreign to the skilled PL/SQL, front end, or back end developer. It is important to note that customizations that require coding will use SQL and PL/SQL. Moreover, most data interchange will rely on JSON formatted messages. All the examples in this document will employ JSON.
When using APEX, SQL command line type activities are performed in the SQL Commands tool within the SQL Workshop. For SQL script development (for blocks of code where reuse is anticipated), however, one uses the SQL Scripts tool.
When using APEX, one logs into a workspace and that workspace provides access to a single schema. Specifically, one can have access to the data for a single product within a workspace. In other words, it is not possible to execute a mutli-schema or cross-schema query from within a workspace. If one needs to combine information from multiple products, then one constructs schema specific integrations and then joins that information externally.
Lastly, it is important to remember that since RDS is a SaaS offering, some tools and features may not be available or availability may be provided with some limitations. It is important that one understand the dependencies inherent in customizations that one wishes to migrate. Expect to review these dependencies with an Oracle Representative.
Prerequisites
In order to fully explore the examples below, one will need to meet the following prerequisites:
Have access to an APEX workspace within an RDS tenant,
IDCS application credentials
Have access to a suitable Object Storage instance
APEX is a browser-based application. You can access APEX by navigating to the Retail Home Application Navigator and tapping RDS APEX/ORDS. One’s RDS APEX workspace admin will be able to provide the necessary details. IDCS application credentials are needed to generate an access token that can be used to authenticate a RESTful service invocation. An object storage instance is needed as a data export destination.
Implementing a RESTful Service in APEX
Oracle RESTful Data Services play a role in both outbound data service and data export integration patterns. For the data service integration pattern, a RESTful service synchronously returns the requested data in whole or part (i.e., through data pagination). For the data export integration pattern, a RESTful service asynchronously initiates a data export and then returns with a suitable response. Much of the RESTful service implementation is the same regardless of data integration pattern. Ultimately, from the perspective of the RESTful service implementation, the two integration patterns differ only in terms of the actions taken in response to the REST service invocation.
Chapter 7 of the SQL Workshop Guide, Enabling Data Exchange with RESTful Services describes in great detail how one creates a RESTful service in APEX. Bear in mind, the above links are version specific. Although documentation across versions tends to be quite similar, it is generally best to consult the documentation for the version of APEX one is using. In any case, the following paragraphs will only provide an overview of how one creates the necessary RESTful service. Consult the documentation for additional details and example implementations.
The implementation of a RESTful service as two aspects, a URL pattern and a handler. When designing or composing a URL pattern, one is effectively constructing a dispatch mechanism that ties a given URL pattern to a specific action. This pattern-action pairing represents an API through which external systems access customer data residing in RDS.
URL Pattern
The URL pattern consists of three parts: a base path, a module name, and a URI template. The base path is the same for all RESTful services created within a given workspace, namely:
https://<host name>/<tenant_name>/ords/<schema name>where, the host name and tenant name are the same for all a given tenant’s RESTful services. The schema name is the workspace schema (remember, there is a one-to-one relationship between workspace and schema). The module name is just a hierarchical organizing feature. For example, one could have a module called po for RESTful services associated with purchase orders in MFCS. If this were the case, the path for all purchase orders services would begin with the following:
https://<host name>/<tenant_name>/ords/mfcs/po/The last part of the URL pattern is the URI template. The template consists of 0 or more path components followed by 0 or 1 bind variable. If there are 0 path components and no binding variable, then the URL template is blank or an empty string. If this were the case, then the complete URL is:
https://<host name>/<tenant_name>/ords/mfcs/po/In the more typical case, there are one or more path components with and without a bind variable. For example, one might have the following purchase order services:
| Service | Base Path + Module | URI Template | Description |
active |
…/mfcs/po/ |
active |
Return PO numbers for active (not completed or active) purchase orders. |
complete |
…/mfcs/po/ |
complete |
Return PO numbers for completed purchase orders. |
expired |
…/mfcs/po/ |
expired |
Return PO numbers for purchase orders that have expired with being fulfilled. |
summary |
…/mfcs/po/ |
summary/:po_num |
Return a summary for the purchase order with the given number. |
detail |
…/mfcs/po/ |
detail/:po_num |
Return the details for the purchase order with the given number. |
If one wanted purchase orders within a given date range, a query string specifying a date range can be added. For example, the following would return PO numbers between May 1st and May 15th, 2022.
https://<host name>/<tenant_name>/ords/mfcs/po/active?from=2022-05-01&to=2022-05-15The from and to become bind variables in a query.
Handler
The second aspect of a RESTful service is the handler. In any case, each URL pattern can be associated with up to four handlers, one for each of the following HTTP methods: GET, POST, PUT, and DELETE.
The source is parameterized using bind variables. Explicit bind variables are part of the URL, e.g.: po_num, from, and to. Consider the implementation of the handler that returns the details for a purchase order. The URL pattern might be:
https://<host name>/<tenant_name>/ords/mfcs/po/details/:po_numThe GET handler for this URI pattern could then be:
select … from purchase_orders where po_num=:po_num;
Ideally, purchase_orders is a view that is identified as part of the public API of the product data model in RDS. In general, accessing a view versus a table is preferable because the product makes stronger guarantees regarding the immutability of views (i.e., they are less likely to change in inconvenient ways).
Query string parameters can also be used to parameterize the RESTful service handler. The query string parameters are used like the :po_num above. For example, one can use the from-to range in the URL above to construct a query that returns only purchase orders within a data range, e.g.:
supplier_id=:supplier_id and
order_date >= DATE :from and
order_date < DATE :to;
It is important that RESTful services respect the semantics of the methods used. The GET method strongly suggests a synchronous operation with no side effects. Whereas the semantics of POST, PUT, and DELETE methods are expected to have side effects, but could be synchronous or asynchronous.
RESTful data services can be paged. Paging can be useful for interactive operations that only require a subset of data, but it can also be used to return a multi-part result set. In either case, page data returns a subset of data as well as URLs for the previous and next result set.
Lastly, only explicit bind variables have been described. The term explicit is used because there are also a number of implicit bind variables, see Implicit Parameters. These include parameters that provide access to bind variables that implement pagination. They also provide access to the data portion or payload of an endpoint invocation. There is also a current_user parameter. This parameter, however, is the schema owner, not the user accessing the RESTful service.
Security
Authentication
Authentication is achieved using OAUTH 2. What this means is that a RESTful service invocation is authenticated using an access token. That access token can be obtained, for example, using curl as shown in Listing 1. The response is a JSON object. This access token then becomes the Bearer token that authorizes the RESTful service invocation. The client id and secret can be obtained from the Retail Home Application Administration Guide. See Chapter 2 Application Navigator Setup, Creating OAUTH Client Apps.
LISTING 1: ACCESS TOKEN GENERATION
curl --location --request POST ‘https://<idcs host>/oauth2/v1/token' \
--header 'Content-Type: application/x-www-form-urlencoded' \
--header 'Authorization: Basic <base64 clientId:clientSecret>’ \
--data-urlencode 'grant_type=client_credentials' \
--data-urlencode 'scope=urn:opc:idm:__myscopes__'There is no implicit data or row level security. Any such security that is in effect in MFCS, for example, will not exist in RDS unless explicitly implemented by the customer. An effective approach to implementing data security will employ the ORDS Pre-hook functionality.
ORDS PRE-HOOK
Oracle REST Data Services (ORDS) provides the ability to use PL/SQL based pre-hook functions that are invoked prior to an ORDS based REST call. These functions can be used for a variety of purposes including auditing, custom authentication and authorization, and metrics gathering.
Each provided RDS workspace comes pre-configured with a simple
pre-hook function named ORDS_PREHOOK, and it has
a default implementation that simply returns true. As such, it has no effect on the REST calls made into custom applications.
It is provided as a starting point for extension to teams that required
additional processing on each REST call. For those teams, replacing
the implementation of the ORDS_PREHOOK function will
enable the additional capabilities they require. For more information
on pre-hook functions, please refer to Oracle REST Data Services Installation, Configuration,
and Development Guide: Overview of Pre-hook Functions.
Invoking a Data Service
A GET data service can be accessed and tested directly from a browser. If one is not already logged into the Oracle Cloud, then one will be redirected to a cloud login screen for authentication. Once authenticated, the data service endpoint will be invoked. The results of the invocation will be displayed in the browser window. If the data service is accessed from Retail Home, for example, the user is already authenticated.
Invoking a POST RESTful service or invoking a RESTful service from an external system is slightly more complicated. Listing 2 illustrates the invocation of a REST service endpoint using curl. Note the use of the access token. The response is dependent on the handler action.
LISTING 2: DATA SERVICE INVOCATION
curl --location --request POST ‘https://<host name>/<tenant id>/ords/mfcs/pom/job_start' \
--header 'content-type: application/json' \
--header 'Authorization: Bearer <access token>' \
--data-raw '{"param1": "value1", "param2": "value2"}'Using RDS to Build Integration
There are two approaches to transferring data between RDS and an external system, use a data service or use object storage to mediate the transfer. For an outbound integration, one uses a GET data service or exports data from ADW to object storage. For an inbound integration, one uses a POST (or DELETE if appropriate) data service or imports data from object storage to ADW. In the case where object storage is mediating the transfer, the external system is responsible for uploading or downloading data from object storage. When deciding which approach is best for a given situation, one should consider the latency tolerance, data volume, and tolerance for complexity.
Figure 4-1 Data Integration Option Matrix
Latency tolerance is essentially a measure of how long the consuming process or agent can or will wait for the requested data to be made available. The most obvious low tolerance scenario is an interactive setting where latency tolerances are in the sub-second range. A less obvious scenario is one where the objective is to control some automated process in which responsiveness is critical. On the other hand, the typical retail ecosystem encompasses a multitude of automated processes that have a relatively high latency tolerance so long as the latency does not adversely impact process SLAs.
It is important to note that ORDS has a latency tolerance of 300 seconds. That is, the RESTful service source execution must complete within 300 seconds or a Socket Hung Up error will be returned. The 300 second threshold is a hard limit. Bear in mind that DB execution time jitter, which is the result of DB load variation, can increase typical execution times. Parameterized RESTful services may also exhibit a wide variation in execution time. Building a reliable service may entail introducing a retry component. In some cases, it may be necessary to use an asynchronous execution approach. An asynchronous approach is called for whenever the execution time for representative use cases plus jitter is likely to exceed the 300 second boundary.
The second factor one considers when selecting an integration approach is data volume. Distinctions between high and low volumes are best measured in terms of time rather than bytes. Essentially, the amount of data one can rapidly move from one place to another is ever increasing; however, what one considers long versus short transit times, though subjective, remain somewhat constant. For example, low data volumes are associated with transit times measure in seconds whereas high data volumes are associated with transit times measured in minutes.
Though both latency tolerance and data volume are best measured using time, they are measuring different things and are useful criteria when selecting an integration approach for a given problem. Figure 1 presents a data integration option matrix that provides a conceptual framework for deciding which approach, data service or object store mediated transfer, is best suited to a given problem. Although the figure is for the most part self-explanatory, data service with paged result warrants some discussion. Paged results concern outbound integrations only. These integrations produce JSON formatted results where each page returns one part of a multi-part result as well as URLs for the next and previous page.
The last factor one might consider is complexity. Creating a synchronous data service is relatively simple whereas implementing a data export is quite a bit more complicated. A synchronous data service includes a RESTful service implementation and a query implementation. A data export service (a service is used to initiate the export) includes everything that a data service includes as well as export data, managing credentials, and managing and monitoring export processes. Sometimes, however, complexity is not the most important factor when selecting a data integration pattern.
The remainder of this document will discuss how to implement outbound integration in RDS using a data services pattern and a data export pattern. Bear in mind, the examples provided below are illustrative. They are not robust. They do not implement error handling. The goal is to familiarize the reader with the parts of the problem, the tools one uses, and the relevant Oracle documentation.
Before the general features of the outbound integration problem are introduced, the reader should familiarize themselves with the basics of the RDS architecture and environment as well as prerequisites for implementation.
Outbound Integration using a Data Service
The vast majority of what one needs to know to implement a data integration using a RESTful service is described in the previous section. This short section will discuss some of the finer points of implementing actions. There are several key points to remember:
Queries consisting of a simple or complex SELECT statement can often be implemented with a GET method. Queries with complex filtering or lists of inputs typically require a payload and therefore use of POST method.
The duration of query or PL/SQL block execution must be less than 300 seconds. If it is not, the service will fail with a "socket hang up" error. If this occurs, it may be possible to page the service using a page size that is sufficiently small to consistently produce durations of less than 300 seconds. If a page service is not reliable one will need to employ an asynchronous service that populates a result table or exports data to object storage,
A handler’s PL/SQL source is not compiled when the handler is saved. Handler source compilation errors reveal themselves when the REST service is invoked. So, keep the handler source as simple as possible and avoid an approach that frequently changes the handler source. Essentially, do something simple and then call a procedure or function to do most of the work.
If the result is not returned in the handler source as the direct result of a query, one can compose a JSON object (see APEX_JSON and JSON Data and Oracle Database) and return it using htp.print. If the resulting response is more than 4000 characters long (the max length of a varchar2), the response must be emitted in chunks of 4000 characters or less.
A handler’s source is not reusable short of copy and paste. If the handler source is likely to be reusable, then encompass it in a procedure or function.
One can compose procedures, functions, test scripts, and such in the SQL Workshop using the SQL Commands and SQL Scripts tools.
Outbound Integration using Object Storage
As mentioned above, it is substantially easier to meet data integration needs using a data service pattern than it is using a object storage pattern. The data service pattern in the simplest case requires just a data service. Whereas the RESTful service in the object storage pattern moves the data only part way to its destination since the service achieved its end when the data arrives in object storage. Moreover, the data export pattern generally calls for an asynchronous start because data exports are likely to be long running. With the asynchronous start comes the requirement that one now manage and monitor the export — if for no other reason than to trigger the process that moves the data from object storage to its final destination. The remainder of this example, however, will begin with the description of a hypothetical, short running, synchronous data export approach in order to avoid introducing all the complexities of an asynchronous start. The section will conclude with a brief overview of how one would manage long running asynchronous exports.
Hypothetical Outbound Integration Problem
Consider the following hypothetical problem. The customer wants to export changes to the item master (i.e., RDS_WV_ITEM_MASTER). The customer will use the csn_nbr column to keep track of what has been exported. Specifically, the customer will select rows whose csn_nbr is greater than the max csn_nbr of the previously exported rows. The export process is assumed to be idempotent.
Exporting changes to the item master is a task well suited to a synchronous data service. The item master changes slowly, and the volume of data needed to capture those changes is relatively small. If, however, the export concerned transactions, a synchronous data service may or may not be appropriate depending on the data volumes.
One would begin by creating an item master module — in the SQL Workshop RESTful Services Tool — with a name such as item_master. The presumption is that there may be multiple item master RESTful services and using this approach to naming anticipates that possibility. Next, one creates a URI template with a template of “changes/:last_csn_nbr.” The first part of the template, changes, identifies the function of the endpoint. The last part of the template, :last_csn_nbr, is a bind variable that will be used in a query. The last step is to create the GET handler for the service.
The most common GET handler has a source type of collection query. If the source type is a collection query, then all one needs to do is provide a query as the source and ORDS will take care transforming the query result into a JSON string. In order to get the most recent changes to the item master one would use the following source for the GET handler:
select … from RDS_WV_ITEM_MASTER where csn_nbr > :last_csn_nbr The endpoint one would use to get recent changes is:
https://<host>/<tenant>/ords/mfcs/item_master/changes/26771905065where 26771905065 is the maximum CSN number of the items thus far retrieved. This design makes it the responsibility of the caller to keep track of the maximum CSN number used. With that in mind, one needs to make sure that the query returns the csn_nbr. Without it, it will not be possible to keep track of the maximum CSN number. The initial item master will have items with NULL valued CSN numbers. One could obtain all the changes since the initial load using the following endpoint:
https://<host>/<tenant>/ords/mfcs/item_master/changes/0The final part of the GET handler that will be discussed is pagination. Using the pagination, one can retrieve the query result in pages of a specified number of rows. The default pagination size is set at the module level but can be overridden at the handler level. All results are paginated; however, one can set the page size such that no more than one page is ever returned. The JSON object that is returned has the following form:
"items":[…],
"hasMore":true,
"limit":25,
"offset":0,
“count":25,
“links":[
{“rel”:”self”,”href”:".../item_master/changes/26771905065"},
{“rel”:”describedby”,"href":".../metadata-catalog/item_master/changes/item"},
{“rel”:”first”,”href":".../item_master/changes/26771905065?limit=25"},
{“rel”:”next”,”href”:".../item_master/changes/26771905065?offset=50&limit=25"},
{“rel”:”prev","href":".../item_master/changes/0"}
}The items value is a list of JSON objects where the keys are column names in the query result. The hasMore value indicates whether there is more data. The limit specifies the limit used in the query. The offset is the row offset of the first row returned. Count is the number of rows actually returned. The links value provides URLs for the first, next, and previous pages of data. Note that if this is the first query — offset = 0 — there will be no prev link. If hasMore is false, there will be no next link.
If one wanted the items included in the initial item master, then one would need to create a new data service with a URI template of simply “initial”. The get handler source would look like the following:
select … from RDS_WV_ITEM_MASTER where csn_nbr is null An interesting variation would be to also create a POST handler to copy the initial item master into object storage. This approach requires an object storage credential. The creation of a credential is something done infrequently. Bear in mind that credentials do expire and at some point credentials need to be refreshed. Once the credential is created, one implements the data export script. The last part, as implied above, entails creating a RESTful service to initiate the data export. In this case, a POST handler will be added to the “initial” URI template.
The construction of credentials in ADW is described in the CREATE_CREDENTIAL Procedure section of the DBMS_CLOUD Subprograms and REST APIs section. Note that the form of the CREATE_CREDENTIAL Procedure one uses is:
DBMS_CLOUD.CREATE_CREDENTIAL ( credential_name IN VARCHAR2, user_ocid IN VARCHAR2, tenancy_ocid IN VARCHAR2, private_key IN VARCHAR2, fingerprint IN VARCHAR2); |
One composes the create_credential script in either the SQL Scripts or the SQL Commands tool in the SQL Workshop. A sample create credential script is shown below.
BEGIN DBMS_CLOUD.CREATE_CREDENTIAL ( credential_name =>'OCI_KEY_CRED', user_ocid=>’ocid1.user.oc1...zdyfhw33ozkwuontjceel7fok5nq3bf2vwetkpqsoa', tenancy_ocid=>’ocid1.tenancy.oc1...gnemmoy5r7xvoypicjqqge32ewnrcyx2a', private_key=>'MIIEogIBAAKCAQEAtUnxbmrekwgVac6Fd....pESQPD8NM//JEBg=', fingerprint=> 'f2:db:f9:18:a4:aa:fc:94:f4:f6:6c:39:96:16:aa:27'); END; |
Refer to Required Keys and OCIDs for details on obtaining credential information. The easiest way to obtain the needed credentials is by navigating to one’s My Profile page in the Oracle Cloud (i.e., tap the profile button/image in the upper right corner and select My Profile from the drop down). Next tap the API Keys link in the Resources section on the lower left of the screen. Finally tap the Add API Key button and follow the instructions. Part of the process is downloading one’s private key. The downloaded key is in PEM format. The key will need to be reformatted as a single long string without the leading and trailing dashes. There should be no new lines in the key. These final instructions will make more sense once one goes through the Add API Key process.
The last step is the actual export itself. In order to copy data from ADW to object storage, one uses DBMS_CLOUD.EXPORT_DATA, e.g.:
DBMS_CLOUD.EXPORT_DATA ( file_uri_list IN CLOB, format IN CLOB, credential_name IN VARCHAR2 DEFAULT NULL, query IN CLOB); |
A sample export script is shown below. Note that a JSON response is composed using json_object and that response is returned using htp.print. To get started with JSON data see JSON Data and Oracle Database. See HTP for more information on hypertext procedures.
declare response varchar2(4000); begin dbms_cloud.export_data( credential_name => 'OCI_KEY_CRED', file_uri_list=>'', query => 'select … from RDS_WV_ITEM_MASTER where csn_nbr is null', format => json_object('type' value 'json', 'compression' value 'gzip')); select json_object('status' VALUE 'success') into response from dual; htp.print(response); END; |
The URI format in file_uri_list is the Native URI format, see DBMS_CLOUD Package File URI Formats.
The name of the exported object would have the following form:
transactions1_<part>_<timestamp>.json.gzSince this export is not multi-part, part is equal to "1." The next step is to consume the export. How this step is accomplished depends on customer requirements. One could use a shell oriented approach with Oracle OCI Command Line Interface, see also Object Storage Service. One could also use a Java or Python API.
Retail Home Integrations
A Retail Home integration is an example of outbound integration with a user interface or portal. Retail Home Metric tiles without charts are quite simple to implement. For example, the following data service source (with a source type of collection query) will populate the 2 Metric Tile below:
select
'PO Receipts' as NAME, 25680 as VALUE,
'N' as "VALUE_FORMAT" from dual
union
select
'In Transit' as name, 112300 as value,
This data service response is:
{"items":[
{"name":"In Transit","value":112300,"value_format":"N"},
{"name":"PO Receipts","value":25680,"value_format":"N"}
"hasMore":false,
"limit":25,
"offset":0
"count":2,
"links":[...]
Producing a 4 Metric Summary, however, is more complicated and requires one use a source type of PL/SQL (the following code only provide values for two of four metrics).
declare
begin
SELECT json_object (
'items' value
json_array(
json_object ('name' value 'Metric 1',
'value' value 0.5,
'valueFormat' value 'PC'),
json_object ('name' value 'Metric 2',
'value' value 0.25,
'chart' value
json_object ('type' value 'bar',
'items' value
json_array(json_object('name' value 'FEB',
'value' value 2300),
json_object('name' value 'MAR',
'value' value 3100),
json_object('name' value 'APR',
'value' value 2900)
'valueFormat' value 'S',
'seriesName' value 'Sales',
'valueLabel' value 'Amount'
into response FROM DUAL;
end;
Filters, if used, become query string parameters and values in the URL. The query string parameters manifest in the source as bind variables.
An Asynchronous Approach
An asynchronous approach is generally called for when the likely wait time for process completion is high. A data export to object storage is generally a good candidate for an asynchronous start. In the simplest case, one needs to implement three data services: job start, job stop, and job status. The DBMS_SCHEDULER package provides the functionality one would need for these services. There is, of course, the option to schedule an export job to repeat and obviate the need to create a job start service. One could still use a job start service to invoke an unscheduled export. The initial item master export described above, however, is both relatively small and infrequent enough (probably once) that it does not warrant addressing it with an asynchronous approach.
One uses the DBMS_SCHEDULER.create_job procedure to create a job that that can be started asynchronously. A typical approach would be to use create job to wrap a procedure. The create job invokes the procedure immediately (by setting the start_date to SYSTIMESTAMP) upon creation and is then dropped automatically upon completion. The service would return a unique job name or execution id to be used to stop and monitor the job.
Another service is used to monitor the job status using the returned execution id. The monitoring service would be used to poll the status of the job. The job status is obtained by executing a query on the DBMS_SCHEDULER.user_scheduler_job_run_details. A complete sample implementation of an asynchronous job start and monitoring framework is available on My Oracle Support.
Next Steps
The first step is to familiarize oneself with the above concepts. Start with a simple hello world service. First with a GET handler that is invoked from a browser that handles authentication. Next move on to curl or postman where one has generate access tokens. Lastly, build some simple queries. If a data export is anticipated, begin with a synchronous approach before attempting the more complex asynchronous approach.
Monitoring Resource Consumption in RDS
Although ADW is self-tuning, it cannot ensure that one's business priorities and resource consumption are well aligned. For example, the resource consumption of a new, as yet to be tuned, report may adversely impact higher priority tasks. By monitoring the consumption and performance of RDS, one is able to pinpoint which tasks could benefit from additional attention. In some cases, however, even well tuned tasks are long running and resource intensive. If these tasks are of lower priority, the user would like to run them at a lower priority. Ultimately, monitoring allows the user to both effectively employ compute services and determine if resource consumption matches business priorities. Control, on the other hand, gives the user a means to align resource consumption with priorities. Exerting control will be the subject of another chapter whereas this chapter will focus on monitoring using AWR reports.
AWR reports are used to monitor activity in ADW. This section will discuss how to obtain AWR reports, but it will not discuss how to interpret those reports. Given that each customer's monitoring needs differ, there is no ready to use AWR report access built into RDS. In other words, an AWR report is obtained via a customer implemented data service.
There are two steps to creating an AWR report, obtaining snap ids and generating the report using the appropriate pair of snap ids. Sample code for obtaining snap ids is shown in Listing 1. The code is used as the source for a ORDS GET handler. It illustrates the use of two bind variables. The first is part of the URI template, the begin_interval_time. The second optional query string parameter is the end interval time. The times are given as dates for simplicity, but snap ids are based on timestamps. If the query parameter is not given, the value is null.
Note that a procedure, HTPPRN, is used to output the response. HTP.print, which is ultimately used to output the response, only handles varchar2 args. Varchar2 strings have a maximum size of 4000 characters, which is often insufficient. Hence, the output of the query is put into a CLOB. The CLOB is then output using HTPPRN, which is shown in Listing 2.
The second step is generating the report. I hard code the snap ids for simplicity. Using the code in Listing 3 as the source of a GET handler and the URL of the data service, a browser will render the report. It would not be difficult to add additional bind variables to allow one to create a narrower snap id interval and combine the snap id query and the report generation.
LISTING 1: OBTAINING SNAP IDS
DECLARE
from_begin_interval_time date := to_date(:from, 'YY-MM-DD');
to_end_interval_time date := null;
db_id NUMBER;
inst_id NUMBER;
response clob;
BEGIN
dbms_output.enable(1000000);
if :to is not null then to_end_interval_time := to_date(:to, 'YY-MM-DD') + 1;
end if;
SELECT dbid INTO db_id FROM v$database;
SELECT instance_number INTO inst_id FROM v$instance;
SELECT json_arrayagg(
json_object(
'snap_id' value snap_id,
'begin_interval_time' value begin_interval_time,
'end_interval_time' value end_interval_time
returning clob format json)
returning clob) into response
FROM dba_hist_snapshot
WHERE dbid = db_id
AND instance_number = inst_id
and begin_interval_time >= from_begin_interval_time
and (to_end_interval_time is null or
to_end_interval_time >= end_interval_time)
ORDER BY snap_id DESC;
HTPPRN(response);
END;
LISTING 2: THE HTPPRN PROCEDURE
create or replace PROCEDURE HTPPRN(PCLOB IN OUT NOCOPY CLOB)
IS
V_TEMP VARCHAR2(4000);
V_CLOB CLOB := PCLOB;
V_AMOUNT NUMBER := 3999;
V_OFFSET NUMBER := 1;
V_LENGTH NUMBER := DBMS_LOB.GETLENGTH(PCLOB);
V_RESULT CLOB;
BEGIN
WHILE V_LENGTH >= V_OFFSET LOOP
V_TEMP:= DBMS_LOB.SUBSTR(V_CLOB, V_AMOUNT, V_OFFSET);
HTP.PRN(V_TEMP);
V_OFFSET := V_OFFSET + LENGTH(V_TEMP);
END LOOP;
END;
LISTING 3: GENERATING THE AWR REPORT
DECLARE
db_id NUMBER;
inst_id NUMBER;
start_id NUMBER;
end_id NUMBER;
response clob := null;
BEGIN
start_id := 12133;
end_id := 12134;
FOR v_awr IN
(SELECT output FROM
TABLE(DBMS_WORKLOAD_REPOSITORY.AWR_REPORT_HTML(db_id,inst_id,start_id,end_id)))
LOOP
response := response || v_awr.output;
END LOOP;
HTPPRN(response);
END;
Notification-Based Monitoring
POM can be used in combination with the data in RDS to establish automated process monitoring. A POM batch job can be setup to call a RDS data service to generate and send the Alert to the associated application such as Merchandising.
This document describes the steps needed to setup such an automated process. These steps are:
Setup a notification type in Retail Home
Implement a RESTful service in RDS
Setup a job in POM to invoke that service
RDS-POM integration will be illustrated for an alert that returns the counts of stock counts that are open for more than seven days.
Setting up the Notification Type
Typically, an alert/notification results from the monitoring activity. As a first step, a notification type associated with this monitoring activity needs to exist or be setup in Retail Home. Refer to Retail Home documentation for details on how to create a notification type. For the example at hand the notification type is MerchStockCountAlert and is setup for the MFCS application.
Implementing a RESTful Service in RDS
The first step is to create the data service boiler plate, which consists of the following:
creating a module
creating a URI template, and lastly
creating a POST handler
The steps below describe the implementation of an open stock count RESTful service suitable for integration with POM.
The alert service must conform to the POM specification. There are two relevant specifications. The first concerns the format of the JSON body in the POST, which is shown in the following table. The alert service need not use any of the details in the body of the POST message.
Endpoint to start a job. Method: POST Body: |
| Attribute | Description |
cycleName |
Name of the Cycle - Nightly, Hourly_1, Adhoc etc. |
flowName |
Name of the Flow. |
processName |
POM process name |
jobName |
POM job name |
agentExecutionId |
A unique ID assigned by POM for every job run (Re-run of a failed job would have a different id compared to the initial run) |
parameters |
Job Parameters (Pipe delimited key-value pairs -- hey1=value1||key2=value2) |
The second specification concerns the response returned. If the notification object is not null, the content will be sent as a notification by POM.
executionId |
Unique Id returned by the target app to POM for status tracking |
executionInfo |
Any additional info the target app would like to share with POM |
notification |
This is an optional entry that can contain the following attributes. The url, type, and severity fields are optional. "notification": { "info": "<message>", "url": null, "type": "ErrorNotification", “severity":1 } |
status |
Submitted/ Running/Error/Completed |
Create a Stock Count Module
The first step is to create a module. Module is a hierarchical organizing construct. The user may have multiple services associated with it or just one. The following screen shot illustrates what the create module screen looks like prior to creating the module. Note the module name is stock_count and the base path is /stock_count/.
Create a URI Template
Once the module is created, create the URI template. Note the URI template is set to open_gt_7, i.e., stock counts open for more than seven days.
Create a POST Handler
The last step is to create a POST handler. Note the method is POST and the source type is PL/SQL.
The source of the example alert service is in Listing 1. The body, a sample of which is shown in Listing 2, of the alert service invocation is accessed using the :body_text implicit parameter -- a bind variable. This variable can only be read once; so, retrieve it and store it in a variable. Unpacking the payload and crafting a response will be common tasks for most RESTful services. The example below illustrates some but not all that one might encounter. Bear in mind, the example below does not show any error handling. Experimentation and experience will determine what level of error handling is warranted. Listing 3 shows a response.
declare
-- The :body_text bind variable is an implicit parameter.
-- It can only be read once, so it is captured in a variable
-- called payload.
payload varchar2(4000) := :body_text;
-- The result of the stock count query
query_result number;
-- Note that varchar2 is set to the maximum. If the response
-- could exceed 4000 characters, a CLOB would be needed and
-- one could not use htp.print directly.
-- The response will return the agentExecutionId in
-- response as the executionId.
agent_execution_id varchar2(32);
-- The notification info destination.
notificationInfo varchar2(1024);
begin
-- Get the agent execution id from the payload (i.e., body text).
agent_execution_id := json_value(payload, '$.agentExecutionId');
-- Get a count of stock counts that have been open for more than
-- 7 days and put it in query result.
SELECT count(1)
into query_result
FROM rds_wv_stake_prod_loc spl,
rds_wv_stake_head s
WHERE s.stocktake_date BETWEEN sysdate - 7 AND sysdate
AND s.delete_ind = 'N'
AND spl.cycle_count = s.cycle_count
AND s.stocktake_type = 'B'
AND spl.processed != 'S'
AND spl.cycle_count = s.cycle_count;
-- Craft notificationInfo as a human readable string.
notificationInfo := 'Number of stock counts that have been ' ||
'open for more than 7 days is ' || to_char(query_result) || '.';
-- Craft the required JSON response. There is no executionInfo.
select json_object('status' value 'success',
'executionInfo' value '',
'executionId' value agent_execution_id,
'notificationInfo' value notificationInfo) into response from dual;
-- Output the response - note htp.print is used here. htp.print
-- only supports varchar2 so another approach would be needed
-- if the response is likely to exceed 4000 characters. This could
-- if error handling (not shown) were to return a stack trace.
end;
Listing 1: An Alert service conforming to POM Requirements
A sample payload for the above job is:
"cycleName": "cycle1",
"flowName": "flow1",
"processName": "process1",
"jobName": "job1",
"agentExecutionId": "agentExecutionId1234",
"parameters": ""
Listing 2: A Sample Payload
The response of the above service, given the payload in Listing 2 is:
"status":"success",
"executionInfo":null,
"executionId":"agentExecutionId1234",
"notificationInfo":"Number of stock counts that have been open for more than 7 days is 0."
Listing 3: A Sample Response
Setting up the POM Job
The user now needs to setup an Adhoc batch job in POM which calls the RESTful service described above. Adding such a job is done through the spreadsheet as described in the next section. The user then uploads the spreadsheet to POM then schedules to run at the desired time.
When the job executes, it will invoke the RESTful service which will return a response with notification content. POM will then send a notification to the associated application based on the designated notification type. The notification will contain the notification content returned from the RESTful service.
Adding the Adhoc Job in Batch Schedule Spreadsheet
Entries as shown below as an example need to be added in the specified tabs of the batch schedule spreadsheet for every Adhoc job created for an alert.
Figure 4-2 Process Tab
ProcessName – Add a unique process name in upper case with no spaces. Use an underscore if needed. It should end with XXX_PROCESS.
Description – Short description of the process without any special characters.
Application Name – Mention the application name where the batch process belongs to. E.g., MFCS
DependencyType – This needs to be set to ‘Time’.
AdhocInd – It will be ‘Y’ as we are creating an adhoc job here.
Figure 4-3 Job Tab
JobName – Unique job name for each alert in upper case only with no spaces. Use an underscore if needed. It should end with XXX_JOB.
Description – Short description of the job without any special characters.
RmsBatch, ScriptFolder and RmsWrapper – Irrelevant for alerts and can be left empty.
ParameterValue – This holds the two parameters needed to identify the notification type and the RDS endpoint. For the example at hand, these are:
notificationType: This is the notification type setup in Retail Home as described in the Setting Up a Notification Type section at the top of this document: MerchStockCountAlert.
restPath : This points to the endpoint defined above: mfcs/stock_count/open_gt_7.
These need to be separated by a double pipe as depicted in the Job tab screen shot above.
ApplicationName – Mention the same application name entered in Process tab. Here, it’s RMS.
Modules – Job can be associated with a module of the application.
JobType – The job type associated with RDS alerts is RDSAlert.
Figure 4-4 ProcessJobMapping
To map the new process and jobs (it’s one-to-one for adhoc jobs), enter the created ProcessName, JobName and the day(s) of the week on which the specific Process/Job needs to be run. If the Job will run on daily basis, leave ‘DaysOfTheWeek’ column blank.
Figure 4-5 Schedule
Ensure that the ‘Version’ is updated to a version greater than the ‘Current Version’ in POM Application. In this example, the version should be changed on the spreadsheet to 22.1.302.2.1 or 22.1.302.3.
Uploading the Batch Schedule Spreadsheet in POM
Login to POM UI and navigate to Tasks -> Schedule Maintenance.
Select the Application Scheduler tile and click ‘Import Latest Schedule’ button.
Upload the spreadsheet containing the new Adhoc job for alert.
Figure 4-6 Upload Batch Schedule
Enable the Newly Added Process/Job
Note that any new job introduced through the spreadsheet will be added in the disabled state. Enable it using the Batch Administration screen.
Figure 4-7 Batch Administration Screen
Starting/Restarting the Scheduler Day
You will need to start a new scheduler day or restart the existing scheduler day on the Batch Monitoring screen for the new changes to take effect in the next batch run. See the Batch Monitoring screen shot below.
You can now run the Alert job in POM in one of two ways:
Direct run through the Batch Monitoring screen or
Schedule it to run using the POM Scheduler Administration screen.
Direct Run
On the Batch Monitoring screen, select the Standalone tab below the tile area. Then select the previously added RDS Alert process in the Standalone Entities table and click on the run action button above the table.
Figure 4-8 Batch Monitoring
Schedule through the Scheduler Administration Screen
You can use the POM Scheduler Administration screen to schedule the newly added job to run as frequently as needed.
Figure 4-9 Scheduler Administration
In Context Launch of an APEX App
In context launch of an APEX App entails navigating to an APEX App from within a product application using a URL. Once you have deployed your application, loaded the data, and created users, you can publish your production URL. You can determine the production URL for your application by either:
Selecting the application on the Application home page and right clicking the Run button. Then, select Copy link address or Copy link location depending on your browser.
Running the application and then copying the URL.
Invoking an APEX app with one or more query parameters requires that the APEX App Session State Protection and Application Items be appropriately configured.
In your APEX App navigate to Shared Components > Security > Session State Protection. Navigate to the Set Page and Item Protection page of your published launch page, for example, your App Home page. Next, set page access restriction to Unrestricted. Always treat query parameter input as untrusted and sanitize it.
Next navigate to Shared Components > Application Logic > Application Items. Create an application item of the same name as your query parameter.
See Oracle APEX for additional details on URL syntax and managing session state.
Launching APEX Apps from Retail Home
It is quite simple to configure Retail Home to facilitate the launch of an APEX application.
Navigate to the Dashboard Configuration tab and tap the Create button.
Figure 4-10 Dashboard Configuration Tab
Fill in the Create Dashboard Tile Dialog. Note there is a field for specifying a URL for you new dashboard tile.
Figure 4-11 Create Dashboard Tile
