Configure which Properties of Aggregated Records and their Members are Accessible to Front End Applications
You can configure which properties of aggregated records
and their member records are accessible to services such as guidedsearch (which produces search results) and typeahead (which controls the typeahead function).
This section applies to Open Storefront
Framework (OSF).
This can reduce the amount of data in the JSON returned by calls to these services. In particular, it can make inaccessible the data that is irrelevant to shoppers or is otherwise sensitive, such as profit margins.
By default, all properties of aggregated records are accessible to services.
To configure which properties are accessible, execute the following endpoint with JSON content that configures which properties are accessible:
PUT /gsadmin/v1/cloud/pages/Default/services/service_nameWhere service_name is the name of the service,
such as guidedsearch or typeahead, whose access to properties is limited by this call.
For example:
PUT /gsadmin/v1/cloud/pages/Default/services/guidedsearchIn the JSON content, list the properties that you want to make accessible, as follows:
- List properties of aggregated records in the
attributesfield of theresultsListelement. These properties hold values such as minimum and maximum prices.fieldNamesis deprecated in this release. - List properties of member records in the
childRecordAttributesfield of theresultsListelement. These properties hold values that shoppers search on, such as names, descriptions, brands, and SKU-level data per product, such as swatches.subRecordFieldNamesis deprecated in this release.ThemaxChildRecordsspecifies the number of child records to be returned. This configuration expects an integer from the following list:- 0 (no child records)
- 1 (one child record)
- -1 (all matching child records)
For example, execute the following endpoint with the JSON content
shown to cause all matching SKU level data of member records
to be accessible to the guidedsearch service:
"resultsList": {
"@type": "ResultsList",
"maxChildRecords": -1,
"attributes": ["product.repositoryId", "product.displayName" ],
"childRecordAttributes": [ "product.repositoryId", "sku.repositoryId", "product.displayName",
"sku.listPrice", "sku.activePrice", "product.primaryFullImageURL", "product.route" ]
}You can see your changes to the configuration of aggregated records in you Preview storefront. To see the changes in your Production storefront, you must first publish the changes.
Setting maxChildRecords to -1 can impact
performance both in terms of response time and the response
payload size. We recommend that you use attributes, childRecordAttributes and maxChildRecords together to minimize impact on performance.
