Modify Data Structures to Enhance Searches and Navigation
In some cases, you can enhance the ease and accuracy of navigation or of searches on search terms by performing operations known as transformations on your data structures.
This section applies to Open Storefront Framework
(OSF).
Retail Digital Commerce supports three types of transformations:
split-regex- Splits the value of a dimension or property and assigns each part of the split value to a new dimension or property.split-jsonpath- Replaces the JSON value of a property with values that it extracts from the JSON.concatenate- Concatenates the values of dimensions or properties into a single new dimension or property.
One or more transformations can be performed on a single attribute (property or dimension). Transformations are in all cases optional.
The following sections describe each of these transformations.
Configure a Split-regex Transformation
A split-regex transformation divides the value of a dimension or property into
separate values and assigns each separate value to a new dimension
or property.
This transformation is useful when the Catalog
contains an attribute whose value is a delimited list of values. Such
a list is not usable for user navigation. However, the split-regex transformation can split the list into separate values that are
useful for navigation.
The transformation uses a regex pattern to determine where to split the dimension or property value. The pattern can be either a single character or a more complex regex pattern; for example, the following pattern specifies that a value is split at any occurrence either of two dashes or of a comma and a semicolon:
"(\-\-)|[,;]"Suppose that your product data provides the following different values for a dimension named country:
"country": "UK, US, DE"Although such an assignment is acceptable in the Catalog, is it
not useful for user navigation by dimension. The split-regex transformation, however, can convert this assignment into ones that
are useful for navigation, as follows:
"country": "UK",
"country": "US",
"country": "DE"The conversion above is performed by
the following split-regex transformation:
"ecr:type": "attributes-owner-folder",
"country": {
"ecr:type": "dimension",
"mergeAction": "update",
"indexingTransforms": [
"transform": "split-regex",
"pattern": ","
"ignoreDuplicatePropertyValues": "true"
}The following table lists the properties of the split-regex transformation:
| Property | Data type | Default value | Comments |
"transform" |
String | n/a |
Required. Must be set to Example: |
"splitPattern" |
String | none |
Required. The regex pattern must comply
with Example:
"sourcePropertyNames" |
JSON Array | The name of the attribute to which this transform applies. |
Optional. Example:
Boolean | True |
Optional. Example: |
Boolean | True |
Optional. Example:
Boolean |
True when the source property is the same as the attribute name. False otherwise. |
Optional. |
Configure a Split-jsonpath Transformation
The split-jsonpath transformation
extracts values from a specified location in the JSON value of a specified
property. The transformation replaces the JSON value of the property
with the extracted values. No other properties are created or modified
by this transformation.
For example, suppose that the following
JSON has been assigned as the value of a property named product.shoeSize:
"product.name": "Suede Shoes",
"product.childSKUs": [
"sku.id": "1000-R-M8",
"shoe.color": "Red",
"shoe.size": "8"
"sku.id": "1000-B-M8",
"shoe.color": "Blue",
"shoe.size": "8"
}The following split-jsonpath transformation
replaces the JSON value of the property product.shoeSize with values that it extracts from the JSON value:
"product.shoeSize": {
"isAutogen": true,
"transform": "split-jsonpath",
"sourcePropertyNames": [
"product.shoeData"
"splitPaths": [
"$['product.childSKUs'][*]['shoe.size']"
}The split-jsonpath transformation
assigns the extracted values to product.shoeData as follows:
"product.shoeSize": "8"The following table lists the properties of a split-jsonpath transformation:
"transform" |
String | N.A. |
JSON Array | The attribute name to which this transform belongs |
Optional. Example:
Boolean |
True when the source property is identical to the attribute. False otherwise. |
Boolean | True |
Optional. Example:
"splitPaths" |
JSON Array | Not applicable |
Required when it is not an identity transform.
The array values must comply with Example:
Note: When |
Configure a Concatenate Transformation
A concatenate transformation can combine the following:
- The different values of a multi-assigned property, or the values of two or more different properties.
- The values of two or more dimensions.
The concatenated values are assigned to a single new dimension or property.
To include the new property in searches, you must
add it to the fields array of your search interface.
You can concatenate localized properties with non-localized properties. The resulting property is localized. You cannot, however, concatenate properties that are localized to different locales.
For example,
the following JSON example creates a record property named all.colors and assigns to it, as a single unitary value,
the concatenated values of the existing record properties shirt.color, dress.color, and pants.color:
"all.colors": {
"propertyDataType": "ALPHA",
"ecr:type": "property",
"transform": "concatenate",
"shirt.color",
"dress.color",
"pants.color"
}For example, suppose that values are assigned to the source properties as follows:
"shirt.color": "Red",
"dress.color": "Yellow, Black, Red",
"pants.color": "Orange"The concatenate transformation
above assigns the follow value to the output property all.colors:
"all.colors": "Red Yellow, Black, Red Orange"The following table lists the properties of a concatenate transformation:
"transform" |
String | Not applicable |
JSON Array | The attribute name to which this transformation belongs. |
Boolean |
True when the source property is equivalent to the attribute name. False otherwise |
Boolean | True |
Disable Transformations on a Property or a Dimension
The system owner can disable transformations
on a property or dimension specified by non-system owners. To do this,
specify an empty indexingTransforms attribute.
The following example disables transformations by non-system owners
on the property named product.color:
"product.color": {
"ecr:lastModifiedBy": "admin",
"indexingTransforms": [],
}Applying Transformations
Transformations are applied by POST or PUT REST API calls of the following form:
POST | PUT /gsadmin/v1/${appName}/attributes/${owner}For example:
POST /gsadmin/v1/attributes/owner1When both the system owner and a non-system owner specify transformations, the transformation specified by the system owner is used. However, when only a non-system owner specifies a transformation, the non-system owner’s transformation is used.
For more information about how to make POST and PUT calls, see Understand how to execute endpoints.
