Understand how to Execute Endpoints
Each request to execute an endpoint consists of the endpoint itself - that is, an HTTP method and a URL - as well as other information required by the endpoint being executed.
This section applies to Open Storefront Framework
(OSF).
For example, the endpoint that imports configuration of keyword
redirects is as follows:
POST /gsadmin/v1/cloud/redirectsYou must provide the following information:
- A message header specifying a valid OAuth access token
- In JSON format only, a message header specifying that imported
content is to be parsed as JSON. The value of this header must be:
"Content-Type:application/json". This header is not used with endpoints that export or delete configuration. - A parameter that points to the file containing the content to be imported. This parameter is not used with endpoints that export or delete configuration.
A variety of tools and utilities exist to enable you to execute endpoints. For samples of how to execute the endpoints using the cURL command line utility, see Sample Search and Navigation REST API endpoints using cURL.
