Understand ZIP Format and JSON Format
Any request can be made in either of two formats: ZIP format and JSON format.
This section applies to OSF. This section applies to Open Storefront Framework (OSF).
These formats differ only in how they import and export configuration. All configuration, however exported or imported, is written in JSON code.
The following table summarizes the differences between JSON format and ZIP format.
Format Input and output HTTP methods Best uses
JSON
JSON content specified in command line or utility, or
In JSON files.
GET
POST
PUT
PATCH
Exporting configuration for viewing, or
Configuring resources.
ZIP In ZIP files that contain JSON files.
GET
POST
Exporting configuration for backup and migration, or
