HTTP Methods for Configuring Search Features
The following table summarizes the HTTP methods supported for use with JSON format and ZIP format.
This section applies to Open Storefront Framework
(OSF).
| Format | Operation | Method | Examples |
| JSON | Export | GET |
| JSON | Create | POST | POST/gsadmin/v1/cloud/thesaurus |
| JSON | Overwrite | PUT |
The input to the PUT request can include configuration of the child objects (thesaurus-entry) of thesaurus. The imported configuration of the child object replaces its existing configuration. |
| JSON | Modify | PATCH |
PATCH modifies an existing object by modifying the values of existing attributes in the object or adding new attributes to the object. Note: PATCH cannot modify child objects of the object specified in the URL. For example, to modify a
| ZIP | Export | GET | GET/gsadmin/v1/cloud/thesaurus.zip |
| ZIP | Create | POST | POST/gsadmin/v1/cloud/thesaurus |
| ZIP | Overwrite | POST | POST/gsadmin/v1/cloud/thesaurus |
| n/a | Delete | DELETE | For information, see Delete resources. |
Note the following differences between the HTTP methods that are supported for ZIP format and for JSON format:
- JSON format supports two methods that are not supported for ZIP format: PUT and PATCH. These methods cannot be used with ZIP format.
- With ZIP format, the POST method creates configuration, overwriting any existing configuration. With JSON format, POST can create but not overwrite; to overwrite configuration in JSON format, use the PUT method.
